15K maintenance requirements for 2006 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by satsuke, Jan 24, 2007.
  1. satsuke
    satsuke Junior Member
    68
    I just had a question on saving $ and the standard service on the 06 prius.
    I've called two different dealers in my area to see what needs to be done and at what cost.
    One dealer (the closest .. Superior Toyota in Merriam, KS) indicates the 15K maintenance is just another oil change and tire rotation .. with the possible added cost of replacing an air filter (didn't specify if cabin or engine). for around $120.00 .. they charge $60 for just the rotate and oil change normally .. though the guys I've talked to have all been clueless on the Prius 5000 mile maintenance schedule
    Another dealer (Molle Toyota in Kansas City, MO) indicated at 15K that an oil change, rotate and balance, cabin air filter and engine air filter change, as well as a read drum brake readjust and detailed inspection. All for around $200.
    My question is .. if all things being equal, the dealer charging $60 for what is normally a $25 oil service, and several shops in my area offer linetime balance and rotate for ~$15 per tire.
    As far as toyota official things .. what's the official 15k interval checklist? I read something on the toyota web site indiciating basically just a general inspection to go with the oil change and rotation up until 30k or so. And I can figure out how to reset the dashboard maintenance required monitor and / or get to the cabin air filter if it's located where I think it is behind the glove box panel.
    Anyway, any suggestions? I'd love to keep going to toyota service for everything ,. but the $ != better service or price.
    Thanks
    Brian
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Just do a LOF, inspect the different filters and change if necessary and rotate the tires If necessary. Check the different Toyota dealers website, alot of them have coupons you can print out for LOF's ect.
  3. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    I'd think at 15K, oil change and tire rotation are all that's needed.
    Both air filters are pretty simple DIY items, and I thought the interval was 30K on them (I don't have the book handy, but just did 15K not long ago and didn't change them). There's a thread on the cabin air filter here, it is pretty easy to get to once you figure out how to get the lower glove box out. Engine air filter is just like any other car, a few clips, no tools needed. I think the cabin filter is around $20 and the engine filter $10 or so, just guessing, haven't had to buy either yet.
    If the other inspections make you feel better, then by all means go for it, but it would seem like a waste of money to me. There should be no brake wear, and adjusting drum brakes should not be necessary at 15K, or probably ever etc. etc.
  4. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(satsuke @ Jan 24 2007, 11:19 AM) [snapback]380063[/snapback]</div>
    Where is your Toyota Scheduled Maintenance Guide? (It should be with your manual.) You need to find it and read it unless you want to just hand your wallet to the dealer and say "Help yourself." Make sure you are informed BEFORE you go to the dealer. Dealers like to add on all sorts of extra things that aren't needed.
    <div class='quotetop'>QUOTE(Beryl Octet @ Jan 24 2007, 11:50 AM) [snapback]380097[/snapback]</div>
    You're right. I just looked up mine and the 15K is just oil, tires, and visually inspect a bunch of things. 30K for the cabin air filter.
  5. NightRider
    NightRider New Member
    35
    yes, after thinking this through even further, I agree that the
    15K should not cost more than $20 something for the oil&filter,
    and cost for tire rotation, unless you get that for free.
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(NightRider @ Mar 16 2007, 10:18 PM) [snapback]407181[/snapback]</div>
    $56.45 for an oil change and tire rotation!? :eek:
    Around here that's $21 at Firestone. Plenty of places charge $20 or less for an oil change and $20 or less to rotate tires.
  7. itsme
    itsme New Member
    68
    in mis - missouri an oil change alone is going for 29.95 and up I found a toyota dealer service special coupon on the net for $ 16.95 LOF and it does not have an expiration date will print up a few!!!
