15K Update
Discussion in 'Gen 5 Prius Main Forum' started by futurist, Oct 28, 2025.
  1. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Agree on declutter = pretty. But have been in cars before w/o that *one thing I took out* and needed it. Tiny curse raincloud following just me around, I guess...
    My old-school 5 x D-cell Maglite / bat from what, 1997? Still with me... and battery cap's a chamfered flat -- guess with all the 'tacticool' crap selling these days, Maglite decided on a small-investment mod for way more appeal commuting -- esp if your commute involves black ice and crossing water :confused:
    Re: some of Hammer's reccies -- totally forgot about my digital 100-psi JACO gauge (#1 on ProjectFarm) and OBD2 reader / app. Haven't had to use the reader for the XW60 but tbh don't see a lot of utility unless something's malfing enough to be noticed. Nice to know it's there when that happens, tho... but imo it's more for deeper modders who'll need the data.
    The JACO's been pretty much flawless, except for one thing: on at least my Toyota's valve stem threads, a riser of some kind on the inside of the JACO's chuck catches the brass threads, preventing you from pulling it off the stem immediately. Pressure leaks out for a split second too long, so the pressure when you finally get it off, isn't the same as you measured. With the digital JACO and its hose and relief valve, all you should need to do is overinflate, then bleed the pressure on each tire down to your spec with the JACO -- this lessens time inflating by a lot, especially if your pressure comes from a vending station that charges $2 for 5 mins of pump. Old tech trick...
    Besides the spare tire mod, am really interested in this one, as like to park very close to my passenger-side wall, and a motorised mirror would make this easier. Will do some reading (y)
    Oddly enough, no one will ship the super-cap power pack I want (Autowit 800A) to even though it's not a Li battery, it's a cap. Despite, still falls under Li-ion air freight restrictions, apparently. Not enough we have the Matson Tax of 30% on everything, plus 30% COVID Tax -- we can't even get decent jump packs if our 90F summers kill 12V batteries like flies :cautious:
    You know, have had nothing but good exps with those simple push-thru-w/-glue-then-trim cylindrical white rubber plugs, on both my Paseo (had one tire with two in the tread I ran for years to the wear bars) and in moto treads -- which if you don't know what you're doing is far more likely to kill / maim you vs. just strand. So if I run out of Dynaplugs on the road (if/when I move back to the mainland, and roadtrip again)... good to know every hardware store in BF, Egypt'll stock something like that, which I can vouch for.
    Tbh, know for a fact those chintzy sticky rope plugs kits work astonishingly well at least on moto tires, and to boot the kits are easily stowable under the seat of a sportbike... real-estate which is shrinking with every human generation, apparently (thus the rise of tank and tail bags). But on a car -- esp one that's 3200 lbs vs. 500 on very similar 190-195/60R17 tires... I wanted something w/ a bit more redundancy (the barbed tip)... and Dynaplugs seem a bit less faff than the white glued push plugs to install, by enough for me (plus don't seem to need as much enlarging of the hole w/ a rasp, to work). Am aware patch-plugs installed with the tire off the wheel, are the only sane repair if you want to retain the most of your speed rating... but for limping to a tire shop or dealership, fits the bill and takes up minimal space. Thanks for the reccie (y)
    The one non-intuitive, non-routine addon or car stuff I've used most historically tho, is the Gerber multitool (MP600). Doesn't pinch like early military models anymore, and have used to do everything from cutting a seatbelt in a flipped car to a cooking utensil to digging out a whoor of a 20mm metal shard from my hand. Used to be a Victorinox Swiss Champ but those of course have toy pliers... the Gerber's full size in comparison being a massive multiplier (I'm here all week) used side-by-side... stuck on the shoulder in the middle of nowhere, or coming up on your buddy and their bike who'd crashed on wet leaves (the bane of backroad mountain twisties in the PNW, effing oak leaves that decompose like they're made by Ziploc). If you have enough room in the console for a Snickers, you can tote an MP600.
  2. Hammersmith
    Hammersmith Senior Member
    2,492
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm pretty sure only otatrant and I have done the mirror mod. I started it in the fall of '23 and finished in the spring of '24 when temps had warmed up enough to work outside again. Otatrant just did theirs a few months ago.
    It's not for the faint of heart or limited of skills. You have to source parts from overseas, dive deep into the wiring diagrams, and either pull the dash out(what I did) or scrunch yourself under it(what otatrant did) to get at some of the wiring. Because of the level of work and the needed skills, I don't recommend doing it unless you are already at an advanced DIY level, you really want/need the features, and you plan to own the car for well over five years. It's absolutely not worth the work if you're just going to turn around and sell/trade the car in three to five years.
    otatrant and futurist like this.
  3. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    Not successfully. I bought the model from the Japan Harrier and I am coming to the conclusion that it is not going to work. Thinking about contacting Gentex to see if they have any information and would be willing to help. I am getting from Techstream 18 the following DTC.
    U019887 Lost Communication with Telematic Control Module "A" Missing Message.
    Still a work in progress. Not looking good though. I think it may have to do with the difference in the GPS systems in Japan and the USA. The Harrier mirror has a DVR and dual cameras that record location and video feeds and store on a micro sd card.
    On the positive side it looks like the two can wires I added are working since I can read the error via Techstream. Addidng the CAN wires was simpler than I expected too. Only had to run them from the mirror to the A pillar since the CAN wires the rest of the way were already present on my car. Was thinking I was going to have to remove the dash too.
    I might try to borrow another digital rear view mirror from a Subaruu Forester that is very similar to the model that comes with the Prius to test my hypothesis.
    #23 otatrant, Nov 7, 2025
  4. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Well I am an ex-mechanic... and have pulled dashes from cars before (did the heater core on the Paseo, which has a monoblock dash, one-piece ~50 lbs, w/ 0 way to swap it otherwise (add'l nightmare, as did it in 25F weather after finally getting tired enough of wiping the inside of the windshield every few mins, just to go to the corner shops in WA, freezing my nads off. Blocking off the core = great in AZ, but real winter weather, nope).
    That said... if the job entails fabbing your own harnesses (these are CAN busses, after all), or fabbing any parts by modding OEM ones beyond drilling holes or something simple (100% reversible, best-scenario)... may want to preserve resale and trade this in. Intrigued to see how the new 1.5L HEV systems Toyota's planning for the new Corolla do in real customer hands... by that time, may be better to stay OEM and get one. But if not... enough MY will have passed to consider it (car will be paid off by then, which is when I tend to feel fine about hacking my vehicles up).
    For now, it's just me walking around to the other side of the car, to foldi in the mirror to get into my parking space. This is my only vehicle, and I don't have covered parking... so has to be something I can accomplish in one day max. Will take a gander at otatrant's writeup (y)
    EDIT: ah, just read otatrant's reply above. Have no exp dealing w/ CAN, so perhaps this isn't worth it to those not already familiar with modding them. Thanks for the info, fellas! :notworthy:
    otatrant likes this.
  5. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Good things to think about!
    It reminded me to put the black Carhartt jacket over the black-plastic-bag-wrapped donut behind the passenger seat. Less glossy, ie more stealthy, lol, and I have a tendency to not dress warmly enough in the car, although in the interest of more mpgs.... :)
  6. Mendel Leisk
    42,352
    Adding auto-folding mirrors? I’ve a notion who it’s for, posted this once before:
  7. Hammersmith
    2,492
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    My bad. I mixed up otatrant and jtchinoy. Otatrant is trying to replace his standard rearview mirror with a digital one that shows the output of a rear camera. It was jtchinoy that did the side view mirror upgrade like mine. Sorry.
    The side mirror upgrade does need additional wiring, but no CANbus/Multiplex wiring. You need 3 wires from the Main Body ECU to each mirror and 2 wires from the ECU to the driver's door switch(the window/lock/mirror one). You also need new mirrors and a new door switch(one with buttons for the folding). Depending on where you order the mirrors from, you may need to swap mirror bases as LHD and RHD cars have bases with slightly different angles. If you buy from Japan for the best prices, you take the new mirror body and put it on your original mirror base. It's super easy, though; three screws each.
    The reason to pull the dash pad is to get better access to the ECU as well as to run the new wiring to the passenger door along the main wiring harness(I loomed my new wiring and zip tied it to the big harness. I also wanted to match the official wiring diagram exactly, so that meant running some wires to existing junction connectors instead of wiring direct. Those connectors were not accessible without pulling the dash pad. In the end, my install is about 97.5% matching to cars that come from the factory with power mirrors. There were a couple wire colors I couldn't get(lavender/pink stripe and lavender/violet stripe) and one connector I bodged up a bit and doesn't exactly match the pinout in the wiring diagram(one pin is in a different spot).
    Jtchinoy did it the easier way and ran the wiring direct from the ECU to the mirrors. Because of this, they were able to just tuck the wiring up under the dash and zip tie it where convenient. Much, much easier, if not as nice and tidy.
    No matter the method, the process is all just swapping parts plus new wiring. There are no physical modifications needed to the car like drilling holes or fabbing parts. All Priuses in the world get power folding mirrors with turn signals except the US and Canada, so it's just a matter of getting those parts and sticking them on. It's the wiring that's the bear.
    futurist and otatrant like this.
  8. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Ah -- that brings it back on the list then! Okay, will probably go the jtchinoy route, just for expediency, given I can't park the car for this mod more than the weekend (plus, the fewer things I touch first-attempt-no-exp-wrenching-on-XW60, the less chance something gets damaged / wonky).
    Again, thanks muchly, fellas -- leave it to us in NA not to get the nice things everyone else does :notworthy:
  9. Mendel Leisk
    42,352
    Once every coupla years, on a B.C. ferry, I “might” be in a crowded enough spot to want to want the side mirrors folded. In such instances, I grip them firmly and fold.
    futurist likes this.
  10. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Just rolled over 16K recently...
    After getting my svc, noticed the car's taking another tenth from the dash reading. So far actual's been about the same... but 2/10ths in less than 3 wks, concerned me.
    Then thought it through: temps are coming down quite a bit, and the worst readings (20s :confused:) are coming on the short trips where the ICE doesn't run long enough to get warm. Tires are still getting used to their jobs on opposite sides of the vehicle, and with F/R swaps, now the nose is riding slightly higher than the rears, as inflating rears to 39 - 40 doesn't have the same aero effect on into-wind driving as prior. Seems almost paranoid to think mms of ride height can matter... but know they do on a motorcycle, so just less on an automobile (esp up in the stratosphere, hybrid-mpg-wise). The extra F tread also means the engine has to rotate and accelerate linearly, slightly more mass. Not in order of importance, obviously... just throwing stuff at the wall.
    Or something else entirely... who knows.
    Oil is (as Mendel posted) ~1/8" below the full mark, so not the level of the oil. Maybe its newness? Weird if it is, never exp'd this in past oil chgs. New air filter did make a bit of difference, but not as much as expected.
    My suspicion then... is alignment. Had posted before the XW6# seems pretty durable alignment-wise... but that were a while ago (I do more than normal share of avoiding things that ruin alignment, like slowing for sleeping policemen and sidestepping potholes -- which on Maui's a F/T job :rolleyes:). Perhaps time to get it done. Dealer seems to do a good job, and getting the mechanic I prefer at the local Goodyear's a crapshoot w/ no price difference... so may stop in and get it done.
    If it's still 2/10ths down after the alignment, will chalk it up to the cooler temps and worn tires (n)
  11. Mendel Leisk
    42,352
    Boy, you’re closing in on @ETC(SS) , for esoteric blitzkrieg. Just to disentangle one of ‘em:
    sleeping policemen = speed bumps
    hate them btw, especially in parking lots when they’re spaced every 20’ or so. Or the occasional, brutal ones, way too high/abrupt, requiring dead-slow. Or the diagonally placed ones, prone to put your neck outa joint.
  12. ETC(SS)
    7,560
    Hit them at 90 and you don't even feel them...... :ROFLMAO:
    @ Alignment:
    This is why I learned how to drive and I don't drive fragile little cars.
    I have not required an alignment in any of my last 8 cars spanning 30 years more or less.
    My tyres wear evenly, my cars do not change lanes by themselves when I let go of the steering wheel and my steering wheels have never been off-center. I ALSO have 200k in Priuses (2 G3s) and I live in a fairly rural county (60k souls in 1000 mi/2) and have never seen fit to ram into curbs or otherwise modify my vehicle's suspension geometry.
    I also rotate my tires assiduously every 5k using a forward or rear cross pattern (depending on type.)
    I do this service MYSELF after learning a painful lesson once upon a time about trusting dealers to do it correctly.
    (same with filters and fluids.....)
  13. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Obvi, have the aptitude to do this myself. Lack now, the tools & esp the opportunity to do it.
    Long story short, bad right knee (juuust stopped me shining my wheels every Sunday; hurts too much now), plus the conditions local here, that make working on your own car w/o a garage, nearly impossible. Details if desired, but they're even more boring than my usual posts :p
    Dealer here isn't that bad for pricing, and has fewer fartcan kids in the tech pool not giving a crap about their work (notice I said fewer.. they're there, just fewer than Toyota master technicians). Honda dealer was/is awful for this in my direct exp. Not sure why Servco, which owns and services Toyota dealers on O'ahu (Honolulu County), only has a Lexus dealer here... and they won't svc Toyotas as long as the non-Servco Toyota dealer -- the only Toyota dealer in the County -- exists. And non-Servco dealers' standard of svc, tends to be a lot lower than Servco's. So like a lot of things on an island, the business' attitude is 'where else you gonna go?' :cautious:
    But direct exp at this monopoly dealer, has been pretty much flawless so far; maybe some crisis enabled some sea change, who knows (wouldn't have touched this dealer in 2018, when the last Honda were purchased) Not sure how long that'll last... but have no problem dropping it off for an alignment. Have a backup if they do screw up, about the same price... but no reason not to trust the dealer, when doing it myself's a lot more of an ask than would be anywhere on the mainland ;)
    Re: things that screw up alignment other than the dealer :p
    This County has some of the worst-maintained roads of anywhere I'd lived -- and it doesn't even freeze here! Mentioned in another post why... but some stretches of lumpy years-of-asphalt-patches (caused by cement trucks, 18-whl dump trucks hauling fire debris, sanitation trucks, and the recent appearance of heavy EVs), are still there since the last time I'd lived here, in late '90s.
    So am sure freezing conditions that do tear up roads there, and driving rural -- read dirt -- roads, doesn't do a thing to your suspension, you do everything perfectly. But can't avoid it here -- it's slow attrition that needs looking after. Big reason why balloon tires on Tacomas, make it the most popular vehicle sold in the State -- it's not that much better elsewhere (y)
    #33 futurist, Nov 12, 2025
  14. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Not a massive update, just some thoughts on maintaining mileage after a svc visit...
    Read earlier posts re: what I suspect's changed after the last svc visit. Always some chg, like they're effing around in my mapping parameters -- the first one was actually positive (one where my car began getting 65 mpg actual, vs. 58 -- the throttle and regen point in the brakes felt different than what I took delivery of).
    So with this dreaded bum knee, am trying not to drive too far in a trip, as keeping the knee still for too long makes it exponentially worse getting out of the car. But all the same, the fact the ICE will warm up, w/ super-rich warmup 'jetting', until coolant temp sensors report a threshold temp... means shorter trips = mpg in the 30s, 20s... and even teens. And pray you don't gun the ICE in this warmup phase -- or say goodbye to your tenths, maybe even whole numbers.
    So have been gently tootling around after starting the car (such as after my parking structure workout), as the next workout at the park, is only a short distance away. Found some possibly interesting things to bounce off you...
    • every day, more evidence some high-medium throttle you think will tank your mpg, in a sortie > 5 mi... will gain you more than grannying the throttle all the time. Mentioned this earlier, but it still baffles slightly. If you use less throttle angle, you consume less fuel, which should read as better mpg. Must be a fair bit more complicated, as XW60 defo wants the throttle to be used -- almost like I'd use my Civic throttle... but caveat, only for accel to a certain speed. If you maintain that throttle enough to shut out EV mode... then can understand what's going on. You're encouraged to stab --> pull 100% in a 5th-gen (maybe all Priuses) in bumper-sticker terms.
    • not how I drive, as don't want everyone behind me to rightly clock me as using PriuSlinky road speeds (hell I used to pull around 2nd / 3rd gens on sight, because of this accordion-speed nonsense). Maybe I'd get whole numbers better if I pissed others off. Nah, there's always that one urchin on the edge, ready for any excuse to let the red mist fly. It is post-covid, and tbh, these transplants moving here from mainland often have a lot of worldliness on us true plantation Locals... but frankly no idea what to do and 0 grace when confronted, when the plan that would've worked wherever they're from, fails on Maui :rolleyes:
    • have been testing the 'apply throttle only when unwinding steering away from lock, never towards it'. Not only does this save the CV roller bearing surface becoming pitted from combined torque in the same place thousands of miles... but prevents full electric torque stressing them as well, if you roll on vs. jab (this is another reason I'm never in Sport mode anymore). Much like applying throttle on your 450-lb, 1-wheel-drive, 100bhp motorcycle in the wet, rolling on will insure you can feel what's happening at the contact patch, as well as delay when breaking free leaned over, visits karma unto your impatient, squiddish arseblossom :eek: The car seems to like this, as mpg increases the further you are from steering lock... so only applying throttle when you're nearly centered, means less energy to overcome huge friction in a pair of CV joints.
    • is there any way to disable this forum's annoying habit of correcting my spelling to the wrong thing? And what's happening with this bullet point's alignment, when I try to add a space between paragraphs? Could do it above, why not now :cautious:
    • aaanyway :p last thing, is kind of hilariously aimed at my post about extending the fob signal, by firing it into your own head. At the park, forgot whether I'd locked the car (blame the knee pain)... so was ~60m down the trail at this point, about twice as far as I'd even consider the edge of trying (25m is usually practical limit, before begrudgingly walking closer). On a whim, tried it, opening my gob as far as it'd open. Flashes. Wait -- wut?
    • figured out... was that station for bodyweight exercises mentioned in another post, near the car. All metal -- mostly steel and aluminium. Must've reflected the signal just right... because tried it again, and it worked again. Tried again at my lunch place, nothing but cars around (steel, I'm assuming) -- nothing. Oh well -- guess I need to carry a steel barn door with me, to get the same fob range as my old sold Civic (n)
    Gokhan likes this.
  15. Mendel Leisk
    42,352
    Just curious, are you touch-typing?
    Gokhan likes this.
  16. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Partially... never formally trained to touch-type, but mostly do for a selection of common words. Had been a programmer in mil and in IT on / off forever... so always typing but never could fully keep eyes on the cursor constantly; that's my brain :rolleyes:
    To make things clearer re: spacing borks in the above post... I hit Return twice Delete once, then click the bullet-point button top of the rich text editor, and then the Inset Right button for sub-paragraphs. Sometimes it works... most times does what was posted. Maybe missing some magic combo of Deletes, Returns and Bullets? No idea.
    Re: the word correction phenom... often it will change what I type, but only after hitting Save Changes... which sort of defeats the purpose. No idea what the list of banned words is, but will Save (then Refresh per your advice), and the forum just kicks the words out -- often making my writing even more gibberish than it already is :p
    Mendel Leisk and Gokhan like this.
  17. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I'm going to drive a little more 'normally' this tank. I recall that one of the tips in my TDI days was to get up to speed in a non lacksidaisical manner and then shift up to the highest gear the engine could take.
  18. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    So... visited the dealer today to receive a new fob, only took a year to come in :rolleyes: Drive down, we can program that for you.
    So rocked up figuring they'd be able to remotely access the security system in the car (like the fob does), with some handheld device, then hand me my spare. So didn't remove my stuff from the car as normal.
    Nope. Need to pull it up to get sucked into the garages, just like a regular svc, says my writer. Fine...
    Not a bad wait time tho, ~45 mins... pretty quick considering the overhead the staff needs just to get the ppwk together (sometimes 15 mins by itself). Drove away, seemed normal.
    However... the throttle response on the car, in Normal mode... was waaay more aggressive. WT...?
    To their credit, nothing was changed in the car when it were returned to me, but the position of the seat and the temp of the A/C, which is fine as I keep seatback vertical for posture -- I am a bodyworker, natch -- and temp set to Auto & 80F, to save main battery charge for propulsion, minimal for cooling. Don't mind if the techs run it full LO once in a while, as A/C systems need worked occasionally to keep things internally lubricated.
    But Christ -- someone gunned in front of me merging into a side street next to Safeway... then act like they're on their permit making a right turn, took several seconds for a 1 sec maneuver. So pulled around them (had 2 lanes) on a 12% uphill grade right before the supermarket. The car peeled out uphill, and launched two lengths ahead, like it were on level ground. It's never done that... except right after the 10K svc :cautious:
    So even programming a fob, resets something in the PCU to reset mapping? Wth for...?
    Must be just plugging a Toyota service computer into the OBD2 port, makes all brand PCUs into default zombies... **you will forget everything about the last 1K miles of driving** (Vincent Price hands) :p
  19. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    But do they have an espresso machine?
  20. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    They do not -- but we're talking Maui here, not the First World :p
    I don't drink coffee anymore* so wasn't looking too closely... but if memory serves their coffee machine was a K-pod one, meh.
    Tbbh, don't care if they offer coffee, if a 2nd fob takes a year to get to me :cautious:
    * used to svc espresso machines (Brasilia, Rancilio, La San Marco) for a living in AZ for about a year and change... then found out tasting massively good espresso hundreds of times daily, had given me hives. Doc said the caffeine consumption were poisoning my liver. End of espresso machine career :cry:
    So Keurigs wouldn't sate my tastes anyway -- had roasted beans ground right off the cooling tray at my job -- hard to follow that.
    VelvetFoot likes this.
