16 inch wheels to fit 2023 prime?
Discussion in 'Gen 5 Prius Main Forum' started by jbbass, Sep 12, 2023.
  1. Mendel Leisk
    41,457
    16" rims may catch on like fire, and not just for snows. (y)
    otatrant likes this.
  2. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Blackat- no issues with the extra width? Just want to be sure.... And adequate clearance around the brakes with 16" diameter? I guess so, or you wouldn't have done it....
    Thanks for confirming! Reassures me about my winter wheels!
  3. Blackat
    Blackat Active Member
    459
    319
    Colorado
    2023 Prius
    Limited AWD-e
    None at all. I had a long conversation with TireRack before I bought. They did put the balance weights too far outside on the inner wheel and they rubbed on the caliper oh so little and I had the tire shop relocate
    Teleplayer likes this.
  4. Mendel Leisk
    41,457
    That's pretty tight; the weights are about 4mm with adhesive.
  5. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    I was trying to understand why you were putting on winter tires NOW... and looked at your location: Colorado?! It's that time already?
  6. Blackat
    459
    319
    Colorado
    2023 Prius
    Limited AWD-e
    Yep. It was an annoying rotation noise as it passed by the calipers.
    I thought it might go away after a few miles but it didn’t so had them moved to the inner inside of the wheel
    Yeah, I live in Winter Park. I would have waited but one of the tires had a side wall blow out and I have the Wheel/tire warranty. Plus I had the new wheels and tires so I installed them.
    Snow in the mtns coming this week.
    Also, still waiting on the dealer to get me a replacement tire, been a week.
    #24 Blackat, Oct 2, 2023
  7. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Thanks for sharing your experiences with us. I'm leaning towards 16" and 205s also.
    otatrant and Blackat like this.
  8. Mendel Leisk
    41,457
    That 4 mm clearance is tight. Could depend on the rim; others might be better.
  9. purplePriii
    purplePriii Active Member
    275
    122
    Gonna be interesting to see if heat or even ice and snow accumulation will cause problems down the road. 4mm sounds pretty tight indeed.
  10. Mendel Leisk
    41,457
    Yeah I'm thinking if hidden weights are just grazing the calipers, 17" rims are the sensible minimum. Again, it could depend on the rim, but seems dicey.
  11. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Yeah... here I was congratulating myself on my bargain priced 16" rims... ;p
  12. purplePriii
    275
    122
    Hey there, I'm happy you're taking the risk for us! ;p
    But really, these are just random questions in my mind. You can get ice accumulations on any wheels. As for heat, I am not entirely sure how the regen braking works. My understanding is that it doesn't always engage the pads so might have less heat generated there but I am not sure if it generate any of its heat during regen and if it's centered around the wheel. Could be a non issue.
    Keep notes, color and life of the discs please!
  13. Mendel Leisk
    41,457
    I've got 15" Plug-In Prius rims on our '10 right now. Doing finger-feeler-gauge on them, with the front my pinkie is a go, ring finger a no-go. With the rears, somewhat surprisingly, even pinkie is no-go. Just.
    Checking my pinkie with a caliper, I'd make the rear (lesser) clearance around 8 mm, fronts maybe 9.
    someone here was upset by my whittling popsicle sticks down to certain mm widths (to rough check brake pad thickness); hopefully he doesn’t catch wind of this…
  14. Blackat
    459
    319
    Colorado
    2023 Prius
    Limited AWD-e
    That's not really a concern.
  15. jbbass
    jbbass Junior Member
    Interior BC Canada
    2023 Prius Prime
    SE
    These I believe are the exact wheels I ordered from Costco. I will be having Bridgestone 205 65r16 winters mounted this Friday. Wheels clear the front calipers by about 1/2 inch. These wheels also work with the OEM nuts which are not cone type.
  16. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Please advise how it goes. Don't be surprised if I pm you.... (then i can return the set of 17" that i'd ordered initially, tried to cancel... but received anyway)
  17. Nntw
    Nntw Active Member
    398
    248
    Toronto
    2023 Prius Prime
    Michelin.ca has a sale starting tomorrow: Oct 5- Dec 20 2023 $70 off a set of 4, and an additional $30 off a set of winter tires.
  18. Steve Step
    Steve Step Junior Member
    Huntsville
    2023 Prius
    XSE
    Gen 5 winter rims?
    I have been trying to follow the link (above in this post) for 16 inch rims from Costco but have found that the link for the rims mentioned was for Costco Canada. Has anyone been successful in ordering that part number for C wheels ( is part number 1253385) for the C- wheels 16 inch TY1 Replica wheel CW08119 inside the US? . Sorry as I am a newbie the site will not allow me to post the link mentioned in this string of posts.
    It is getting time to add snows here soon. Thanks
    jeremnyc likes this.
  19. Steve Step
    Huntsville
    2023 Prius
    XSE
    UPDATE Just heard from C-wheels customer support that they only sell wheels in Canada and will not ship to the US. So my search for 16 inch rims available in the US that will not interfere with the brakes continues.
  20. Blackat
    459
    319
    Colorado
    2023 Prius
    Limited AWD-e
    I got my 16's from TireRack. I'm in Colorado
  21. Wind23
    Wind23 Junior Member
    I think you only need to look for rims size 16x6.5 with 40mm offset and CB 60.1 with 205/65/16 tires should work.
  22. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Not a fan of aftermarket wheels. For a winter set of wheels, we found a set of 16" Camry wheels off a 2012 Camry from a junkyard that seem fit well and clear brakes, suspension etc. Using tire size 205/65/16 diameter and circumference is really close to the factory 19's with 195/50/19...and Camry wheels have same lugnuts, socket etc to get them off. The taller 65 aspect ratio ties on 16" wheels are cheaper than 19" tires and less susceptible to blowouts when hitting potholes etc. Great for winter tires IMHO if you live in a snowy part of the country. We also installed Clone TPMS sensors with Autel so when you seasonally switch wheels no programming needed to pair the sensors to car.
    #40 3prongpaul, Nov 6, 2023
