16 number 2 27000 miles
Discussion in 'Gen 4 Prius Technical Discussion' started by Freddog12345, May 19, 2018.
  1. Freddog12345
    Freddog12345 Junior Member
    Emerson NJ
    My 2016 number 2 has started to make a a loud squeaking noise in the rear passenger area. Sounds like two pieces of plastic or rubbing together. It's worse when I hit bumps. If I'm driving on a flat level Road there's no noise. I just made an appointment with the dealer for next week to check it out. Any ideas out there. I carry nothing in the hatchback.
    Thank you.
  2. krmcg
    2,592
    2,390
    Whittier, CA
    Shock nuts?
    #1
    RCO and Freddog12345 like this.
  3. Freddog12345
    Emerson NJ
    Thank you. I will let the dealer know on Wednesday.
  4. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    Could be the foam rubbing?
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Not the hatchback door?
    If you lay the back seats flat, is it still there - or worse?
    Could something have rolled under the front seats - slide them forward to double check.
  6. Harters
    Harters Active Member
    335
    424
    UK
    Excel
    I have a little squeak from my near side rear quarter panel trim that I cannot get rid off, could It be that?
    On mine its temperature sensitive and above 12oC it doesn't do it. If thought about taking the panel off, but am a bit worried about the airbag and breaking clips.
  7. Freddog12345
    Emerson NJ
    Thanks for the feed back
    Thanks for the update
    I'll check that thanks
    Thanks for the help. I'm glad I joined this site.
    #7 Freddog12345, May 20, 2018
    RCO likes this.
  8. Freddog12345
    Emerson NJ
    Hi
    Just got back from the dealer.
    It's the shock nuts. Should get them tomorrow . Drop off car. Should take about 4-5 hours to repair. Thanks for the info. I told the service advior about what I found on this sight. He looked at me a bit strange.
    RCO, Harters, krmcg and 1 other person like this.
  9. Freddog12345
    Emerson NJ
    Not sure if first response went threw. Parts on order.
    krmcg likes this.
  10. pjm877
    pjm877 Member
    340
    84
    austin, tx
    The PriusChat is a GREAT resource... I remember how LITTLE the Toyota service Dept knew about the Gen 1 2002 (I waited for the Curse Control to be an option before ordering my Prius over the Internet as that was the procedure back then.. them roads are long in Texas) .... I had to watch them like a Hawk.
    pilotgrrl and Raytheeagle like this.
  11. Starship16
    Starship16 Senior Member
    1,348
    1,453
    Beach Christmas
    I still haven't had the rear shock nuts changed out on my 2016. There was a technical service bulletin about that, right?
    If it ain't broke...
    My Prius has never had any of the rattles, clicks, ticks, or squeaks that so many guys have reported. Especially the Prime guys. But maybe all the road noise and tire noise :( drowns out those rattles? :LOL:
  12. krmcg
    2,592
    2,390
    Whittier, CA
    Maybe use a stethoscope to isolate the various noises?
  13. Starship16
    1,348
    1,453
    Beach Christmas
    I'm good. My Prius has never had any of those rattles or squeaks that so many others describe.
  14. Freddog12345
    Emerson NJ
    Road noise won't drown out that noise when the shock nuts get loose.
    pilotgrrl likes this.
