'16 real MPG
Discussion in 'Gen 4 Prius Fuel Economy' started by DieselHybrid, Dec 31, 2015.
  1. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    Another update:
    427.9/8.257 =51.82, Guage read 54.9.
    Still digging it.
    Surferboy likes this.
  2. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Just under 6% off... Kinda like the Gen3's..
    Still amazing mpg!! :)
  3. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Benn awhile, but I thought many reviews showed the displayed mileage being conservative, and people were happy with that. As hey should be.
    So nothing's changed?
    52,855
    conservative meaning displayed lower than actual?
  5. Mendel Leisk
    42,347
    Yeah I think so.
    Wayne Gerdes apparently had one that behaved thus, acurate mpg, and he let drop that it was slated to be crushed in a week or two.
    Maybe they "tweaked" the mpg display for final production models, back to the usual?
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Nice numbers. Best of luck to you. (y)
  7. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I find with Pearl S I can put in over 6 litres more after the fuel filler nossle cuts off. I fill till I see fuel in the fill tube. Here in Edmonton the ambient temp is usually lower than the temp in the ground (where the fuel is stored) so it usually shrinks once in the car.
    Knowing this, I suspect the way you fill the tank is what is making the variation in "accuracy" appear. Again, the Prius IS NOT a "lab instrument", nor do I think you or anyone else could make a fuel economy instrument with repeatable accuracy better than about 10%, due to all the variables. So -I- think Toyota did well, even with the GII and GIII.
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Toyota knew, way back in 2009 with the 2010 Prius, the Prius MPG dash gauge was not accurate yet Toyota even after 7 years fails to correct the problem. This is now intentional adjusting the software to show a display in mpg higher than actual by at least 6% or so.
    I wish someone with authority at Toyota would be addressed on this issue and would at least attempt to give a plausible explanation, though there is none, but as far as I know none have.
  9. Mendel Leisk
    42,347
    It's not a "problem" if it's intentional. Well not for Toyota.
    I get very consistent error, tank-after-tank. Tank filling shenanigans don't make it go away, just run the risk of dumping gas on your first turn when leaving the gas station, or messing up evaporative emission components.
    krmcg likes this.
  10. bisco
    52,855
    i'm not chuffed about it, it is what it is. any vehicle reads diffently at the pump than on the display, and on the window sticker.
    the important thing is that prius leads the way in best overall gas mileage, nothing else matters.
  11. galownia
    galownia Previous master neon mechanic
    117
    73
    How do I get those screens? I've toggled through everything (I thought) and those are not options in my Two Eco.
  12. Y-Zer09
    Y-Zer09 Junior Member
    24
    24
    This was my first tank. I could of gotten 800 miles but I do not want to push the fuel pump. To fill it back up was 10.2 gallons so the mpg gauge is fairly accurate. I think the accuracy depends on how you drive. With the exclusion of one trip where I pushed it in power mode and got 45 mpg for the trip, I drive very moderate and do not go into power range. If you are constantly using power mode and driving inefficiently it will make it more difficult to gauge MPG
    fsu23phd, bisco and Surferboy like this.
  13. Tideland Prius
    16,680
    Remember that each of the menus that you scroll left/right can also scroll up/down.
    To get to the Hybrid System Indicator, scroll to the first menu [the one with the (i)] and then scroll down to the Hybrid System Indicator (it's the 3rd menu I believe after Energy Monitor and Fuel Consumption Record)
  14. krmcg
    2,592
    2,393
    Whittier, CA
    If you had asked me before I got the new car, what MPGs am I expect - I would have said low 60's would be great. Now that I have had the car for two short months, I am actually disappointed that this tank looks to fall short of 70 MPG (tracking to 60.5). Have my expectations gotten out of control?
  15. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    Yes, the expectations are too high. If you get 60 as displayed by the dash and get 55-57 in real life, then that is great. My 2010 said I got about 55-56 mpg averaged over 10,000 miles, and as tracked by fuelly logs, 52.3. So if you get 52.3+5=57.3 in real life, that is a big step up from one generation to the next in my opinion, especially seeing it doesn't have a plug or a much larger battery.
  16. Mendel Leisk
    42,347
    Yes you smug so-and-so. :cautious:
    Kramah313 and krmcg like this.
  17. krmcg
    2,592
    2,393
    Whittier, CA
    First Fill-up 650
    Odometer 650
    Gallons (first click) 10.211
    Calculated MPG 63.66
    MFD display MPG 64.9
    MPG Delta -1.95%
    Gas Light Notification 616
    DTE Reached "Zero" 637
    2 675
    Odometer 1325
    Gallons (first click) 10.605
    Calculated MPG 63.65
    MFD display MPG 67.9
    MPG Delta -6.68%
    Gas Light Notification 610
    DTE Reached "Zero" 650
    3 725
    Odometer 2050
    Gallons (first click) 10.571
    Calculated MPG 68.58
    MFD display MPG 72.4
    MPG Delta -5.57%
    Gas Light Notification 666
    DTE Reached "Zero" 700
    4 671
    Odometer 2721
    Gallons (first click) 10.164
    Calculated MPG 66.02
    MFD display MPG 69.5
    MPG Delta -5.27%
    Gas Light Notification 640
    DTE Reached "Zero" 665
    All-up data:
    Odometer 2750
    Gallons (first click) 41.6
    Calculated MPG 66.2
    MFD display MPG 68.7 average
    MPG Delta -4.87% average
    Gas Light Notification 633.0 average
    DTE Reached "Zero" 663.0 average
    bisco, retired4999, pakitt and 3 others like this.
  18. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Those are excellent MPGs! I am still waiting to hit 550 per tank in my G3. Maybe when it warms up a bit...
    krmcg likes this.
  19. krmcg
    2,592
    2,393
    Whittier, CA
    We don't get much of a winter here in SoCal. Does get into the 40's on the way to work in the morning.
  20. Mendel Leisk
    42,347
    @krmcg: There's a typo in your last entry, post #137: "Gallons (first click) 41.6".
