17 Inch Wheels For Winter Question
Discussion in 'Gen 5 Prius Accessories and Modifications' started by longshot, Oct 19, 2024.
  1. longshot
    longshot Junior Member
    84
    16
    For 2024 XLe. Bought used after market wheels for the winter 17's. The hub centric rings don't seem to fit the wheels properly. Ordered 73.1mm to 60.1mm. It normal for the ring to sit down into there like that?
  2. Eddie F
    Eddie F Junior Member
    27
    Windsor, Canada
    2024 Prius Prime
    SE
    I'm considering 17x7 rims off of Corolla iM 2017 or Scion iM 2016. Center hub is Ø60.1, 4x114.3, +50mm offset.
    What do extra 10mm of offset will do to handling? Also the weight of the rim is 26LBs, which to me is on a heavy side.
    Any thoughts or suggestions would be appreciated.
