17 PRIUS HEADLIGHT GROUNDS LOCATION
Discussion in 'Prius v Technical Discussion' started by batis, Oct 21, 2023.
  1. batis
    batis Junior Member
    Help!
    I need help finding headlight grounds for a prius 17 that go on the passenger side fender held by two 10mm
    both of the cables were ripped by a dog looking for a squirrel. One cable is BROWN held by a 10mm and
    the other cable is WHITE with a Black stripe. I'm having issues with the right blinker staying completely on
    and the headlight blinking when i put the turn signal going right.
    any help if appreciated. I posted pics of current damage. the wiring harness ground that are complete on the pic is from the driver side.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,940
    6,862
    Texas Hill Country
    Is this a 2017 Prius v wagon?
    batis likes this.
  3. batis
    batis Junior Member
    i appoligize i coudn't figure out how to edit my thread but the car is a
    17 PRIUS V
  4. batis
    batis Junior Member
    i tried edit the thread but i couldn't figure how to do it to put the info.
    Anyhow thanks for the diagram but I cannot find the BROWN cable in the wiring harness that goes to fender and back
    towards the car near and around the coolant reservoir. Do you know if in another diagrams if the brown (broken cable on pic)
    connects/taps to another colored cable? please help . TIA
  5. rjparker
    10,940
    6,862
    Texas Hill Country
    You have to know if its a 2017 hatchback or a v wagon as a starting point.
  6. batis
    batis Junior Member
    17 PRIUS V (wagon) do you need a vin?
  7. rjparker
    10,940
    6,862
    Texas Hill Country
    A Prius v is the wagon (lowercase) while a Prius V is a hatchback trim V.
    Assuming you have a v trim 2, 3 or 4 then it’s halogen headlights. A v trim 5 is LED headlights.
    My drawing does not include the DRLs you may have.
    With halogen trace the white black from the sockets back to a junction (probably in the harness right there) where the brown continues to the ground. Or if the dog got the brown I would trace from that direction to the junction pulling off tape or covering on the harness.
