17" tire confussion
Discussion in 'Prius c Accessories and Modifications' started by Priusxrs, May 20, 2013.
  1. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    So Ive had my new/used wheels on my car almost the same miles as the stock steelies now and noticed over a 7000 miles of each I got 1mpg better with the bigger heavier wheels. Granted some of my trips were different here and there but mostly to and from work. I would have though the stock ones would have done leaps and bounds better they are smaller and lighter??? Unless the way the car figures out mpg would have any factor on different tire size I know my speedo is bout 1mpg different with the 17s???
    SGH-T889 ? 2
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You would need to specify the exact tire size you changed to and approximate weather conditions you drove on the stock tires vs. the 17s. I.e. the stock 15s in winter weather may be similar to 17s in warm summer weather...
  3. Priusxrs
    61
    Pa
    205 50 17 had the stocks on sept till mid dec then from mid dec till just now with the 17s but the weather in pa has been crazy so maybe it was something with weather
    SGH-T889 ? 2
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    A 205/50/17 is over 1" larger in diameter than your stock 175/65/15! Your odometer will be way off and your speedo will read slow instead of fast (speedo reads fast from the factory). Interesting you are observing a mpg gain despite the odometer error. Have you kept careful records of your FE on a spreadsheet or Fuelly?
  5. Priusxrs
    61
    Pa
    No it was just from my trip odo. I was keeping track cause i was going to go with lrr 17 tires to see what difference between the 3 to see if it made sence but i have no idea thr best way to measure and i dont know if i really want to lose the grip of non lrr tires
    SGH-T889 ? 2
