17in alloy wheel weight (range)
Discussion in 'Gen 5 Prius Technical Discussion' started by cosmic-ploy, May 7, 2025.
  1. cosmic-ploy
    cosmic-ploy New Member
    some place
    2024 Prius Prime
    the technical discussion seems like the most appropriate place to put this, though the fuel economy or modifications forums could also make sense.
    i, like some others, have been looking into replacing the stock 17in alloy wheels on my 2024 prius prime for aesthetics, weight, and aerodynamics. i could not find any information on the weight of the stock wheels. i called my local dealership and they did not have good information and had to look it up on some parts site, i think discount tire was mentioned. that site listed the weight of the wheels at 28.1lbs. to get a second opinion i called an independent reseller selling some oem wheels and they gave the weight at "about 36lbs".
    i wanted to share this information as i have seen several people here also asking how much the wheels weigh. i would take mine off and weigh them to add another data point, but i do not have a set of wheels to put on in their place, yet. but now that i know where a rough baseline of weight i can make more informed decision about which wheels to replace them with.
    tl;dr - stock oem 17in alloy wheels on the gen5 prius prime weigh somewhere between 28 and 36 lbs.
  2. Mendel Leisk
    42,341
    Nothing stopping you, from taking off one wheel, weighing it (say with a digital luggage scale), deducting the published weight of the tire that's on there. Maybe deduct an additional oz or two, for the valve, tpms sensor and wheel weights. Then put it back on.
  3. ingénieur
    ingénieur Junior Member
    27
    Drummondville
    2001 Prius
    Here are weight from Prius 2023 Premium:
    TOYO EXTENSA II A/S 195/50R19
    Tire:
    Original alloy rim:
    TPMS:
    Total: 48 lbs
    Custom wheels:
    TOYO EXTENSA II A/S 195/60R17
    Tire: 17.2 lbs
    Alloy rim Fast EV01(+): 19.4 lbs
    TPMS:
    Total: 36.6 lbs + TPMS weight
    Prius 2005 original Wheel (Tire and alloy rim): 31 lbs
    #3 ingénieur, May 8, 2025
  4. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    Aftermarket wheels can be lighter. But lighter is not always better.
    Lighter wheels can bend more easily and not take the punishment that an OEM wheel is designed to handle.
    As an example just running over road debris or a pinecone repeatedly and at speed.
    In general though lighter wheels (rim) can improve fuel economy. But I believe the tire compound and contact patch (tire width) has a greater overall effect on fuel economy more than wheel weight.
    Just ride a heavy mountain bike with fat tire versus a road bike with skinny tires and you'll know. You tire so much faster on the mountain bike but you go much faster and more easily on the road bike.
    You can even just swap tires on a road bike frame and feel the difference. Of course no one will do this as its a lot of work and really unnecessary plus very hard to measure scientifically. But you can definitely feel it.
  5. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    The tire width can’t be the main factor because the Prime SE with 17” and the XSE with 19” tires have the same width at 195mm but, there’s almost 10% difference in EV range and fuel economy!
    I am convinced that the total weight of the tire plus wheel has a major impact on fuel economy. The reason is that it takes so much more energy to get the heavier wheels inertia rotating every time you stop or accelerate. Try stopping or starting a merry go round to get a feel for this.
  6. Quovadis007
    Quovadis007 Junior Member
    25
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    50% of people drive a car with under-inflated tires. While this is a much more important factor in consumption than height or width. The weight of higher rims can be partially recovered by regenerative braking.
    1. **Tire width**: Wider tires generally have higher rolling resistance because they have a larger contact area with the road. This increases friction and therefore the energy required to roll the tire.
    2. **Tire pressure**: Under-inflation significantly increases rolling resistance. This is because the tire deforms more while driving, resulting in additional energy loss. A reduction of 0.3 bar can increase rolling resistance by **6%**, while a reduction of **1 bar** can increase resistance by **30%** "1"). Over-inflation, on the other hand, can reduce rolling resistance, but this can come at the expense of grip and comfort.
    **Comparison**: The impact of tire pressure on rolling resistance is generally greater than that of tire width. Incorrect tire pressure can increase rolling resistance by tens of percent, while a wider tire causes a more gradual increase. That's why it's crucial to maintain the correct pressure for optimal performance and fuel efficiency.
  7. Mendel Leisk
    42,341
    The distance between the wheel's mass and axle centre is a factor too. The further out the more effort it takes. 17" have an advantage accordingly.
  8. scotched
    scotched Member
    Encino, CA
    2023 Prius
    If I were in the market to replace my OEM wheels I would definitely be looking for something with less weight rather than more. Unsprung weight makes a HUGE difference on how your suspension reacts to the road. There's always a tradeoff.
    Inertia works both directions, so a wheel that is easier to accelerate will also decelerate quicker. Not sure how this will affect regen braking but I suspect it will be noticeable when you take your foot off the gas.
  9. frodoz737
    frodoz737 Top Wrench
    4,800
    2,560
    33
    I respect that folks want different wheels/tires for different reasons. However, I would suggest the the cost of new wheels will surpass any dollar savings in energy consumption...as it it relates. Just do what makes you happy. ;)
    Quovadis007 and Mendel Leisk like this.
  10. frodoz737
    4,800
    2,560
    33
    Double posting again Mods.
    #10 frodoz737, Jun 2, 2025
  11. ingénieur
    27
    Drummondville
    2001 Prius
    Prius 2023 speedometer is calibrated with 17 inch wheels. I have seen this with an habitual long distance that I was used to do with a Prius 2005. I have confirmed it with Apple Plan. 19 inch wheel circumference is theoretically 1.9% higher than 17 inch. Since MPG is function of distance, display of 1.9% less efficiency with 19 inch wheel can be directly explained by this false calculation. 1.9% could get higher because of 17 inch tire greater flexion that reduces diameter of the wheel and then its practical circumference.
  12. Mendel Leisk
    42,341
    I'll bite: Apple Plan?
  13. PriusTech
    PriusTech Active Member
    264
    133
    Reno
    #13 PriusTech, Jun 29, 2025
  14. cosmic-ploy
    some place
    2024 Prius Prime
    update: finally got around to getting some new wheels and was able to weigh the oem wheels.
    bare with only the balancing weights (no tires, hubcaps, or anything else) weigh 9.2–9.3kg (20.28253lbs) on my bathroom scale.
    for any interested if when with maxxim champ for the look and the weight.
    KMO likes this.
