17Prius phv Knock on Cold Start
Discussion in 'Prime Main Forum (2017-2022)' started by allen7482000, May 24, 2017.
  1. allen7482000
    allen7482000 Junior Member
    taiwan
    Hello everyone
    I am from Taiwan
    My new prius phv Knock on Cold Start
    Will your prius prime do that?
    #1 allen7482000, May 24, 2017
  2. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    like backfire knocking? If the car is backfiring, use higher octane fuel. :eek:
    52,804
    uh, this is disheartening to hear. it is kind of hard to distinguish the sound from the engine running normally.
    i don't think anyone else has reported it yet.
    how often does it happen, and what is outside temp?
  4. stevepea
    stevepea Senior Member
    535
    581
    Welcome!
    I've never heard that knocking on cold start.
    Could it be that there is something for the Taiwan market that might be causing this?
    Can you start another PHV (at the dealer, or someone you know) to see if it does the same thing?
    If not, something may be wrong. What has the dealer said when you played the noise for them?
    Can I ask... does the Taiwanese PHV have two charger ports (like Japanese model) or just one charger port (like US model)?
    Also, your picture of charging at a public charger at night... Is that in Taipei? Kaohsiung? I'm curious how common public chargers are in Taiwan now..
  5. allen7482000
    taiwan
    Hi stevepea
    my english is not good
    I do not quite explain the PHV engine knock it is not happening at every cold start
    the Taiwanese PHV have one J1772 charger port
    J1772 Charging stations in Taiwan have a lot of
    KrPtNk likes this.
  6. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Now we know where all the Blue Magnetism Prius Primes are!
  7. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    Looks like the eastern part of Taiwan toyota
    iPhone ?
  8. stevepea
    535
    581
    I see. Yes, it is difficult if it doesn't happen all the time.
    Sorry, I have not had this noise yet.
    Ah yes, one charger port (like US version).
    Wow, lots of public chargers!
    And I love those pictures of all the Blue PHV cars.
    I can just imagine watching them all drive past, one after the other!
    Sorry I can't help with your problem.
    But I hope it's not serious, and you enjoy the car.
    Welcome here!
  9. bwilson4web
    16,516
    To me it sounds like a power relay closing with an arc. That explains the sharp 'ket-pop.'
    I would try to find out if the sound is coming from the traction battery where there are power relays. The relays should close before the car puts a load on it.
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    Welcome!
    I am fairly new here to but I only have a Hybrid Prius.
    I believe some Prius will knock on startup it previously the engine was turned off before completing its warmup cycle. Other here are much more knowledgeable though.
    Enjoy your new car and fuel savings.
  11. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    My 2010 Prius does that sometimes. It's an ugly sound, but usually just revving the engine a bit gets it to stop, or turning it off and then on again. Maybe the Prime is vulnerable to the same thing. No clue what it really is other than it sound like the timing a VERY off.
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
