185s rather than 195s for snows...?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Coyotefred, Oct 27, 2012.
  1. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    Stock tires on our PiPs are obviously 195/65R15, but I can get a great deal on a set of snow tires in the 185/65R15 size 195s are sold out).
    From what little I've read, switching to the 185s would knock the speedo/odo off slightly (speedo showing 55mph would actually be around 53.8). The tread width would be slightly less which some say improves snow handling since the load per square inch would be greater. Tire height/road clearance would be reduced very slightly, but probably not noticeable.
    'Any thoughts on running 185s pro or con?
  2. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    Narrower Snow tires are Better.
    The 1st number, 185 or 195, is the width of the tire in millimeters.
    How to Read A Tire Sidewall | BFGoodrich Tires
    Narrow Tires
    • Narrow tires[​IMG] act similar to a knife cutting through butter when driving in snowy conditions. The thin surface allows the tires to dig right through the snow to get as close to the ground as possible. According to John C. Dixon, author of "Tires, Suspension and Handling," this allows tread on the tires to take hold and provide the best traction.
    Wide Tires
    • Wide tires act similar to snowshoes during winter driving. The wide surface floats on top of the snow rather than cutting through. This means that the tread on the tires often never has a chance to dig into the snow and take hold for optimum traction.
  3. lensovet
    2,615
    496
    Burlington, NJ
    the speedo is already wrong with the stock tires btw. 1.5 mph too fast seems about right.
  4. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    I didn't realize that...'guess that's another advantage :)
  5. lensovet
    2,615
    496
    Burlington, NJ
    i have yet to drive a car on which the speedo matches GPS speed. i suspect it's for liability reasons.
  6. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
  7. benlevi
    benlevi Junior Member
    Boulder, CO
    Did you end up using 185s? I'm still debating whether to buy snow tires or not... I'm wondering about the traction control being a liability if I stick with the stock tires. I live in CO where we can get icy roads.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The 185s are pretty narrow and usually have a lower load rating. It will work but I don't recommend it. You'll also lose ground clearance because the tires are so much shorter. I'd expect the speedo to read 3mph to high +-. IMO the Prius is too heavy for those little tires.
  9. benlevi
    Boulder, CO
    when it comes to snow, I'd like more ground clearance... I don't suppose 205s are an option...
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    They are. They are quite a bit taller than the OE tire but it's better to go taller than shorter. The X-ice Xi3 comes in a 205/65/15.
  11. Mendel Leisk
    42,358
    Going to the narrower tire would reduce circumference by around 2%. This would directly effect spedometer, odometer and gearing. Not a lot, but not insignificant. As mentioned it would also reduce ground clearance.
    I do not know, maybe not a good idea to impulse shop tire sizes?
    Here's a calculator:
    Tire Size Calculator - Discount Tire Direct
  12. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    That sounds interesting, increasing the ground clearance.
    What are the safety downsides? Less clearance in the wheel well? Would the tire hit the wheel well on a bump?
  13. Coyotefred
    Coyotefred Member
    132
    31
    Western Nebraska
    I ended up going with the stock 195s. So far (which isn't very far) I've been quite impressed.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    There should be plenty of clearance on a stock height car. I have done it so I can't say for sure.
  15. Flying White Dutchman
    4,376
    314
    mmm?? you only go down in width .. that got nothing to do with your speedo??
    or what m i missing here.
    only when you go from 195/65 to 185/60 there wil be a differents in speedo..
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No. The middle number is an aspect ratio (sidewall profile/height) and dependent on the width of the tire. It is simply a percentage of the width. You can't change the width and keep the same aspect ratio without changing the total diameter.
    Tire Tech Information - Tire Size Guide
    HowStuffWorks "How Tires Work"
  17. Flying White Dutchman
    4,376
    314
    so if i want 175 ob my gen 2
    dont care if they are 15 16 or 14 rims.
    what would i need to have.. 175/80/15?
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No. You would need a 175/70/15. Unfortunately they don't have any real tire choices in that size. Why would you want a narrower tire? You may end up with worse fuel economy.
  19. Flying White Dutchman
    4,376
    314
    i was hooping better!!
    wy worse?
    the gen2 base model also got 15inch and better mpg then the 16inch model
    the PIP got also smaller tire size right?
  20. ProximalSuns
    1,877
    PNW
    Hmmm...looking at the tire size guide it says the 205/65/15 is wider not taller, 205 vs 195 tread width. Where is the outside diameter measurement?
