19" wheels easily dented?
Discussion in 'Prime Accessories and Modifications' started by rschlegel, Mar 5, 2023.
  1. rschlegel
    rschlegel Junior Member
    Raleigh, NC
    I am planning to buy the 2023 Prius Prime. I am cautious about getting the fancy, unique wheels in the 19" size. I think that with that size, and the smaller tire size in the vertical dimension, hitting a deep pothole may cause the wheel to dent. Thoughts?
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Don't think it would matter if the design is right, but I would guess a rougher ride.
  3. rschlegel
    Raleigh, NC
    The vertical height of the front tire on a 19" wheel is only about 3 inches when compressed by the weight of the car and engine. I think a deep pothole could press the tire down to the rim and more, resulting in a dented wheel rim.
  4. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    Do not get worried about bent rims or wheels. I've driven for over 15 years on 19in wheels I've driven in pothole prone areas of San Francisco. But I do so at a lower speed. Freeway potholes were unavoidable. There was a really rough area of the freeway around an international Airport in the bay for what seems like 10 to 12 years.
    Your alignment will go off before the wheels get bent.
    Curb rash will be higher as there is less rubber so wheels will be more exposed. But in my opinion, Curb rash should be a thing of the past. All new toyotas should be purchased with parking sensors and the self parallel parking system often puts the vehicle 4 to 8 inches away from any curbs.
    The biggest issue with 19in wheels are tire costs and a harsher ride. But with good suspension, harsh ride is a thing of the past.
    Just enjoy the vehicle 19in or 17in. 17 should be the standard all around in the industry in my opinion.
    Xterra72 likes this.
  5. rschlegel
    Raleigh, NC
    Thats good to know! I agree that 17" will probably give you a better ride, perhaps the best. I am debating whether to buy the SE or XSE, and the wheel size, keys, and seats seem to be the deciding factors.
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    I'm going to believe that Toyota's 19" rims will be made of the strongest materials. That being said, my experience with rims over 17" is exactly what you fear. I constantly had to have front end alignments done. Fractures and cracks happened and then I had to have the cracks welded. Eventually the rims would warp out from the constant beating they would endure. With these new rims, time will tell.
  7. rschlegel
    Raleigh, NC
    I believe both the 17" and 19" wheels will be aluminum. Also, there are actually 3 wheel styles on the 6 various Prius hybrids. It's unclear which styles will be on the 3 Prime trim styles, but they will all likely be aluminum.
  8. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    Actually, I take it back. Tires at 19in and 17in will be cheaper than our old 15in Prius tires.
    I think with a more narrow tire size, it is better on environment and on the amount of rubber used for each tire.
    Used to be 15in were large wheels. But standards improve as the automotive industry matures. Now hybrids are affordable and considered a standard option for all automobiles.
    Just like safety is no longer an option but a standard, I think larger wheels and thus larger tires will actually be cheaper overall on 17 and then on the 19 inch wheels.
    Just my 2 cents.
  9. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    No, larger diameter, low profile tires always cost more than smaller diameter, larger profile tires.
  10. PianoBench
    PianoBench Member
    155
    95
    San Francisco
    What I am saying is the the industry appears to be moving to larger diameter wheels and thus lower profile tires.
    So as more and more vehicles come standard with 17in instead of 15in tires, cost should come down.
    Another thing I have heard is that rubber is becoming more expensive. And with less rubber on larger diameter wheels, larger diameter wheels should eventually drive costs lower.
    Less rubber = cheaper.
    Something about the vast majority of rubber on a tire being unused and wasted is also an concern for the environment. So a larger diameter wheel will have less rubber than a smaller diameter wheel because there is rubber replaced by steel now.
  11. bisco
    52,889
    If that’s true, it’s some time in the future, because the 2023 tire sizes aren’t even available yet.
    It’s a risk to hope or speculate that supply will go up and prices will come down.
    Right now, good 15” tires are pretty cheap
    Merkey likes this.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    YES. Absolutely right.
