195/80R15 Tyres + Front Strut / Rear Coil Spacers
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jcaprani, Dec 17, 2016.
  1. jcaprani
    jcaprani Junior Member
    Fiji
    Hello People,
    This is my first post as I just put a downpayment on a used 2009 Gen III today. It's a JDM import RHD (I live in the South Pacific) with 128k kms (80k miles) on the clock.
    Viewed over 10 different vehicles and there are so many different spec and trim levels for bot Gen II and Gen III. I was very tempted by a 80k kms (50k miles) Gen II but liked the more spacious feel and general refinement of the III.
    I love the drive and features, but the ride height is not ideal for driving out of town. The vehicle has a set of standard 15" prius alloys with 195/65R15 tyres which are 25 inches in diameter and give about 5 inches of ground clearance.
    My daily driver is a 2wd Hilux running on 195/80R15s that are 27.3 inches diameter are excellent for roughly paved, potholed or loose gravel roads.
    I would love to fit the same tyres to my prius but have been informed that they will cause clearance issues and rubbing.
    I have seen these 40mm suspension spacers. If I fit these strut/coil spacers, can the 195/80R15 tyres fit?
    Or, will I also need wheel spacers to make it all go together?
    REAR
    FRONT
    Burna J likes this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,646
    1,669
    Somewhere in Wisconsin
    2013 Chevy Volt
    195sr15's that fit old VWs are pretty rare
    Anyway, most wheel wells are the same diameter throughout so spacing taller but not wider tires wont make any difference, unless of coarse you want the tires outside the fender wells :0
  3. jcaprani
    Fiji
    195R15C(195/80R15) is a very common size in the developing world - cheap and forgiving for rough surfaces.
    I have no interest in wider tyres or 'stancing' my vehicle, just want a little more protection from potholes...
    I understand that increased ride height affects COG and worsens body roll but I am prepared to spend a bit on extra under bracing to counteract this.
    My concern was if increased diameter tyres would cause rubbing issues when turning the front wheels?
    I also understand that effective gearing will be 9.2% higher due to increased tyre diameter, will this create any problems for transmission other than inaccurate Speedo?
  4. Vman455
    Vman455 Senior Member
    537
    553
    The Middle
    I've toyed with this idea too, after doing a little off-roading in Montana and Colorado this summer.
    Body bracing won't "counteract" a suspension modification like this. You'd need stiffer springs and dampers (or, lighten the vehicle, which effectively increases spring rates) to do that. But, I wouldn't worry about that anyway.
    And inaccurate odometer, but shouldn't be any problems otherwise.
    jcaprani likes this.
  5. jcaprani
    Fiji
    Thanks for advice. Have ordered the parts and will do some before after shots when job is complete.
  6. jcaprani
    Fiji
    Hi All,
    My vehicle is a December 2009 JDM Gen 3 Prius RHD fitted with standard 15" rims and 80k miles (128,000 kms) on odometer.
    Ground clearance at purchase was approx 5" on factory coils which is just a little to low to get in my driveway... only found out after I drove it home.
    I fitted my new tyres this morning - 195/80R15s which are labelled as "195R15LT". These are replacing my previous 195/65R15s.
    Fitted tyre width is unchanged, but wheel+tyre overall diameter increases from 25.0" to 27.3 - there is just over 1.1" more sidewall all around.
    Tyre shop guy was sceptical of fit but all was ok. Tightest place was the spats at the rear where there is only 10mm clearance but motion there is up/down only so should be no issues.
    The reason I have done this is that I live in a developing country (Fiji) with awful roads. We regularly have heavy rains too so it's essential to have at least 7" of ground clearance for safe driving.
    After fitting I have 30mm increased ride height which is ideal for clearing local speed bumps (made by idiots), potholes and getting into my driveway.
    I have ordered alu strut spacers for the front and urethane coil spacers for the rear to give me a further 40mm lift which should bring overall clearance to ~7.5" underneath. Safe to go down most gravel tracks when required.
    I understand what I have done will reduce MPG and increase wear on steering and suspension, but it will save me on underbody damage. and things like bushings, tie rods, shocks etc have shorter service lives here anyway.
    I change my oil every 5000kms (3100 miles) due to dusty condiitions. Booked for a transaxle oil change with Toyota WS ATF next week and will repeat every 50,000kms (30,000 miles) after.
    I am not concerned about high speed stability - Fiji national speed limit is 80km/h (50MPH) and my average speed is approx 30km/h (18.5MPH!) as most driving is town and suburban roads.
    Initial impressions after fitting:
    • Negative camber at rear looks a bit more pronounced, will take it for an alignment after coil spacers fitted
    • Ride height more comfortable, bumps in road less harsh
    • Better forward visibility than before
    • Acceleration less than before, may need to use PWR mode more often
    • Steering turn-in a bit more understeery
    • No rubbing on full lock which was my main concern about steering
    • Speedometer is now MORE accurate than before! With the standard tyres it was overestimating speed by about 8%. Tested it this morning using the speed readout safety meter on nearby highway - that reported 39 with 40 on the dashboard. Will test again with GPS soon.
    Overall I am happy so far but will report back on changes to MPG, I was averaging about 19km/l before (44.7 US MPG). My last tank took me 800kms (500miles) and cost FJD$80 (USD$40). Previously had a Pathfinder with 3.3 V6 and a misfire which was getting mid-teens MPG so anything over about 35mpg will make me happy.
    20170107_104807.jpg 20170107_104811.jpg 20170107_104815.jpg 20170107_104820.jpg 20170107_104829.jpg
    #6 jcaprani, Jan 6, 2017
  7. jcaprani
    Fiji
    UPDATE
    I have now fitted the lift kit from (Items in tema4x4 store on eBay!)
    Prius no looks a bit odd with the oversized tyres and large arch gaps.
    There is ~8 inches of clearance under the nose and ~9 inches below the side rails.
    Comfort has improved on (dreadful) local roads.
    Body roll a little worse. I may fit some hubcentric spacers to widen the track a little at some point (5mm front, 10mm rear).
    Overall I am happy and like it, think the practical aspect of having better clearance for the many deep potholes, puddles and gravel tracks here in Fiji is worth it.
    20170307_165313.jpg . 20170307_165315.jpg 20170307_165318.jpg 20170307_165322.jpg 20170309_062734.jpg 20170309_062828.jpg 20170309_062851.jpg
    Burna J, aelkman and RMB like this.
  8. crunchyshad
    crunchyshad New Member
    Palisade, Colorado
    Excellent, do you think those tires would fit my 08 gen II? I get sketch going off road here in Colorado. Also was the spacer install difficult? Thanks for the post.
  9. DangerD
    DangerD New Member
    white salmon wa
    So how did that affect the mileage?
  10. Matt Cope
    Matt Cope Junior Member
    22
    17
    Columbia MO
    Any long term feedback for the spacers? Have you noticed any suspension parts wearing quicker or had any issues since you have had them for two years?
    Dale Denton likes this.
  11. Mendel Leisk
    40,555
    That's a little tricky to answer. To channel "Fiddler on the Roof" a bit:
    On the one hand: bigger tire outside diameter sort-of lowers the "gearing". Which is good for mpg, I think.
    On the other hand: the car is raised, so some more wind resistance.
    On the other hand: the larger tire OD is gonna throw the odometer off, so you would need to add a correction factor.
    CR94 likes this.
  12. Dale Denton
    Dale Denton Junior Member
    23
    34
    San Francisco
    I would love to hear an update on this. I installed the Tema4x4 kit on my 2013 Prius less than a month ago, and the rear passenger spacer already failed! I heard a rattle sound which I installed thought was a loose heat shield. When I got under there I saw the spacer failed and sent the coil into the muffler, resting on the heat shield!
