199.9 or True Average for Total MPG Figuring?
Discussion in 'Prime Fuel Economy & EV Range' started by stevepea, Aug 11, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    If this is a stupid question, please forgive me, but I was wondering... when the car shows the TOTAL MPG from Day 1 (as seen next to the normal Odometer reading), how accurate is it if you've driven a lot of EV miles? For that figure, does the car use "199.9MPG" for the all-EV stretches, or does it instead figure out the total gallons used ever and compare it to the total miles driven? Because "199.9" for EV miles isn't accurate at all for all-EV stretches (you could argue you're getting 1,000,000+ MPG since no gallons of gas is being used -- and MPG is miles per GALLON).
    So let's use this example of driving 1,200 miles (with nice easy figures):
    * You just bought your brand new Prime. It has 0 miles on it.
    * Your first 600 miles are all on gas (no EV), and you manage to get exactly 60 MPG, meaning you've used exactly 10 gallons of gas for those 600 miles.
    * Your next 600 miles are going to be all with EV (no gas used at all).
    So now you have 1,200 miles on your odometer.
    But my question is... when the Prime displays your TOTAL MPG for the life of the car (1,200 at that point), will it show:
    (a) 120.0 MPG (10 total gallons used for the 1,200 total miles you've actually driven)
    or
    (b) some other figure that it gets by adding "60 MPG" for the first 600 miles, and using "199.9 MPG" for all-EV 2nd 600 miles?
    But what if someone instead drove 99% of those 1,200 miles on EV and only 1% using gas? The display would still only show 199.9MPG, when it should be much higher.
    So is it just the DISPLAY that has the 199.9 MPG max limit, or is the car's BRAIN actually using "199.9 MPG" for EV stretches (when figuring out mixed Total MPG for the car)?
    #1 stevepea, Aug 11, 2017
    HPrimeAdvanced likes this.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    Diminishing returns.
    There's little benefit for reported more than 200 miles per gallon.
    It's that simple.
    HPrimeAdvanced and joachimz like this.
    52,464
    just the display. the computer calculates total miles/gallons, a completely irrelevant number. makes toyota feel good i guess.
  4. fuzzy1
    10,603
    For everything prior to the Prime, this has merely been a display limit for US-market cars. This particular problem has a different cap in foreign market units that display kilometers/liter, and doesn't arise at all in the many markets that display liters/100-kilometers. All of them would have the same internal calculations, then just have some local display customization.
    I'd be astounded if the Prime took a great leap backwards by breaking something that was properly handled in prior generations.
    #4 fuzzy1, Aug 11, 2017
  5. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    My ScanGauge says that I get around 1500mpg in engine-off EV glide. I am going to assume that the Prime is the same. The mpg's doesn't come into play when you divide total miles by total gallons. Getting the mileage is pretty straightforward. The gallons are, I believe, retrieved from the digital pump pulses that activate the fuel pump.
  6. stevepea
    535
    581
    Thanks for the answers folks, good to know!
    I've hardly been driving lately (work's slow, and it's the summer) but in a way, having an accurate "Total" MPG (from Day One) keeps driver's honest. On my old Honda, it only had MPG for "Trip A" and "Trip B" which you could reset at anytime, so one could floor it and drive terribly, then reset it as if it never happened. But the Prime remembers all! :)
  7. bisco
    52,464
    great time of year in cali for work slowdown.(y)
  8. stevepea
    535
    581
    I suppose, though work to pay the bills (or to save for a "real" vacation) would be nice. Like most people, without realizing it after a while I rarely bother with what's in my own backyard anymore. People come from all over the world to go to the local beaches nearby, but I never go unless we have out-of-town company visiting (which means I basically go about once every 4-5 years now).
    Actually SoCal is relatively pleasant in June, July, and August. Instead, we get our worst weather in Sept and Oct, when the very hot, dry Santa Ana wind conditions come (along with all the fires that come with it).
    Well, I do have some work on Saturday -- and this time for a change, it's (barely) within the EV range of the Prime... so time to charge it up Friday night!
    HPrimeAdvanced and bisco like this.
  9. Prodigyplace
    12,692
    11,837
    Central Virginia
    It is just display. In fact the split gauge beside the speedometer only goes to 100. The mpg and instant gauge on the center display goes to 199.9 on the Gen 4. I assume the Prime is the same.
  10. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Actually the car can calculate out to just short of 1000 MPG. If you have an Advanced and open the Eco Dashboard in the Prius apps you will see that it goes up to 999. For instance I am one of many people ranked 1st on the dashboard with 312.81 miles at 999.9 MPG. 10 miles of that are actually HV miles not EV miles but since the other 300 are all EV it still calculated out over 1000. So the limitation is in the display not in the vehicles ability to calculate larger numbers.
