1999 Prius Help
Discussion in 'Generation 1 Prius Discussion' started by JohnFromChina, Aug 16, 2020.
  1. JohnFromChina
    JohnFromChina New Member
    Shijiazhuang China
    1999 Prius
    I
    John Here I Have A Prius Black 1999 Now Its yellow as of 2003 With 178754783.5941 KM Or 111,073,073 Miles In USA Terms. My 12V At 12.50V When On And Off At 14.49 I’m In Shijiazhuang China Here’s What The Code Say From My Mechanic. Any Ideas? I was 18 when I got the car back in 1999. It used as taxi car these days. But with COVID-19 now much people want to travel in China.
    P3125 (311) Converter & Inverter Assembly Malfunction
    P3000 (123) HV Battery Malfunction
    P3001 (129) HV Battery ECU Malfunction
    P3004 (132) High Voltage Power Resource Malfunction
    P3006 (123) Battery State-Of-Charge Are Uneven
    P3009 (611) High Voltage Power Short Circuit
    P3026 (123) Battery Block 16 Becomes Weak
    P0AFA (123) Hybrid Battery System Voltage Low
    C1259 (58 150) HV System Regenerative Malfunction
    C1310 (51 156) Malfunction In HV System
    #1 JohnFromChina, Aug 16, 2020
  2. AlexY
    AlexY Member
    163
    45
    UK
    In short high voltage battery need to be replaced or repaired. 99 model does have prismatic cells or this is Japan only model with round cells?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    111 million miles not bad.
    bisco and Rmay635703 like this.
  4. AlexY
    AlexY Member
    163
    45
    UK
    Chinese miles are much shorter. You can see it sometimes when item from Aliexpress comes way too small.
    edthefox5 and WHCSC like this.
