1nz-fe Cam Swap
Discussion in 'Gen 2 Prius Main Forum' started by Toyota Jesus, Jul 8, 2017.
  1. a_gray_prius
    2,927
    783
    IL
    At least drop a couple NOS tanks in the car so that when you do blow the engine (living your life 10 seconds or less at a time), you'll get to experience the floor falling out and your laptop flashing "DANGER TO MANIFOLD"!
    And then you can have the world's first Prius with a built engine.
  2. LamboGuy
    LamboGuy Junior Member
    53
    Hello Jesus, I'm curious if you had any updates since July!
    I have been thinking of getting rid of my car just due to the lack of power and what you did gave me hope!
    Is the engine still running okay?
    Any updates from the shunt capacitor modification? or the inverter voltage increase?
    Did the intake cam go easy, are any things to worry about the swap? Do I need anything else other than a 1NZ-FE cam?
    #22 LamboGuy, Oct 19, 2017
    SFO and Justdidit like this.
  3. Toyota Jesus
    Toyota Jesus Junior Member
    Niagara Falls
    Will be coming out with some updates soon. I haven't had a ton of spare time but what I have been working on is a lithium add-on to increase the available current from the battery. In short, I have a bunch of lithium batteries that will convert the car into a limited plug-in hybrid. By increasing the available current, they will enable me to modify the inverter to draw more current.
    As for the reliability side of things, Ive put a few thousand kilometers on the car and it is still running strong. The power gains are quite variable. Sometimes it seems really fast and other times it seems bogged down. Guess it depends on the battery temperature and all that.
    The cams are fairly easy to swap. Only hard part is reaching down on the left side of the motor and releasing the timing chain tensioner. But you can do that with an Allen key.
    offib, LamboGuy, SFO and 1 other person like this.
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Did you ever find an ODB cable for use with Techstream?
    If you can find one of those three dollar ($3) Elm237 bluetooth adapters (and a copy or Torque) you can manually increase the fan speed, which should help all around -boosted or not.
    If you can't locate one I would be happy to buy one and have it shipped to you.
  5. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Been a few months (and a new year), anything else worth sharing?
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    I highly respect your investigative work!
    way2coolwheels likes this.
  7. way2coolwheels
    39
    42
    Great thread. I've read up a little on the differences between the 1NZFE and the 1NZFXE and it appears cam timing is the main difference. I wonder if anyone has swapped the entire engine: installed the 1NZFE into a prius. My engine is quite worn out, drinks about a quart of oil every 300 miles. If I need to put a newer or rebuilt engine in it, just wondering if it would be worth my while to drop in the Echo engine.
    SFO likes this.
  8. LamboGuy
    53
    I’m also interested in this and I’ve been very curious why nobody hasn’t done this yet!
    I’m saying this because it makes sense to swap for an Echo engine since it’s the same motor running Otto cycle!
    FYI the Prius motor has different pistons to achieve higher compression which could be a bit dangerous (risk of having detonation) if you use the Echo cam but using the entire Echo engine should be safe since it has been tuned to be working with 87 octane gas.
    What I don’t know is
    1) If the engine harness/sensors are the same or not
    2) How well the Echo engine will perform if the Echo ECU doesn’t get transferred and it’s basically working on the (“simulated” Atkinson cycle) Prius ECU
    Sotirakis and SFO like this.
  9. way2coolwheels
    39
    42
    A couple of commentors on this thread mentioned the pistons and rings. I went to an on-line Toyota parts resource and found that the Yaris, Echo and Prius all used the same pistons, rings and crankshaft. The engine block shows a different part number, as well as (expected) the cam shafts. So the increase in compression shouldn't effect the mechanical components. I do wonder, however, if the motor/gen that starts the engine has to work a little harder to crank it.
  10. way2coolwheels
    39
    42
    Okay, I found an engine with 100K miles on it at a great price. I ordered it, on it's way. This will solve my excessive oil consumption problem. Then, imI going to follow your lead, I already have a Yaris intake cam ready to go in when the "new" engine arrives. This will solve my lack of power on long upgrades problem (I hope). I'll be sure to share my results on this forum.
    Aaron Vitolins likes this.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    When the Prius set a land speed record, they used an entire Echo engine, not just the cams.
    Got Hybrid?
  12. way2coolwheels
    39
    42
    Interesting. From what I found by looking at part numbers, most of the components are the same. However, the engine block has a different part number. I wonder what the difference is.
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I seem to recall that the Prius block has the bores centered over the power stroke, while the Otto block has them centered over the bearings.
    m.wynn and way2coolwheels like this.
  14. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    From all that i've read, easiest would be to do just a full 1NZ-FE head swap but all you need to swap is the exhaust cam to really raise your static compression. I looked this up a while back before i looked at my turbo kit. Here are the differences and similarities.
    List of Different Parts:
    • Crankshaft:
      • 1NZ-FE: 13401-21020
      • 1NZ-FXE: 13401-21040
    • Cam 1:
      • 1NZ-FE:13502-21031
      • 1NZ-FXE: 13502-21021
    • Cam 2:
      • 1NZ-FE:13501-21030
      • 1NZ-FXE: 13501-2106
    • Cam Gear:
      • 1NZ-FE: 13050-21041
      • 1NZ-FXE: 13050-21051
    • Rings:
      • 1NZ-FE: 13011-21041
      • 1NZ-FXE: 13011-21100
    • Pistons:
      • 1NZ-FE: 13101-21070
      • 1NZ-FXE: 13101-21110
    • Valve Springs:
      • 1NZ-FE: 90905-01049
      • 1NZ-FXE: 90501-23135
    List of parts that ARE the same...
    • Sprocket:
      • 1NZ-FXE: 13050-21041
    • Timing Chain:
      • 1NZ-FE: 13506-21050
      • 1NZ-FXE: 13506-21050
    • Rods:
      • 1NZ-FE: 13201-29735
      • 1NZ-FXE: 13201-29735
    • Bearings: all three SAME
      • 13041-21022-01
      • 13041-21022-02
      • 13041-21022-03
    • Cylinder Head:
      • 1NZ-FE: 11101-21062
      • 1NZ-FXE: 11101-21062
    • Engine Block:
      • 1NZ-FE: 11401-29856
      • 1NZ-FXE: 11401-29856
    • Valves Seals:
      • 1NZ-FE: 90913-02092
      • 1NZ-FXE: 90913-02092
    • Intake Valves:
      • 1NZ-FE: 13711-21010
      • 1NZ-FXE: 13711-21010
    • Exhaust Valves:
      • 1NZ-FE: 13715-21010
      • 1NZ-FXE: 13715-21010
  15. way2coolwheels
    39
    42
    Great picture! It tells all, there is more than just valve timing in the design.
  16. way2coolwheels
    39
    42
    I also noticed that the fuel injectors are a different part number between the Yaris and the Prius. I ordered a set of the Yaris injectors because it seems to me that with the Yaris cam and a higher compression, there will be more air. Therefore to keep up with the optimum air/fuel ration, more fuel will be required. I'll run with the cam and injectors and see what happens.
    m.wynn and Justdidit like this.
  17. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Cool - keep us posted. Would be awesome to have dyno results but i know thats $50-$100 for 3 pulls from most dyno shops.
  18. way2coolwheels
    39
    42
    I doubt I will put it on a dyno. I will, however, be driving long distances which include long upgrades, typically where the stock drivetrain underperforms. That's where I'll be able really tell the difference.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I have never had that issue since I quit driving a Mazda GLC.
  20. way2coolwheels
    39
    42
    Interesting. When I looked up the pistons the other day, I could have sworn they were the same. Not sure where I slipped up, so I rechecked and you are absolutely right. Hmmm
