1nz-fe Cam Swap
Discussion in 'Gen 2 Prius Main Forum' started by Toyota Jesus, Jul 8, 2017.
  1. way2coolwheels
    39
    42
    Crusty from road salt, but low miles!
  2. way2coolwheels
    39
    42
    So the engine is a bit crusty from road salt, but was cheap and has low miles. Getting it ready, installing the cam and injectors tomorrow. Hopefully I'll do the swap this weekend. IMG_20180822_182859722.jpg
    m.wynn and Raytheeagle like this.
  3. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I remembered I had done something similar when I rebuilt a 2008 Prius some two years ago.
    I had to swapped the complete pistons from a Toyota Yaris, and for new piston rings installed when I was done rebuilding.
    Got massive power, and better economy too.
    PS: I think swapping the cams and even crankshafts have being done. I can't remember where now. Appears to be maybe one the Latin American or Asian countries.
    way2coolwheels likes this.
  4. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I'd suggests, you replaced the pistons and rings at same time since you did the can stuff. Stress on the pistons and rings maybe too much
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I'm interested in this! If thecaos are that rated as you've posted, I'm thinking the inverter can handle, say for instance, a highlander modified pack(9.6V @6500mAh).
    Please when you're done, let us know how you fared with the backup generator
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Your fuel economy in this regard, would be affected, if you drop in an Otto's engine in there(1nz-fe).
  7. way2coolwheels
    39
    42
    Comparison of the Yaris and Prius cams. BIG difference in the cam lobes! IMG_20180823_180137987.jpg
  8. way2coolwheels
    39
    42
    I got the Yaris cam installed, but it won't quite rotate. I believe that the cam followers are pumped up and won't allow the slightly higher lift lobes rotate. Toyota Jesus, did you have to bleed down your followers?
    Justdidit likes this.
  9. Patrick Wong
    18,210
    6,517
    The 1NZ-FXE engine doesn’t have hydraulic valve lifters...
  10. way2coolwheels
    39
    42
    Hmm..... I guess I'm back to square one. I suppose those that successfully swapped cams had enough valvetrain wear to accommodate the higher lift. I guess I've got to run the stock cam.
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Both cams won't rotate? What if you only swapped the exhaust cam... it's the only one you really need to have otto cycle.
  12. way2coolwheels
    39
    42
    Not according to my research. The Miller cycle delays the closing of the intake valves, not the exhaust valves.
    #52 way2coolwheels, Aug 24, 2018
  13. LamboGuy
    LamboGuy Junior Member
    53
    Can you swap the whole engine for one coming from an Echo and then just transfer the Prius electronics?
    iPhone ?
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    That is what the Land Speed Record folks did on the Gen 2. (Among several other mods)
  15. LamboGuy
    53
    True, but this was more of science project, backed up by tons of engineers. I’m curious if a regular shade tree mechanic can just swap the motor and keep the old electronics or if there are sensors and plugs that are not compatible - otherwise I don’t see why people haven’t tried it yet...
    iPhone ?
  16. Patrick Wong
    18,210
    6,517
    Which cam has the interference: intake, exhaust or both?
    If only one camshaft, replace some or all of the 8 valve lifters. They come in various sizes so that you can adjust the clearance between the intake camshaft lobes and the valve lifters. The intake valve clearance is supposed to be 0.007" to 0.009". Exhaust is 0.011" to 0.013".
    If both camshafts have interference then you would potentially have to replace 16 valve lifters. But maybe the lifters originally installed on the exhaust side might work on the intake side?
    Also you could try the lifters from your old engine which potentially might be usable if they are shorter vs. the lifters from the replacement engine. If you have 32 lifters to choose from maybe you don't have to buy that many new ones.
    The lifters are available in 35 sizes in increments of 0.020 mm (0.0008 in.), from 5.060 mm (0.1992 in.) to 5.740 mm (0.2260 in.)
    #56 Patrick Wong, Aug 25, 2018
    way2coolwheels and Raytheeagle like this.
  17. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It has to be cheaper to just buy an Echo than to cripple your Prius into one.
  18. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Or just do a echo head swap?
    SM-G870W ?
  19. LamboGuy
    53
    Clearly but there are a lot of people who need to replace their engine due to high oil consumption - why don’t they put one from an echo instead of another Prius if it’s plug an play?
    iPhone ?
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    35 MPG would be the big reason.
