1st Electric Bill after getting Prime...
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Jun 6, 2017.
  1. stevepea
    stevepea Senior Member
    535
    581
    Wow, shows what a difference in rates there are across the country. Every time I see the "12c/kwh" average US electricity cost listed somewhere, I have to remember to add a lot more, for our (cheapest) tier of 16c. Then just the middle tier is 25c (and the upper tier for heavy users is... I forget). Luckily I don't have or need A/C where I live (just ceiling fans are good enough), otherwise I suspect I'd definitely be in the middle tier in the summers...
    HPrimeAdvanced likes this.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Depends where in California you live; the northern part of the state seems to be really getting the shaft, particularly in housing and utilities, compared to here in Anaheim, in the south. We're in the slummy area but stuff IS cheaper down here. My kid's house, same size as mine, but he's in Huntington Beach, 12 miles away, cost him $100k more than mine, and mine is VERY nice. I guess slummy is good!!, Har, har!
    stevepea and Prius from Dad like this.
  3. Toyotaisme
    Toyotaisme Junior Member
    24
    67
    Glendora
    I changed my bill to the SCE to Time-of-use plan and its actually saving me money. Last year 2016 in May my bill was $330.37 2017 with car plunging in once a day a night is now $101 savings. Last June my bill was $409 this year 15 day in my projected bill is $309 that will be another $100 savings. so far so good.
    joachimz and HPrimeAdvanced like this.
  4. Jordango
    Jordango Junior Member
    Huntington Beach, CA
    My costs appear to have gone up about $1 per day. I've had the Prime for about five weeks and I've only filled up once. Seems like it's worth it. I'm also in SoCal.
  5. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    My billing for May was higher than last year at May but I have used the AC earlier this year in the house. So hard to judge . But love the car either way.
  6. SaraBBrown94
    SaraBBrown94 Active Member
    234
    263
    Pittsburgh PA
    I turned the a/c on and plugged the car in. :D
    Western PA 8cents/Kwh
    #26 SaraBBrown94, Jun 7, 2017
  7. bwilson4web
    16,512
    Long time, PiP owner @bisco has a similar problem in Boston. So I developed this formula for the electric mode cost per gallon:
    A simple formula gives the EV equivalent to the local gasoline cost:
    $EV/gal = (MPG/100) * $/kWh * kWh_per_100mi
    So this is what three popular, plug-in hybrids would cost in Huntsville, $0.10/kWh:
    • $1.13/gal - 2014 BMW i3-REX
    • $1.30/gal - 2017 Chevy Volt
    • $1.35/gal - 2017 Toyota Prius Prime
    • $2.76/gal - 2012 Toyota Plug-in PiP ($0.19/kWh)
    • $1.45/gal - 2012 Toyota Plug-in PiP ($0.10/kWh)
    "Driving around town in a Prime is like buying gas at $1.35/gal."​
    So let's use Prime and San Francisco electrical rates:
    • ~$2.16/EVgal = (54/100) * $0.16/kWh * 25kWh/100mi (average)
    • ~$2.84/EVgal = (54/100) * $0.21/kWh * 25kWh/100mi (April 2017)
    Now if your electrical rate is higher than $0.16/kWh, the cost to operate the car goes up which I understand is the case with residential users. My most recent Google reference claims "20.4 cents per kilowatt hour". So I did the calculation twice.
    You might check this PG&E page on residential rates: Rate Plan Options
    • Tiered Base Plan
    • Time-of-Use Plans
    • Electric Vehicle Base Plan
    Good luck!
    #27 bwilson4web, Jun 7, 2017
  8. markabele
    5,084
    1,782
    Nebraska
    Yep, and we see dirt cheap electricity rates around here. Good to know it's decently clean already and getting cleaner by the day.
  9. stevepea
    535
    581
    While everyone's rates differ across the country (and with various utils), the TOU plans generally favor heavy users. If you charge a Bolt or Tesla (or your Prime every day) and have specific loads/tasks that you can do it at night, it might pay to look at a TOU plan. But for light users (who don't have many specific high loads, but use just a bit of electricity 24hrs a day) the TOU plan often winds up costing a lot more (because of the much higher on-peak prices than the normal non-TOU plans). As I said, everyone's usage is different, and everyone has to do their own math.
    For instance, regarding Toyotaisme's average monthly bills between $300-$400... a user like that might indeed find a TOU plan helpful. Mine for the last few years have averaged around $18/month -- and are now about $28/month with the Prime. But of course it's just me (1 person), I have no A/C (don't need it, as I live closer to the water), have energy-saving stuff like LED lights everywhere, don't put anything on unless I'm in that room, etc. Everyone's needs are different.
    Bob, I like that formula you used. I also like how you use 25kw/100miles for the Prime (= 4 miles per kw). I know others can make their car display 6 or 7 miles per kw, but usually only by using EV mode only in favorable situations (ie, lots of downhill stretches) and then putting it in HV mode for the more strenuous situations, like going uphill (where the worsening numbers won't show in EV, but rather in the gas consumption). I'm not saying this is right or wrong efficiency-wise, but it skews the results, as all one is doing is putting the bad results into the "gas" column instead of the "EV" column. So I like you using the 4.0 number... that's quite a reasonable number.
    When I first got my car (it had 40 miles on it) the display showed 5.0 miles/kw. It's now down to 4.9 miles/kw -- and will no doubt lower more in time as I drive it more. My May driving was 4.8 and for June (so far) it goes between 4.7 to 4.8 (and that's being reeeeeally gentle). The more one uses the EV for higher-speed freeway driving, the more it will drop... so just for myself, I tend to use 4 to 4.5 (at the most) when figuring the math, as anything higher than 4.5 is either being super-careful or not indicative of normal, mixed, various driving conditions. (Again, you could "make" your EV numbers higher, but only by shifting the more strenuous driving situations to HV, which means using more gas).
    audiodave likes this.
  10. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    My May bill was considerably lower this year due to it being cooler in Connecticut and no a/c was required in the house.
  11. Silent Propulsion
    42
    45
    Lake Havasu City Az
    My plan/dream was to add solar to my house, which came online late last august and then acquire a plug in prius (the prime name wasn't known at the time of solar signing). Two weeks ago i took delivery of a blue magnetism advanced prime. I plug it in mostly in the morning after 730 when my panels begin to produce. My drive to work is 3.5 miles one way and down hill all the way to work. As far as my electric bill goes.... it is now only a meter read fee of $21. And my solar lease is $138 a month for 20 years. I currently produce 120% to 300% of my needs. So my prime hasn't effected me very much if at all.
  12. bwilson4web
    16,512
    This highlights the irony of home solar cells. Unless there is a storage system, the actual EV charging comes from the grid. This is not a bad thing as so much of the base has to run at night anyway. Just a better solution would be solar cells in the parking lot at work or other day time destinations like restaurants or shopping areas.
  13. Ed From Syracuse
    Ed From Syracuse Junior Member
    28
    35
    Syracuse
    My bill for charging daily is.07 to .09 cent per kilowatt. Comes to about .0594 to charge it one full charge. So for only charging once a day for 30 days comes 17.82 or less. That fluctuate sometimes it's only $14 a month sometimes it is $17 depending on the amount of days and how often I charge it. But even said that is still a very cheap price to pay for. I live in Upstate New York.
  14. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    WOW... we should be "In Like Flint" then, when ours gets here. I'm retired - so no daily commute - and I anticipate charging ours only 12 to 20 times per month... probably RARELY from a "zero" SOC... AND at only about .10/kWh OR .06/kWh, depending on kWh usage so far within any given billing cycle when it's plugged in.
    And HOPEFULLY by September, our Prime will get its at-home charges "courtesy" of sunlight, as we'll be going solar soon....
  15. Son of Gloin
    421
    320
    Lafayette, IN
    Huh? The charging would "come from the grid" even if the residential solar cells are "producing" more energy than the residence (on the whole... with the car getting charged) is using at the time? And... why would using "solar cells in the parking lot at work or other day time destinations" be a better solution? Wouldn't such places also involve charging "from the grid"?
    Sorry, but other than your mention of "a storage system", I'm simply not following / understanding what you're saying here....
  16. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I believe that what Uncle Bob is getting at, is that during the day the excess electricity from your solar panels is being sent to the grid, if you don't have a storage system to store your electricity on site. Meanwhile your car is probably sitting in a parking lot at your work where it could be getting electricity from solar panels if those existed at your work. For most people who have solar panels, the electricity they use to charge at night actually comes back from the grid, not from their solar panels. Yes you did send electricity to the grid, and that electricity is now coming back to you. To my way of thinking though, I think you should have storage on site where you could get electricity you actually generated from the sun back into your car and of course to your home appliances. The on-site storage is particularly important to me, in the event of an earthquake or other major disaster in our area, I would rather have the electricity stored at my house, and not have to rely on a possibly broken grid. Unfortunately at this time, on-site storage of electricity is extremely expensive, and not offered very frequently by the installers in my area.
  17. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
  18. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    I must live in the most expensive place for electricity. My cheapest rate (SDG&E) is 0.19 per kwhr.
  19. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
  20. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    California, with its environmental and leftist agenda, is about the most expensive for power in the US. We also have the most expensive gasoline.
    N.J.PRIUS and HPrimeAdvanced like this.
