1st Electric Bill after getting Prime...
Discussion in 'Prime Main Forum (2017-2022)' started by stevepea, Jun 6, 2017.
  1. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Thank God for environmentalists!!!
    As far as prices, it's really not that bad here in my area. Anaheim really has good rates and incentives for its residents; hell, they even give us free trees! You gotta pay to play in the best place in the world. I just wish the state would do more advertising on how terrible our earthquake problem is out here!! That way we can keep paradise to ourselves!. The rain has really blessed us this year!
    joachimz and Prius from Dad like this.
  2. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    The Paris climate accord is just not good enough.:D
    California remains well ahead of this and intends to stay a leader. Electricity/Energy prices are high, so many put up residential solar which just ends up making California even greener.
  3. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    True, yet California offers no solar tax incentives. In fact, my property taxes are going to go up because the County Tax Assessor notified me that I have to declare my recently installed solar system as an improvement, which will raise my home's assessed value.
    Hypocritical Governor Brown comes across as an environmentalist, yet he is the force behind the twin tunnel water project that will take away a huge amount of fresh water flowing through the Delta, causing a lot of harm to an ecosystem that is already in distress. This has been confirmed by an independent review conducted by the National Academy of Sciences.
    Without NEM metering (which the power companies want to do away with), residential solar would be dead in California like what happened in Nevada and Hawaii and Arizona.
    #43 MikeDee, Jun 10, 2017
  4. bresna
    bresna Active Member
    193
    144
    Southern Maine
    I'm happy that my local utility's rate is only $0.06/kWh. :)
  5. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    Our kWh rate "starts" at $0.093 (for the first 300 kWh in any given billing cycle) and then "drops" to $0.054.
    BUT... silly dude that I am :confused:, I think about it like this: TOTAL amount due divided by kWh usage equals "actual" cost / kWh. As an example, our last bill came to $85.83 for 643 kWh usage... or $0.133 / kWh. It will be interesting (to say the least) to see how all this (each bill's "fine print") changes once we get our solar installed / up'n'running (which will probably be no later than mid-September)....
  6. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    That's how I calculate my cost. So with your $0.133/kWh x 6.3 kWh/charge your cost per charge is about $0.838. Until you get your solar.:)
    HPrimeAdvanced likes this.
  7. markabele
    5,084
    1,782
    Nebraska
    Wouldn't you hit 300 kWh in a month even without your car charging? If that is the case it may not be fair to consider the car charging cost as a fraction of the whole. May be more accurate to use the cheaper tier.
  8. BlacksmithTB
    BlacksmithTB Junior Member
    Portland OR
    I will have to see how it plays out over the whole year - I have 4.8kW of solar on my roof, and my house is so efficient that I have conssitently been giving power back to the grid, since I can't roll credit over from one year to the next (in Oregon, so I make most of my power from June to Sept). Right now charging a couple of times a week I am still net positive, but in the winter that isn't true at all. Still, I'm optimistic (and I ride my bike a lot...).
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Interesting, under President Carter I worked with a special electric group persuing solar, electric vehicles. Of course the batteries at that time were lead and really inefficient. Required a insane amount of maintenance, basically checking for bad or low charged cells, the Motor Pool wasn't up to this level of maintenance. The person wiring up the charger did not even have a multi-meter. I had thought the AF might be more sensible on
    EV charging now, bring the question up to base HQ. They may agree.
  10. Andyprius1
    2,327
    859
    Cool CA
    Only certain areas, SF, LA. I'm using TOU thru SMUD, .075 for 1 Kwhr, my small solar array puts out 10- 12 Kwhrs per day. I only pay the monthly basic service charge now $20.00 I expect to have a credit by Oct ( solar panels birthday) Unless Summer AC wipes me out. So far, it looks like Summers been CX.
    As for DMV I agree CAs the worst. CA Government and Jerry Brown thinks every bodies RICH.
  11. Lithium MPG
    Lithium MPG Junior Member
    27
    27
    Inland Empire
    2013 Prius Plug-in
    12 cents kwh is living the dream! SCE is 19 cent per kwh in tier 1 here in the Inland Empire
  12. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Ouch! Yeah I noticed that Anaheim Utilities charges less than many. Our tier 2 jumps to $0.197 from the tier 1 of $0.12, after 310 KW, unless you have a medical condition requiring A/C.
    Lithium MPG likes this.
  13. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    It appears that I'm a lying sack.... Either that, or I'm misinformed. In spite of the public (pubic?) humiliation I must correct my earlier statements vis a vis the electric rates charged here in Anaheim. . It appears that I do pay $0.12 1st tier, to 540 KW, then $0.19 thereafter for summer usage. However this is only because I've been declared physically decrepit by my cardiologist, and needful of A/C to stay relatively healthy, here in toasty Anaheim (we are expecting 100 degrees or so this weekend, and it ain't even summer yet!!), so A/C is vital. .
    Sorry for my ignorance and faut pas!!
    I'm not worthy, I'm not worthy!!
    Andyprius1, Bri-n-TX and Lithium MPG like this.
  14. Riversong
    Riversong Junior Member
    28
    48
    Amsterdam NY
    6 cents per kWh where I am!
    Lithium MPG and Prius from Dad like this.
  15. Son of Gloin
    421
    320
    Lafayette, IN
    Hmmm... I'm strongly leaning toward disagreeing with you when you say: "May be more accurate to use the cheaper tier." (The $0.054 / kWh as opposed to $0.093 / kWh). That's because that $0.054 / kWh doesn't come into play during any given month (billing cycle) until AFTER the first 300 kWh for that month have been "consumed". SO... since I'll probably be charging the car every-other day or so throughout the billing cycle, roughly half of these car-charging cycles will be costing me the $0.093 / kWh. I'd rather estimate the charging costs toward the "high side" (TOTAL bill amount divided by TOTAL kWh usage) than strive for absolute accuracy.
    Xterra72 and Prius from Dad like this.
  16. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    I totally agree. I charge about 24 times a month and from my bill I can't tell when I charged. So from this month's bill $145.50 / 997 kWh = $0.1459. and $0.1459 x 6.3 kWh per charge = $0.919 per charge for me.
  17. Nancy S
    Nancy S Member
    53
    60
    Chandler, AZ
    .06 KWh between 11pm and 5 am is the best it gets if you are part of the EV program here for SRP(Salt River Project) Co. Between our Prime, Leaf our 3 A/C units, pool pump and expected highs next week of 120 degrees, I expect something's going to either blow or melt! still I bet the monthly bill won't be over $400:cool:.
  18. markabele
    5,084
    1,782
    Nebraska
    How many kWh's did you average in a month before you started charging a Plug In? Or, put a different way, how many kWh's do you currently use if you don't count your Plug In amounts?
    Son of Gloin likes this.
  19. Andyprius1
    2,327
    859
    Cool CA
    (faux pas)
  20. Ducky
    Ducky Member
    33
    South Shore, MA
    For both your supply and your delivery charges?! That's incredible! Mine:
    Supply charge: .09432/kwh
    Delivery charges -
    Distribution charge: .06236/kwh
    Transition charge: .00054/kwh
    Transmission charge: .03056/kwh
    Energy efficiency charge: .02083/kwh
    Renewable energy charge: .0005/kwh
    Total: .2091/kwh And we're only a couple of cents above our lowest cost of the past few years. It'll get worse when winter returns.
    If I've done my math right, it works out to $1.33 per full EV 6.3 kwh charge. If that takes me 25 miles, that's 5.3 cents per mile. Typical ICE compact sedan getting 30 MPG is paying 7.7 cents per mile right now (we're at $2.31/gal), so at least I'm not that, but hybrid engine getting 54 mpg runs at 4.3 cents per mile. I run in EV mode as much as I can to reduce emissions, but I sure wish my short-term financial incentive better aligned with the long-term societal one... I am green with envy at the degree to which your incentives do!
