1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
1st surf trip results
Discussion in 'Gen 2 Prius Fuel Economy' started by jgills240, Mar 19, 2007.
  1. jgills240
    jgills240 Member
    190
    Palmdale, CA
    So, against the advice of the brilliant minds at the Toyota dealership, I installed a roof mounted rack on my Prius, and this weekend was my first opportunity to give it the true test. I loaded up 3 surfboards on the roof, 3 people in the car, and another 150 or so pounds of gear. With all that hanging out in the breeze, after 330 miles I read 39.2 MPG, and after 700 miles I was sitting at 38.2 MPG. Sure, this is much lower than the 47+ MPG I got last time i made the exact same trip without racks on the car, but it blows my old Subaru Outback out of the water, and that's with nothing on it! Put some form drag on the Outback and see what MPG you get, nowhere near 38! I'd use 14 Gallons in the Subaru at just under 300 miles.
    Final result: success! Prius still dominates any other car with a load on its ultra-aerodynamics! WEEHW! :D
  2. pkittie
    pkittie Junior Member
    50
    LaLa Land
    <div class='quotetop'>QUOTE(jgills240 @ Mar 18 2007, 11:54 PM) [snapback]408256[/snapback]</div>
    Hey, what brand roof rack did you use?
  3. jgills240
    jgills240 Member
    190
    Palmdale, CA
    [​IMG] [​IMG]
    I used the Thule system cause I already had all the attachments from my other car, but Yakima also has an identical system, but with round crossbars.
  4. pkittie
    50
    LaLa Land
    Cool beans! Been shopping around for a roof rack for the boards-I've seen only one other Prius with a roof rack, and it was the soft bar strappy system.
  5. Silver_Prius_2006
    Silver_Prius_2006 Junior Member
    <div class='quotetop'>QUOTE(pkittie @ Mar 27 2007, 08:28 PM) [snapback]413303[/snapback]</div>
    What roof rack did you ultimately decide on? And how has it worked out?
    I'm in the market for a rack system right now. Would like something that can pop off relatively easy and doesn't require me to bolt anything to the roof. Also need one for a longboard. Thanks!
Loading...
