2.25 ton Jack Stand Clarifications
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ThatOddMan, Sep 10, 2019.
  1. ThatOddMan
    ThatOddMan Junior Member
    64
    25
    Alhambra, CA
    Does it mean 1 jack stand has a capacity to hold the weight of 2.25 tons?
    Or does it mean 2 jack stands have a total holding capacity of 2.25 or total of 4.50 tons?
    The nearest auto shop only has the 2.25 low profile lift and jack stand as a set; no ramps in store. I will just need to install the rear sway bar, reason I ask.
    Thank you.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    It's a common question. It means that together they can hold 2.25 tons.
    Raytheeagle likes this.
  3. Leadfoot J. McCoalroller
    8,280
    7,791
    Pennsylvania
    2018 Prius c
    ^ What Pluggo said. It’s an extension of the thought that jackstands must always be used in pairs. Lift the front, the back, or the whole car. Each pair of stands is good for the printed rating.
