2 Battery Questions
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Aqua Vitae, Apr 2, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    What ?? Where did you pull that statement out of ??
    I believe the "book" specifically says that it is perfectly OK to leave it plugged in after it's fully charged..........every night.
    Yes.
    We want you to back up the statement that you made.......or admit that you made a mistake.
    Giving erroneous advice seems to happen much too often with you.
    #21 Easy Rider 2, Apr 7, 2015
    52,863
    point is, you shouldn't charge it when you get home, and leave it charged all night. doesn't matter if you leave it plugged in after it's finished charging. not a mistake, you simply misinterpret me.
  3. Easy Rider 2
    1,584
    258
    Ocala, FL
    You are just digging the hole deeper.
    That is bunk too.
    The system will only charge it to a point that the designers have determined is OK........and then it stops.
    Your statement is absolutely WRONG.
    I misinterpret nothing.
    52,863
    again, it's not about over charging, it's about leaving it all night with a full charge. that's why they installed a timer. i'm running out of ways to explain it.
  5. Easy Rider 2
    1,584
    258
    Ocala, FL
    They installed a timer so you could charge it when the electric rates are the lowest.
    You said nothing about using the timer in your other posts.
    You still haven't sited the page in the owners manual that explains why the timer is there.
    Please do.
  6. bisco
    52,863
    how do you know that?
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    From the manual.
    Use the charging timer function as much as possible in order to fully charge the hybrid battery (traction battery) immediately before starting off.
  8. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    No, but a citation to support an assertion is always appreciated. :)
  9. bisco
    52,863
    see post #27.;)
  10. Easy Rider 2
    1,584
    258
    Ocala, FL
    Those statements are not the same.
    It is YOU who has read something into the manual that is NOT there.
  11. bisco
    52,863
    okay, okay, i stand corrected by the chap driving a prius c.:cool:
  12. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Leaving a PiP fully charged for a few hours or even days is not a big deal, especially if isn't left out in the Sun on hot days.
    However, it is often ideal to use a timer so they charge finishes shortly before the car is driven:
    1. having the battery spend less time fully charged is better since that can cause it to degrade faster especially in combination with higher temperatures.
    2. Using a timer often results in charging overnight when there is less demand rather than right after getting home when demand is still high in the early evening. This help to "flatten" the daily power demand curve which tends to make generation more efficient. It may also have carbon advantages in some regions.
    3. Charging in overnight cool temperatures just before driving helps warm the battery pack which allows it to discharge more total energy.
    This is true for any Lithium-ion plugin battery pack.
    Mendel Leisk, giora and retired4999 like this.
  13. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I would add to Jeff N nice summary:
    Delayed charging gives the battery the chance to rest and cool down from the intensive activity during driving, especially in the hotter seasons.
    Jeff N likes this.
  14. markabele
    5,084
    1,782
    Nebraska
    I think the point Bisco is trying to make is that it is better for the battery to sit for a while at 30 or 50% then it is at 85% (fully charged). How much better? No one can answer that definitively, but it is better. This is battery 101.
  15. bisco
    52,863
    correct, thanks.(y)
  16. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    Indeed. And this is a far cry from "you're not supposed to leave your PiP plugged in all night," which was the challenged statement.
  17. bisco
    52,863
    except that statement is not in the manual either. in fact, it goes against the advice of the manufacturer.;)
    markabele likes this.
  18. Easy Rider 2
    1,584
    258
    Ocala, FL
    It's "battery 101".
