2" Bike Hitch Advice Needed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by NJ-Professor, Mar 27, 2021.
  1. NJ-Professor
    NJ-Professor Junior Member
    Just picked this up Yakima Holdup 2" on FB Marketplace. Will any 2" receiver hitch work with this rack or must I get one specifically made for Gen 3 Prius?
    Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    13,353
    5,397
    Pacific Northwest, USA
    Yeah 2" reciever is standard for big vehicles. Most hitches for prius are the next size smaller and if you use a hitch adapter it increases the length of the lever (aka: force on tongue weight) which turns into a problem with more than a few bikes of a load. But fortunately if you modify it DIY style it won't be an issue.
  3. fuzzy1
    10,678
    There are a number of 2" hitches built specifically for Gen3 Prii. I have the original version of the Torklift Hidden hitch, installed at their primary shop ('sort of' local to me). They have revised designs since. Not inexpensive, but it works very well.
    Torklift Central | Select Your EcoHitch Style
  4. NJ-Professor
    Care to comment on DIY you refer to? Thanks!
  5. PriusCamper
    13,353
    5,397
    Lol... "eco" Hitch...
    Made with 'genuine' earth-sourced materials!
  6. PriusCamper
    13,353
    5,397
    Most stuff that mounts on a hitch is designed for trucks and larger vehicles that can handle greater tongue weight. You can reduce your tongue weight by shortening the length of the lever that creates that weight. You can also modify the bike rack so it fits on a smaller size reciever.
  7. NJ-Professor
    Thanks....more than I could deal with....sold last night to someone with a large pickup truck.....Will look for a decent 1 1/4" hitch mount rack 2 bike CARRIER on CL, FB, OU, etc. Know of any affordable brands/models if I have to buy new? Thank you.
    PriusCamper likes this.
