2 Bolts Sheared off on Intake Manifold when trying to reinstall
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nivekonbass, Apr 13, 2023.
  1. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    hi guys,
    After doing the EGR service on my car, i'm trying to reinstall everything. My question ultimately is, what order should i be re-installing everything. The EGR is currently sitting in it's correct position and that part is basically done except for the EGR pipe.
    The EGR pipe is currently on the intake manifold and it's just not perfectly lining up. (See attached photos).
    When trying to install it all, I had 2 of the bolts that go into the intake manifold (see photo of the part i'm talking about), shear off when trying to torque it down to 21 ft lbs. For some reason it doesn't feel like they are tight, but the bolts broke? Is this due to the alignment of everything? My Torque wrench works fine, but it didn't click at all before it broke the bolt.
    I purchased new bolts/removed the old ones. Where I'm at is intake manifold re installation.
  2. ChapmanF
    19,046
    What's the range on that torque wrench?
  3. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    For the record, I didn't try to loosely install the EGR pipe to the EGR valve first, and then installing it to the manifold.
    I wanted to ask here first before re-attempting anything.
    First one I used was a 1/2 inch drive, which was 20 to 150.
    After this happened, I went and bought a 3/8 inch torque wrench yesterday because I assumed my torque wrench was broken too, this one is 5-80 ft lbs.
    I'm thinking it's an alignment issue causing some unnecessary stress on these bolts. The reason TWO bolts broke is because I tried it again this morning with the new torque wrench, same thing.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    983
    Monument, Colorado USA
    I've had aluminum bolts break, too, when torquing them down....it stinks! So, now, I always have new extras on hand (And extra ignition coil connectors and plastic clips and crush washers...etc.)
    Always insert screws and plugs in slowly by hand...I've seen too many guys using power tools and cross-threading at speeds which makes for a nightmare situation.
    You got this!
  5. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    I did do it by hand, both times, that wasn't it. I know better than to use a impact wrench on plastic stuff. My question ultimately is what order should i be doing everything. As you see, the egr pipe is not perfectly aligned.
    Should I loosen everything so I have some play?
  6. ColoradoBoo
    1,356
    983
    For sure...get all the bolts inserted a few good times before starting to snug them and then torque.
  7. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    I think what I will do is loosely connect the EGR pipe to the EGR valve, and leave it disconnected from the intake manifold. Torque down the manifold first, then install the EGR pipe to the manifold.
    Does this sound like the right order? Sorry for the stupid questions, in a lot of the videos they don't really show the re-install, they just say "reverse the process" or skip through it.
  8. ChapmanF
    19,046
    That may have been a dubious choice, as clicky wrenches are often not at their best accuracy way down in the lowest portion of their range.
    That's more in line with the usual recommendation to choose a wrench where the wanted torque is more in its mid to high range.
    Of course, that leaves me with no explanation why your bolt broke the second time. :oops:
  9. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    I think that this is a case of user error, more than the torque wrench, but I agree with you 1000% that's why I bought the 3/8 version. I'm using harbor freight torque wrenches too for the record lol
    The EGR pipe is currently torqued down to the intake manifold, and it's not perfectly lining up. I should have had both sides relatively loose. I think my best approach is to torque the intake manifold down FIRST, before installing anything to it, including the throttle body.
  10. ChapmanF
    19,046
    That sounds like a good approach to me.
    nivekonbass likes this.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    If your not using a torque wench all the time its absolutely the worst thing a rookie can use. Many a snapped off bolt on this site from just that.
    Especially if its a cheap harbor freight TW with a funky sloppy click alert.....why would you buy a piece of junk torque wrench when your looking for precision?
    If you must use a TW and I don't know why you would test it on a tire wheel lug first. See if the click is making sense.
    Just tighten them down bro its an intake manifold. It doesn't care.
    There's not one thing under that hood that needs a torque wrench the exception is installing a cylinder head and or main bearings.
  12. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    :p i love ray, i watch his stuff all the time him and ericthecarguy are awesome. Chrisfix too.When it comes to plastic shit with gaskets, i'm usually extra cautious and i'll go ahead and torque them, but this time I was not cautious enough and got a little comfortable thinking it would all just come together ezpz, but nope lol. I'm kinda glad it happened because now it all lined up pretty nicely and I know next time what not to do.
    I just got it done by installing/torquing down the manifold first even before the throttle body. That should be a disclaimer in every one of these repair videos.
    edthefox5 likes this.
  13. edthefox5
    10,096
    4,840
    Clearwater, Florida
    I like "Just Rolled in"
    ColoradoBoo likes this.
  14. Mendel Leisk
    42,368
    No clue as to how the intake manifold bolts would shear off, at proscribed 21 ft/lbs. They're steel btw, not aluminum, as alluded to above in post #4?
    The EGR pipe between intake manifold and EGR valve is always the first thing I take off, and the last thing to reinstall. It's a bit of a geometry miracle that it fits so well, but pre-bolting to one end or the other is asking for trouble. It does have a pliable gasket at the intake manifold end, gives you a little wiggle room.
    You should maybe get a 1/4" drive torque wrench as well, for stuff like the throttle body hold-down bolts/nuts. More info about all the torque values involved, in the attachements.
    jzchen, James Finch and edthefox5 like this.
  15. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    You might like vice grip garage if you like those guys. I like that guy a lot. He goes and finds the most rusty pieces of crap and tries to drive them home hundreds of miles away. I learn a lot from his ghetto techniques lol
  16. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    Yeah that was the mistake, I had it preinstalled onto the intake manifold side, it probably would've been fine if it wasn't torqued down. In any case, I still would recommend installing the intake manifold even before putting the TB back on. It's probably not a huge deal but I imagine the weight of the TB puts a little extra stress on that manifold. can't say for sure but just glad it's solved.
  17. Mendel Leisk
    42,368
    You do know there's no need to disconnect the throttle body's coolant hoses? If you take the throttle body off first, you can leave the coolant hoses connected, just rotate the whole thing up and over twowards, the inverter, tie it to the inverter's wiring harness with some twine or what have you. See second link in my signature.
  18. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    Yea thats what I did. I left the coolant hoses on (I watched merv's video in the past for this, and he mentioned you :p). I just hung it somewhere while I did the intake manifold/EGR stuff
    I did not deal with coolant at all in this whole repair. Instead of pulling out the EGR cooler/it's hoses, I removed the two studs in the back of the EGR cooler so it wasn't connected to the exhaust and so that I could move it to the side and then I used a coat hanger to clear the EGR cooler passageways and then used an air hose/compressor to blow out the crap from inside of the cooler. Worked great, lots of flow coming through now. I had already removed the annoying nut from the bottom of the cooler so all I had to do was take the two in the back out. The compressed air worked really really well. The EGR valve itself I cleaned thoroughly.
    My car only has 105k miles on it at the moment so it wasn't TOO obstructed, but i'm confident that I got all of the blockage out. I air hosed that thing for a good 20 minutes lol and made sure my compressor was full of pressure before going at it again, each time.
    #18 nivekonbass, Apr 13, 2023
  19. Mendel Leisk
    42,368
    If you ever revisit EGR cleaning, see second link in my signature, for removal of cooler without coolant spill. Off the car your cleaning options are better.
    #19 Mendel Leisk, Apr 13, 2023
  20. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    OP has explained exactly why I don't trust my cheap arse torque wrench...
