2 Issues: XM Fuel Price and Audio Setting
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rezar1, Oct 31, 2012.
  1. Rezar1
    Rezar1 Junior Member
    have 2 issues that I wanted to find out if anyone else has experienced and how you were able to resolve it.
    First: When I click on the XM Fuel Prices, I get a message stating that an active subscription is needed to access this feature. My XM is active and XM Sports and Stock Price works but for some reason XM Fuel Price is not working.
    Second: When I was reading the Nav Manual, I noticed that under the audio setting>DSP, there should be an option to switch to “Surround”. When I click on DSP under the audio menu, I don't see this option! Is there a reason for this?
    Thanks,
    52,690
    i can't believe you haven't heard from anyone on these issues.(n)
  3. lensovet
    2,615
    496
    Burlington, NJ
    Well as to your second question, there is no reason, other than the fact that the manual sometimes doesn't match the car. I guess the manual gets printed before the production software gets finalized. Also, the audio/nav manual is not model-specific, so not every feature is available on all models.
  4. Rezar1
    I gave up and Called XM directly and they resent the signal and I am good to go. For the second issue, I guess above post is correct. The online manual has the feature while the manual that came with the car does not. So I guess they took out at the last minute or something.
    lensovet likes this.
