2 month anniversary energy stats for 2012 plug-in basic
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JohnSNY, Dec 16, 2012.
  1. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    Thanks. It is more than 300 g/mile.
    JMD likes this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Interesting point, is the Long Island Gas/Electric company buring clean fuel. I would think they are. Not Nuclear but maybe natural gas.
    I know some energy companies offer off peak electric at a lower price point. Is there anything like that where you are?
  3. John H
    John H Senior Member
    2,208
    558
    With your higher EV % you might be less. I think that site assumes 28.8% EV for the PiP.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    It is 190 g/mi with my zip code. You sure you picked the right car? :)
    JMD likes this.
  5. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I
    LIPA buys electricity from National Grid. I can't find much info. on what National Grid is producing. There is a coal fired power plant near me, but I understand that this plant is offline now. It is used only when there is peak demand, like in the summer. The next closest plant burns natural gas. Some of the power goes from/to Connecticut.
    No discount from LIPA for off peak use. I pay .19, but the average is .20.
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    It should be more because 50 MPG on gas would emit 222 g/mi. If 28.8% EV raises it to 300 g/mi, 52% EV would have higher CO2 output.
  7. John H
    2,208
    558
    uh oh
  8. JMD
    3,779
    1,282
    You must be talking about Shoreham. I grew up in Long Island but moved to California in the late 80's. That almost went Neuclear but State Gov put a stop to that. Natural gas is safer.
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    EPA data is outdated so that figure might have been true when that coal power plant was still in use.
    John Hatchett likes this.
  10. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I know. That's why it is better to focus on national average. PiP is cleaner than a regular Prius when using national average electricity.
  11. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    The National Grid Plant in Port Jefferson (Long Island) uses fuel oil to generate electricity. I see the huge tankers at their dock all summer long as a pass by there on my way out to the L.I. Sound for a day of fishing.
    I've calculated my rate at about 20 cents/kWh from LIPA/National Grid.
    JMD likes this.
  12. JMD
    3,779
    1,282
    I'm sure it is scrubbed and cleaned at the plant, but getting the oil from the ground, refined, and to the consumer has to have some impact with all the controls allowed. The way I see it the Prius and Volt is the lesser offender in an offended world.
  13. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I just looked it up. It uses natural gas and oil, but it is old and one of the "dirtiest" power plants in NY.
    JMD likes this.
  14. JohnSNY
    JohnSNY Member
    36
    26
    Long Island, NY
    I meant the savings is "more than 300 g/mile" relative to my SUV. The site assumes 28% EV, and I am at 52%. I might be saving near 400 g/mile.
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Don't worry about it. It is just one old dirty power plant out of many. National average for PiP is 210 g/mi. If you choose any other plugin, you will find the emission to be much higher, so you have the cleanest plugin out there.
    If you don't plug it in, you'll reduce your CO2 but gas will cost you more. See if you can buy cleaner electricity. Is that train station (where you charge) also has the same zip code? Perhaps the electricity there is from a different powerplant.
  16. give dinosaurs a break
    If you want do some research, EIA 860 (Energy Information Agency) lists the power plant addresses. Cross reference to EIA 923 for recent fuel purchases.
    E.g.
    NorthportEaton's Neck RoadNorthportSuffolkNY11768
    Northport National Grid Generation LLC 56505 NY MAT NPCC 22 1 Electric Utility ST NG NG mcf
    1,986,470 2,113,952 2,771,329 2,801,298 2,954,276 3,150,304 4,431,329 3,675,536
    qty for jan to aug 2012
    mcf => 1000 cubic feet natural gas
    NorthportNational Grid Generation LLC56505NYMAT NPCC221Electric UtilitySTRFORFObarrels 8,311 928 0 0 1,860 36,608 127,471 53,639
    barrels of oil for same period
  17. 3PriusMike
    3,097
    2,419
    Silicon Valley
    Agreed. IMO, no one should buy or not buy the PIP based on where their personal electricity happens to get generated from. Buying many PIPs or other plugins should be looked at as generating "new" demand, so what matters is the "next" power plant built to satify this new demand in your area.
    Technically, you can easily offset one full charge per day (3 Kw-hrs) by reducing other electrical demands at home and/or work. Cut 125 watts of "always on" load and you've saved enough for one full charge every day.
    Mike
  18. give dinosaurs a break
    Moreover there is much less electric demand at night then during day in most areas so if you charge at night it is highly unlikely that charging will contribute to the construction of another power plant. In air conditioning climates the demand peak occurs in the late afternoons so get the charging done when you first get to work. Where electric heat and hot water is prevalent, the peaks occur in the early morning, so there charge in the afternoon.
  19. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    Thanks USB,
    For my 2012 PIP in 14564 it states that the Average New Vehicle emits 500 grams/mile, while my car in my location only emits 190 grams/mile.
    I can now Breathe with Pride !!!
    JMD and usbseawolf2000 like this.
  20. John H
    2,208
    558
    You should see if you can buy clean electricity. I am able to buy wind power for charging so my ghg is running less than 50 g /mile and I buy the inexpensive offsets for that at terrapass.
