2 Questions about intake manifold cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paphillyman, Dec 14, 2018.
  1. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    question #1 ) Did you guys get a new gasket in case you had to replace it or should you just get one to be sure and
    2) after taking the 4 bolts off to release the front of the manifold , was it stuck on pretty good or did it just release and do ya just bolt it back when when putting it back together ?
    3) after cleaning it with brakeclean , do you have to let it dry completely or is it ok to put it back on?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    The first time I did the cleaning I got a new gasket, but it is a rubber type gasket, so unless you tear it or get cleaning solution on it, I’d reuse it.
    The manifold has 3 bolts and 2 nuts (your probably forgetting about the one that holds the dipstick in place as one of those) and it releases easily.
    I would let any parts I cleaned dry before reassembly.
    Good luck and keep us posted (y).
  3. paphillyman
    paphillyman Member
    84
    88
    philly suburbs
    thanks for the quick response
    Raytheeagle likes this.
