20% improvement in MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by *Goldfinger*, Mar 4, 2014.
  1. *Goldfinger*
    *Goldfinger* Junior Member
    Sheffield, England
    I reset CPU’s by disconnecting Aux battery, I guess it’s the first time in 7 years. Since then I have covered just over 50 miles (fair weather) and noticed a big improvement in MPG, from 46 MPG to 56 MPG Average. Could be partly down to me noticing better MPG and then subconsciously trying to improve it further. NB. UK Gallon - not everything bigger in America J
    Anyone experienced this?
    Britprius likes this.
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Likely it's the placebo effect......mostly.
    kenoarto likes this.
  3. miscrms
    miscrms Plug Envious Member
    2,079
    525
    Phoenix, AZ
    If you don't typically reset the meter, it would have been showing a very long term average incorporating all kinds of driving and weather. It wouldn't be surprising for your new short term average to be much better if weather is good, and driving is sedate/cautious :)
    Merkey, xliderider and *Goldfinger* like this.
  4. *Goldfinger*
    Sheffield, England
    I reset MPG monitor at every fill up.
  5. ursle
    ursle Gas miser
    1,049
    192
    NH
    Just like any digital device, unplugging it periodically is a good thing, try it with your cable box, or your desktop computer, who knew? But I agree, unhooking the 12v and giving it a good slow 2 amp top up and re-hooking it is actually a healthy thing, and I agree, better mileage:) ;) , winking because of the 2% mpg difference between the prius brain and reality.
    Data Daedalus and *Goldfinger* like this.
  6. *Goldfinger*
    Sheffield, England
    Went on a long motorway run today and reset MPG monitor while cruising, 53 miles later and average MPG 75.5 ! (UK Gallon). Passenger photographed results on MFD for evidence. Incredible , I didn't think it possible. After entire journey of 380 miles at up to 80 mph in places my average was over 70 MPG.
  7. bisco
    51,140
    brilliant!(y)
    *Goldfinger* likes this.
  8. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Hi Goldfinger,
    Could you please tell us what exact tyres, tyre sizes and tyre pressures you're using? Over 70mpg in the UK is very good indeed. I managed to get up to 66mpg indicated last summer (out of a tankful - or 43 litres to be exact). And that was running with A/C on the lowest setting on the return commute home everyday. Where do you regularly fill up with fuel? As in which fuel supplier? Did you use Cruise Control or did you achieve these figures without it?
    Data_Daedalus
    iPad ? HD
  9. *Goldfinger*
    Sheffield, England
    Hi Data Daedalus,
    Just standard tyres and size (yokohama), slightly high pressure 38 front 36 rear. A/C off for 90% of trip. Fill up at Morrisons with standard unleaded. Cruise control on 95% of time. I was so amazed I made a later post with photo's, on Mar 22, title 75 MPG ?
    WilDavis and Data Daedalus like this.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    One thing I would like to know is this. Does the MFD allow for the larger gallon that you chaps have there when doing the calculation? I do realize that volume wise the gallon there is LARGER than the gallon on this side of the pond.
    My question is if the Prius you drive accounts for that difference in volume when calculating the MPG.
    Hope this makes sense. I would really like to get a clarification on it for better understanding of how the UK Prius models work in comparison to say the USA Prius models.
    Thanks!
    Ron (dorunron)
    Data Daedalus likes this.
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yes, it certainly does Ron.
    So for example, 70 MPG (UK) is only about 58 MPG (US). So while 70 MPG (UK) is still very good for motorway speed, it's nowhere near as crazy as it's sounds. Quite easily achievable at 60 MPH, but obviously getting harder as the speed increases.
    You might be interested to try my converter program Ron, it converts between all commonly used fuel consumption units. It's a tiny no nonsense program that runs stand alone on any windows computer (Windows 95 onward).
    It's in the gen2 file library here: Simple Fuel Consumption Converter Calculator. | PriusChat
    dorunron and Data Daedalus like this.
  12. dorunron
    3,318
    1,105
    Houston, TX
    Thank you uart for the clarification. I now feel better. Thought I was doing something wrong but now found out I was right up there with the UK folks. ;)
    FWIW, when I turned in the Gen II earlier this week, the MFD was showing 57.1 with 215 miles on it. I pointed it out to one of the salesman that was dealing to me. His eyes got real BIG.
    Here's the best tank I ever did if I recall correctly. I didn't make it to the 500 mile mark. I was down to one pip and a little nervous. Never had ours down that low in the time we drove it. I have read too many horror stories here on Prius Chat about running out of gas in a Prius...
    I do however intend to see how far I can go on this new Gen III. Watching the distance to Empty and will fill up when it hits zero or the last pip whichever comes first.
    Ron (dorunron)
  13. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Goldfinger congratulations on breaking 75 mpg. As I stated in another thread the low 70's are easily achievable with a gen2. Keeping the speed down a little really helps as does the warmer weather. Those Yokohama tyres are not doing you any favors mpg wise, but it is pointless changing them "money wise" if they have good treads. Tyres that are nearly worn out will also give better mpg readings.
    I cannot find any Yokphama tyres with a fuel economy rating better than (E) many are at (F and G) this is in the OEM size 195/55/16.
    Perhaps it should also be pointed out to those in the US that the UK/European gen2 Prius comes only with 16 inch wheels reported as not to produce as high mpg figures as the US 15 inch.
    I now buy my fuel from Asda (Wallmart in the US) at only £1.25.7 a ltr compared with Morrisons £1.29.9.
    John (Britprius)
    *Goldfinger* and dorunron like this.
  14. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah 70 MPG-UK (58 MPG-US, 4.0 L/100km) is good fuel consumption, but relatively easy to achieve on a single good trip, and still very good for a full tank average.
    75.5 MPG-UK (63 MPG-US) is a *lot* harder to achieve on a full tank average basis. A one way trip is a different thing though, as even a modest difference in elevation can have a noticeable impact on fuel economy. You can also get lucky with a tail wind for example. So I wouldn't get too excited about a single one way trip figure, but concentrate more on what you can achieve as a full tank average.
  15. *Goldfinger*
    Sheffield, England
    Hi John,
    I didn't know about the UK/US wheel size thing. By the way, I think I'll be filling up at Asda from now on ! Thanks
  16. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    ill see your MPG and raise it
    though i do have a SLIGHT advantage... :)
    the above pic was taken 10 minutes after leaving work for the day and filling up on the way home.
    130MPG imp
    108MPG US
    2.1L/100km metric.
    used 33.74L for the 1564KM and seven weeks of commuting.
    all in up to 70kmh speed zones and all in city conditions.
    Jason.
  17. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Jason . What is your average speed? H
  18. HaroldW
    716
    95
    I must add , those are great #'s :) H
  19. Jason in OZ
    271
    112
    Sydney, Australia
    i guess it would be around 60kmh.
    or just south of that. the real reason im getting such good numbers is the PHEV system....
    basically, for any journey of up to around 1hr:20 minutes, in city traffic, i can get about 50% pure EV.
    Jason.
  20. HaroldW
    716
    95
    What is a phev system. Have you converted too a PIP system? [added a couple packs]H
