200,000 Mile Club
Discussion in 'Gen 3 Prius Main Forum' started by Raytheeagle, Apr 10, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    The original batteries, non lithium batteries were 20-80% range. I am not totally sure
    with lithium or sodium batteries. I've read different things and it's not worth it for ME
    to bother with it. As long as it works, that's all that matters to me.
    The computers seem to know what to do and Toyota has decided on a certain percentage
    and that works for me. (y)
    Some people are really into finding out all about that stuff, and that's fine for them.
  2. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    I work and got money from Li battery research but I am still not convinced with EV disposable cars. Li ion battery varies a lot depends who made it, eventhough they use the same technology.
    Generally, Li ion battery is happy with 40 to 60% charged state. The art is to design the anode so it will not crack at high charged and the cathode still have enough crystallinity when the battery is depleted.
  3. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    You're still using that terminology. Do you have any examples of 'EV disposable cars'?
    Who and why would someone dispose of an EV?
    I assume you're going on about the battery degradation, that will slowly show up in an EV.
    If your Gasser had a known problem of the Gas Tank Shrinking,,, WHEN would you spend thousands to replace it?
    With EV's some charts seem to show that when Degradation is at 80% it's time to replace the pack.:whistle:
    I don't understand that. (n)
    My EV would be fine with an "80% gas tank". In fact I routinely use 'hilltop reserve' which is ~87% SOC.
    My Prius would be fine with an 80% gas tank.
    My Prius and my Bolt both have ~150k miles on them. For example....
    Which car will have a major failure first? :unsure:
    (I consider a head gasket failure 'Major'.)
    Yes, yes, you've dabbled in Li-Ion batteries at a job.
    Was it high-power packs with a proper TMS? Or was it flashlights, tools or toys?
    Laptops have been using them since before AC Propulsion got the idea to build big packs and use them in a car.(Ta'HayL with Leon)
    (Yay, the 18650 !)
    What's wrong with laptops, tablets and phones? They get replacement packs, when the time comes.
    No one disposes of them because of degradation. Well maybe the Rich do....:(
    #123 Bill Norton, Jan 7, 2025
  4. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I would like to think that Toyota is still operating under the notion that excellent reliability creates strong brand loyalty. If my Prius overcharged my lithium cells to 4.4V like my Samsung phone, the batteries would perform better, but in less than 2 years they would be destroyed (as my phone battery did). I believe my Prius battery maxes out at 70% charge, which is about 3 volts.
    A hefty battery replacement bill after 2 years would destroy my loyalty to Toyota forever, I should think.
  5. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Let’s not forget this is for 200k plus posts…
    Currently at 205k
    1) Did you replace the HV battery pack? Do you maintain it?
    Original battery, cleaned fan, replaced bus bars and nuts around 150k, installed air intake filter
    2) Did you replace the 12v battery?
    Once around 130k
    3) Did you replace the transaxle fluid? How often?
    Once at 140k
    4) Did you replace the brake pads?
    120k front and rear but the dealer lied to me about needing the service
    5) Your lifetime MPG (if available)?
    45mpg
    6) How often do you change your oil? Does your Prius consume oil? What brand / product did you use?
    10k until 120k then every 5k after that.
    Oem filter and Mobil 1 or any quality 0w20
    Consumes .5-1 quart per 5k.
    7) How about posting a picture of 200,000 miles on ODO?
    8) Did you install an oil catch can? How often do you inspect or dump it?
    Yes when I did the egr service, cleaned out every 5k at oil change
    9) Have you cleaned the egr circuit? How frequently?
    Complete clean out 140k, new oem egr valve and intake manifold. Probably need to do it again here soon.
    10) Any other maintenance?
    Spark plugs 120k, ice water pump 155k, on my 3rd set of tires, general maintenance like cabin and engine filters. Inverter coolant, pcv valve changed 140k, MAF and throttle body cleaning 140k. Added silicone on the weld cracks to prevent water from getting into the spare tire area. 1 bottle of Gumout regane every 5-10k.
    Bill Norton likes this.
  6. ASRDogman
    8,070
    4,092
    SPLASH73 and Prodigyplace like this.
  7. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    Theres a good point though. Battery cycle life increases more and more if you stay closer in your cycles to 50%.Cycling 49-51% the battery could probably last for 30 years+. Now would that be advantageous in a car that regularly ends up in the junkyard every 20 years? Probably not. The prius per obd2 flicks the engine on at 25% and 75% to avoid over and under charging. Normal driving the battery hovers around 50-65%.
  8. Madmommymelinda
    Madmommymelinda Junior Member
    51
    Lexington, KY
    2014 Prius Plug-in
  9. SPLASH73
    SPLASH73 New Member
    Sellersburg
    2014 II, 278K miles as of this post and well on my way to 300Kmi :)
    Original is still @62% life. Just keeping the fan clean... probably should look at a rebalance soon.
    Dec 2024 replaced the original 11yr old factory w/Optima Yellow top
    Yes... at 100K and 200K.
    First time rotor and pads replaced at 275K
    ~49.9 overall. 80% Hwy / 20% city. Varies seasonally. Still pretty close to 50mpg per tank.
    Every 6,500miles, Mobile 1 Synth, and it doesn't consume at all. Very clean at the swaps.
    (I'l edit and add when able)
    Nope, but I probably should. The intake manifold was filled with oil at 275K replacement.
    Yes, DIY at 275K miles. I pushed my luck and will now clean and swap coolers every 60K
    Coolant flushes, spark plugs, and other maintenance on schedule per Toyota. Cleaned injectors and replaced coils at 275k. Cleaned MAP/MAF sensors. Replaced intake manifold and cleaned throttle body at 275K. All DIY stuff... pretty easy if you watch the videos.
    **Still need to swap water pump.
    Raytheeagle and Noahdoge like this.
  10. Mendel Leisk
    42,369
    Just editorial: to the uninitiated, that expression must be a puzzler lol.
    CR94, gboss and Raytheeagle like this.
  11. tacopyro
    tacopyro Member
    87
    45
    Los Angeles
    just noticed this post. for my 2012. which i bought at 340k mi.
    altho i guess it doesnt really count since i bought it used and dont have 200k mi on it myself. in any case...
    i maintained it then i replaced it.
    yes just recently
    so far just once.
    just once when i bought it.
    42mpg. recently started using Eco mode + 40psi tire pressure and getting 46+mpg
    4k mi OCI. i rebuilt and replaced the rings with aftermarket. havent consumed since.
    yes once every OCI
    when i rebuilt the engine. and plan to every 100k mi.
    i give it a sip of redline SI1 every once in a while and tire pressure checks.
  12. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks for the detailed report !
    1) How do you "maintain" the HV battery pack?
    2) What brand of head gasket did you use during your rebuild? What brand of head gasket did you remove during disassembly?
    It was probably not the original at those miles. Who makes better rings 'aftermarket'?
    I'm having my head gasket replace in a few days by Gasket Masters, ('10 @ 167k mi.) ,and they always use the blue FelPro, although I read that that brand can also be black in color.
  13. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    how about a 300,000 mile club! Alllmost there. I already put the 300,000 mile club sticker
    On it. Couldn’t wait. I bought it in 11/2020 as a project with a blown head gasket and 209,000 miles. So I pulled the head and replaced the gasket along with every little sensor and wearable item that came off while I was at it. The only other problem I had was a bad purge valve. It runs like a champ, 50mpg. It’s black and had some pretty bad peeling so I repaired that too. Anyway, keep driving!
  14. ASRDogman
    8,070
    4,092
  15. Tom Macke
    Tom Macke Junior Member
    Ventura
    I'm at ~189,000 mile mark and driving a 2015 Gen 3. Almost there! Bought it in 2017 when it had about 50,000 on it. Someone had been using it as an Uber I think, but would not admit to it. She has been so very reliable and problem free. Any advice on fixing it up? I saw someone had done a TRD upgrade? How much would that run? My mileage has dropped from 52 mpg to 40 in the last 5 years, but otherwise, she runs like a champ. Considering I've seen several people here crossing over the 300k and 350k marks, I'm assuming it's worth it to replace the HV batt.???
  16. Tom Macke
    Ventura
    Hey friend, how did you go about doing the TRD upgrades? Is there a website(s) that focus on this specialty? Thanks.
  17. ASRDogman
    8,070
    4,092
    Probably a good idea to clean the EGR system.
    Have you replaced the plugs, coolants, trans fluid?
    Clean and grease the brake caliper guide pins?
    About time to do the head gasket.
  18. tacopyro
    tacopyro Member
    87
    45
    Los Angeles
    Sorry for the delay, i'm not on here much lately.
    1. The most important maintenance is to keep the operating temp below 36C. no matter the chemistry. i used hybrid assistant app and keep the HVB fan on with the AC on every time i roll ( i live in los angeles). i did replace it with sodium ion battery pack. so far so good. getting 46mpg consistently. Felpro should be fine. Gasket Masters should have enough experience to know what to use. in my case. i have too many cars to maintain so i use OEM only.
    on my 08 prius, i bought it with a failing HV Battery. i tried replacing individual modules which doesnt last as long. when i started maintaining periodically with prolong charge discharge it got better and balanced. using Hybrid assistant App. i saw it has a temp of 60C one time in stop and go traffic, and started using the fan all the time.
    I operate as follows: in hot areas. with AC on, i keep HVB fan on, in cold areas, however you like warm air with HVB fans on, keeps them in operating temp. and it will last longer. windows always closed.
    Currently my son uses the 2nd gen and he never does any maintenance aside from keeping the HVB fan on and so far it has survived 2 yrs in his "care". :D i havent opened the pack in 3 yrs now aside from the once a year prolong maintenance. same goes for my wifes 2011.
    2. I used OEM only. 04111-37315 complete (3rd gen). it was using OEM HG when i took it apart. yea probably not original from factory. i use either enginetech or NPR rings. also used arp cyl head studs. so far in the 4 prii under my care all have OEM HGs.
    Another thing i see in other engines, usually headgasket failure is bec of old coolant eating the HG coating. maybe change coolant every 60k mi or 4 yrs to keep it fresh. cheap insurance.
    edited for clarity.
    #138 tacopyro, Mar 24, 2025
  19. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    Changing all fluids more than "recommended" is always good.
  20. Ianmeister
    316
    320
    Meridian Idaho
    tacopyro, Bill Norton and ASRDogman like this.
