200,000 Mile Club
Discussion in 'Gen 3 Prius Main Forum' started by Raytheeagle, Apr 10, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
  2. Tande
    Tande Active Member
    556
    339
    Mich.
    ASRDogman .......do I remember correctly ......that you are running an aftermarket waterpump rotor/impeller?.......if so, would you mind telling for how many miles? ......Thank You
  3. ASRDogman
    8,070
    4,092
    Replaced on 22 March 2022, at 266710 miles
  4. Tande
    Tande Active Member
    556
    339
    Mich.
    100,000 mi. WOW! ......thank you soo much.......I have this gut feeling, that a high % of head gasket failures are the result of a compromised water pump, due to a dragging impeller/rotor (not yet locked/up) ........I would be interested in your take on that theory......thanks again
    #144 Tande, Apr 7, 2025
  5. ASRDogman
    8,070
    4,092
    I believe it is a combination of things.
    And it seems those that drive mostly highway miles go a lot further than those
    who drive mostly city driving. 301,000 miles for me.
    I was getting parts together and was going to set a date to replace it before it failed, but it
    beat me to it. It was a simple knock after sitting 20 minutes after a 20 minute drive.
    Then about the same thing a few days later. The coolant had only gone down very slightly.
    I had changed the impeller long before that though. And I only changed it because when I
    removed the pump the impeller was fine. But I dropped the pump as I was putting it back
    in place and broke it.
  6. Tande
    Tande Active Member
    556
    339
    Mich.
    Fair enough! .....I'm going to change the impeller in my wife's 2010......130,000 mi. .....just because......Thanks again!
    ASRDogman likes this.
  7. ASRDogman
    8,070
    4,092
    If it is the original one, and it is not cracked and spins freely, you don't need to replace it.
    But it's up to you
  8. Tande
    Tande Active Member
    556
    339
    Mich.
    (y) ......
  9. GustoGuy
    GustoGuy Member
    82
    57
    397,562 miles and I still have the original Traction battery on my Gen 3 2010 Prius 5 trim. I replaced the engine with a JDM 45,000 mile engine in March of 2021 at 268,000 miles on the original engine due to hydro-locked blown engine. New engine is doing fine with zero oil consumption at 129,000 I added plus the original 45,000 for a total of 174,000 miles total on the replacement engine.
    Tande likes this.
  10. stokesey
    stokesey Junior Member
    93
    Southern Cal
    2015 Prius with 262k on the clock.
    Batteries both replaced at 120k
    Not sure about trans fluid
    Rear pads got stuck, replaced
    Oil changes at 6k, spec synthetic
    Consumes 0.5q
    EGR cleaned and PCV replaced
    Coils and plugs replaced, fixed misfires
    Cylinders a bit dirty but head OK still
    Water pumps can be tested w scan tool
  11. Mendel Leisk
    42,376
    Toyota USA schedule recommends a 30k mile (or tri-yearly) "more in-depth" brake inspection. This is not a "needs new pads and rotors" brake job, just a regular check/clean/lube maintenance. I think both the dealerships and owners tend to ignore it, short term gain but long term pain.
    bobby515 and Bill Norton like this.
  12. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    Hybrid brakes can last a long time if your driving style emphasis is on regen rather than last minute braking.
    My dealer inspects them at oil changes but the fronts have never been apart and the rears only have new pads because the one hub was noisy and we changed both. Short and long term brake expense gain at 331k miles.
    stokesey and Mendel Leisk like this.
  13. stokesey
    93
    Southern Cal
    Definitely plenty of deferred maintenance on this vehicle. I believe the previous owner didn't know how to use the parking brake as he was mystified when I pressed the pedal, "what's that", etc. Seems like that could be related to that rear caliper freezing up, it was hardly used. Not a huge deal, but a bit of a pain when I didn't have the tool to turn that piston.
  14. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    That tool is available to borrow down at your local auto parts store and it's cheap if you want to actually own the tool you need to work on rear disc brakes.
    There are two kinds of 'frozen'.
    There's an actual failure of the piston in the caliper.
    And then there's the Slider Pins rusting up and not allowing the caliper to float. This will result in one brake pad wearing more than the other.
    The mechanical emergency brake may move the piston regardless if it's frozen in the caliper, but I'm not sure.
  15. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    "Cylinders a bit dirty but head OK still"
    How did you come to this conclusion?
  16. Matt Van Aken
    Matt Van Aken New Member
    Batavia Il
    With a heavy heart I write this post. I have never posted on this forum but have used it as a resource for any and all maintenance I have performed. I have 2011 Toyota Prius. On June 4th at 5:26am, she told me she didn’t feel like making the commute into Chicago. It’s 45 mile trip. The head gasket went. She had 275,923 miles. I will be buying a new Prius this weekend but I am not done with my original. I’m not sure if will swap engines or just pull the old one to get a skim and new head gasket. She is a great car. Very little maintenance outside of the normal consumables. I changed rear wheel bearings, and an air flow sensor. When I started getting the death rattle this winter I hoped it might be either spark plugs, coils, EGR valve cooler or pipe or manifold. Changed all of those, seemed to prolong its life a few months. Started to get the rattle last week then no mas. She never stranded me. I love that car. lol.
  17. Tande
    Tande Active Member
    556
    339
    Mich.
    FWIW......If you decide to keep "Her" ......you may want to consider changing the water/pump.......it may be starting to "Drag"......resulting in higher than normal engine operating temperatures .......again, FWIW
  18. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    She did, did she? My car tells me squat. I looks under the hood and sees the coolant is now down about an inch and I says to myself, I says,
    "Crap, the head gasket is failing".
    None of the new parts you put on the engine have anything to do with the head gasket, unfortunately. And did you know you can just clean the 'EGR cooler, pipe and manifold?
    Side note: A 'swap engine' may have a failing head gasket. If it hasn't been repaired it will fail in the future.
    Grit likes this.
  19. rjparker
    11,140
    6,985
    Texas Hill Country
    Yes a lot of people fire the parts cannon with no results. Often because of themes pushed on this forum.
    My small shop mechanic has replace many hundreds of Prius engines because of head gaskets or excessive oil burning. He will not do a simple head gasket job on gen3s. He also gave up on cheap rebuilds by a local engine shop if it overheated. He now spends time inspecting JDM engines before installing.
    Bill Norton likes this.
  20. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Is there a way to 'inspect' a head gasket in an unknown used engine? This sounds like a ticking bomb also.
    What's so hard about replacing the head gasket with a FelPro version of that head gasket?
    I realize the engine could have been damaged while in the 'death rattle' phase. A rod could have been bent, but that can be measured without a big disassembly.
    How long is a typical 'JDM Engine' good for? It still has the factory head gasket.....:whistle:
