200,000 Mile Club
Discussion in 'Gen 3 Prius Main Forum' started by Raytheeagle, Apr 10, 2019.
  1. Matt Van Aken
    Matt Van Aken New Member
    Batavia Il
    The initial problem was a check engine light after a rough start. Scan said misfire. I think there are many things that can cause a misfire besides a failing head gasket, Like all of the items I replaced. All of those items were due for a cleaning or replacement. I went the more expensive route. Lol
    I think the only way to check the head gasket is to crack it open and look. I’m fully aware the I could have just bought a used engine that could easily put me back to square one. I’m curious to open up the original for a gander. Lol
    Will do. 275k deserves a new water pump.
    I am definitely one to fire the parts on canon for just about anything. I am no mechanic. I am a competent parts replacer at best. I think someone like myself and others wish they had the time expertise to fully and accurately diagnose a problem before going full nut job and buying any and everything new. Most of what I bought could have been cleaned but man I’m not sure if you’ve seen a 275k mile egr valve and cooler but I’m thinking it would have been at least 2 cases of brake cleaner the good stuff the kind you can’t get in California. I also think people enjoy doing something even if it’s not what actually needed to be done. However, all the things I did either needed to be replaced or cleaned. I went for replacement. I guess I was hoping my engine wasn’t going to be the one that needed the head gasket. WAMP. The forum was right though it doesn’t go slowly into that good night. lol.
    #161 Matt Van Aken, Jun 8, 2025
  2. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    'Tis true, 'back to square one', as in you now have a second used engine with a pending head gasket failure.
    That's the part I don't understand about buying yet another used engine.
    You had the exact same thing a few months ago before the original engine started using coolant.....
  3. Matt Van Aken
    Batavia Il
    You are right. I should deck the “new” used engine and replace its head gasket. I’m in no rush and truth be told, I will probably be giving the car to a guy that works for me. Maybe that’s why I am doing the bare minimum to get it back running.
  4. Matt Van Aken
    Batavia Il
    Full disclosure. As previously stated I’m at best a competent parts replacer. I purchased a long block so I think it will be easier just to remove the old and put in the new, rather then removing everything on the old engine and not remembering how to put it back together with out a large bag of clips and bolts bag of shame. lol
  5. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    But it you're doing this work, why not do it on the used engine you have right now, in your car? Why buy a whole different used engine, with unknown service records and oil consumption???
    #165 Bill Norton, Jun 10, 2025
  6. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    Perhaps you can sell your used engine to someone else, then they will have a "new" used engine.
    It will work fine! :whistle:
    Unless you get a 2015 engine, you have the weak piston rings to be concerned with.
    "IF" the head on your engine is not warped or cracked, you can reseat the valves, replace he valve
    stem seals, clean the surface and install it on the NEW short block.
    Or get a remanufactured one from the hybrid pit.
  7. Matt Van Aken
    Batavia Il
    Because it will be a lot easier to just remove and replace then bless it and send it on its way. Lol. I’m wishing for the best.
  8. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    ?? Which engine are you talking about?
    The used engine you are driving with in you car now?
    Or the second used engine you would have in your possession ?
    Sounds like a round about way to replace a head gasket that is failing or will fail at some point.....
    Could it be we're all just yapping about an inherent fault with the design of the block/head/head gasket?
    Maybe this is a failure point regardless of 'EGR Cleaning'.......
  9. Matt Van Aken
    Batavia Il
    Nothing wrong with yapping. What would you say should be the life expectancy of a well maintained engine. Maintained meaning oil changes, spark plugs and coil packs. I live in the Midwest. Rust is the killer of all cars. I had my father’s 1987 Mazda 626 the wheel well rusted completely through so that the weight of the car was separating the wheel well from the rest of the body. 247k miles. It was burning oil. But great car.
  10. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    A friend has a Gen2 with over 600k miles before it was totaled.
    It sounds like a Gen3 engine is not capable of doing that without the head gasket being replaced at some point.
    NutzAboutBolts likes this.
  11. Matt Van Aken
    Batavia Il
  12. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    mines at 284k miles and I had to replace the headgasket. Hoping it’ll run till 600k too. (y)
  13. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Your Gen3? Did you use the FelPro head gasket?
  14. NutzAboutBolts
    1,756
    1,789
    Bay Area
    I did :ROFLMAO::ROFLMAO::ROFLMAO: rather be safe than sorry, I bought the HG kit but didn’t use the oem HG.
    Bill Norton likes this.
  15. ASRDogman
    8,069
    4,092
    Have you driven it much? How's it running?
    Any problems with over heating? Or did you fill it slowly so the coolant pushes out the air?
  16. NutzAboutBolts
    1,756
    1,789
    Bay Area
    drove about 80 miles or so lol. Didn’t need to work much this week, I’ll drive it more next week. So far the engine start up nicely, no shutter, no misfire. The coolant went down because the systems warmed up from everything so I topped it off to full.
    so far, it drives and sound like a brand new car again (y)
    ASRDogman likes this.
  17. bob11x
    bob11x Junior Member
    upstate ny
    I just posted (in the wrong forum-sorry) the death of my 2011.
    1) Did you replace the HV battery pack? No
    2) Did you replace the 12v lead-acid battery? At 217,650
    3) Did you replace the hybrid transaxle fluid? Never
    4) Did you replace the brake pads? Multiple times due to the NY salt tax
    5) Your lifetime MPG (if available)? About 39mpg - mostly highway at traffic speed.
    6) How often do you change your oil? What brand / product did you use? Approx 10k mile, factory filter, Pennzoil Platinum Synthetic
    7) How about post a picture of 200,000 miles on ODO? Never thought to take a pic - car is on its way to the scrap yard.... Almost 250k
    Almost 250k miles in 14 years. Total investment 27k purchase + 25 oil changes, 6 sets of tires, multiple sets of pads and rotors, 1 set of calipers, oil sender, 2 wheel bearings, LR ABS cable, 1 rotor dust shield, 3 air filters, 2 cabin air filters, 8 sets of wiper blades, and approx 6500 gallons of gas.
    RIP
    Well done Toyota
  18. ASRDogman
    8,069
    4,092
    Any update?
  19. NutzAboutBolts
    1,756
    1,789
    Bay Area
    I’ll post an update video on my YouTube when I do my next oil change. So far I’ve put in 1k miles with no issues.
  20. ASRDogman
    8,069
    4,092
    Nifty, thanks!
