200,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Jan 3, 2009.
  1. GneillUSF
    GneillUSF Junior Member
    St. Petersburg, FL
    Wow. Wouldn't expect there to be any detrimental effects on the battery though, right? Lifespan is much more determined by age than usage, I would think.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    That does indeed seem to be the case in general.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Here is the pic 2 fas 4 u sent me.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    I take it he slowed down for the photo ;)
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    He even took the pic while racking up the miles.
  6. 2 fas 4 u
    2 fas 4 u Active Member
    320
    353
    florida
    Thanks for posting pic seawolf, im at 290,000 might have to send another one.
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    My pleasure, we'll see if you get stuck at 299,999 as well. When you send me the next pic, I'll post it in the 299,999+ mile club thread.
  8. autoxic
    autoxic Commuter
    111
    Richmond, VA
    I hit 200K miles last weekend. Only problems were a CV joint (or similar) at 35K miles covered under warranty, and the inverter coolant pump replacement at 191K (which might be covered due to the recent recall). I am on just my third set of tires, Michelin HydroEdges now.
    1) Did you replace the HV battery pack? No
    2) Did you replace the 12v lead-acid battery? Yes, around 140K miles, to be safe.
    3) Did you replace the hybrid transaxle fluid? No
    4) Did you replace the brake pads? No
    5) Your lifetime MPG (if available)? Around 47.5 MPG
    6) How often do you change your oil? What brand / product did you use? Mobil 1 every 5 - 10 K miles
    7) How about post a picture of 200,000 miles on ODO? nope
    I am almost ready for a new Prius, but my 2004 keeps going strong.
  9. stevor
    stevor Junior Member
    Connecticut
    2005 Prius pkg 8 New: 08/15/05
    216000 problem free miles.
    Changed the tires, oil, filters, wiper blades when needed.
    Original brakes. Couple of alignments.
    Avg mpg 46-48
    Synthetic oil changes 5K - 10K
    Using 1 qt oil every 1500-2000 miles.
    Dino33ca and usbseawolf2000 like this.
  10. Road Warrior
    Road Warrior New Member
    I proudly have 265,000 on my '05 Prius and have had no problems at all until now - now I have mystery noises they are having problems diagnosing. I was hoping to hit 300k...so I hope they figure this out. Don't want to trade it in until the 2012 electric hybrids are available.
    Dino33ca likes this.
  11. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    wow. amazing. thumbs up, waayyyyyy up.
    forgive me if it's posted earlier, but on 2 fas 4u's car, what was fixed, replaced, broken, etc in order to get to this mileage?
  12. sunvia
    sunvia Junior Member
    67
    palm springs,ca
    I just got my 2010 prius in august, but got 295,000 miles from my 1983 camry....it was the first year for camry and with stick shift, i got
    up to 40mpg on long hauls.... I fully expect to get that many miles from my prius......$4 per gallon just around the corner
  13. trsandy2000
    trsandy2000 Junior Member
    29
    That is really good for any vehicle. But I think a lot of vehicle manufacturers are trying to make a better vehicle because of pressure from the public. My '93 Chevy 1500 W/T pick-up with a 4.3 is all original and it stillstarts and runs great. I have only changed the clutch and did the regular maintenance stuff and it has 237,000+ miles on it. I drive it every day in the winter snow and only to haul things and move friends in the summer. I'm sure that it will last longer than anyone really expected. I also give glory to my God for seeing it to this point.
  14. myfirstprius
    myfirstprius New Member
    columbia, south carolina
    2002 Prius
    just got my first prius and already i need to replace my catalytic converter. help!
    everyone! my mom just bought me a 2002 prius with 163,000 miles on it and i'm really excited. it's wonderful to drive and i like it better than my former (also old) car. however, the check engine light came on and the dealer told me i needed a new catalytic converter, and it would cost $1718!!! that's too expensive for me. what is this part, anyway? i looked online and some sites say i can buy a replacement part for $174. can someone explain why there's such a HUGE price difference? i'm not very car-savvy. thanks!
  15. Patrick Wong
    18,214
    6,530
    Re: just got my first prius and already i need to replace my catalytic converter. help!
    Two reasons for the low price:
    1. The correct part includes a hydrocarbon absorption chamber and valve, upstream from the catalytic converter. You will not be able to obtain a similar part on the aftermarket.
    2. The catalytic converter that costs $174 probably will not fit without a considerable amount of cutting and welding, and likely will not last more than 30K miles.
    There are a couple of reasons why you might need a new catalytic converter: either the HCAC valve has stuck (due to rust) or the catalytic converter itself has failed. If the former, it might be possible to temporarily unstick the valve and lubricate it with high temp grease. If the latter, it might be possible to cut off the old catalytic converter and weld a new aftermarket converter into the exhaust pipe. I recommend that you consult with your local muffler shops to see what they can suggest.
  16. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    2 fas 4 u sent me another picture. His next update should go over 300k miles so I'll post future updates in the other thread.
  17. 2 fas 4 u
    320
    353
    florida
    nothing was fixed, 3 set of tires, 2 set of spark plugs, 2 gear oil changes, 2 pcv, normal synthetic oil changes, and a couple of light bulbs front and rear,
    fyi my shocks on the hatch are on there way out, guess i have to pull out the old broomstick, other than that im almost at 300,000 hope the odometer goes over, if not i will trade unless they can fix it.. Most likely will try and see if the new hatchback model comes out, or i might go jetta tdi has more room, and i probably will take a 50 a week it on the extra gas but will see.
  18. 2 fas 4 u
    320
    353
    florida
    Hey guys just keeping u guys updated, im at 296,000 and counting, hopefully buy end of week should be at 300,000.
  19. gasmiser1
    gasmiser1 EV Wantabee
    107
    Cambria, CA
  20. 2 fas 4 u
    320
    353
    florida
