200,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Jan 3, 2009.
  1. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    at 210000 miles ...
    replace hv battery NO
    12v Battery YES x2
    transaxle fluid YES x3
    brakes Front disks yes...Back drums No did need it at 200000+ yet
    Lifetime mpg approx 44.2
    Oil Changes 8000miles with Mobil 1 5w30 in winter and 5-40 in summer high mileage version
    cwerdna likes this.
  2. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    The Prius made it to 200,000 miles.
    1) Did you replace the HV battery pack? - Not yet.
    2) Did you replace the 12v lead-acid battery? - Yep at 179,690 miles
    3) Did you replace the hybrid transaxle fluid? - at 106,367 miles
    4) Did you replace the brake pads? Fronts at 175,220 and rear shoes at 133,397
    5) Your lifetime MPG (if available)? - A guess at about 44 MPG. Seems to get 48 around the city streets and 43 on freeways
    6) How often do you change your oil? What brand / product did you use? every 5,000 miles at Toyota Dealer
    7) How about post a picture of 200,000 miles on ODO?
    Other things replaced.
    Water pump at 133,397
    Tyres at 34,672 - 91,704 - 133,397 - 175,220
    HV water pump at 90,062 and 106,367 (replaced free)
    Wheel Alignment - 34,672 - 63,053 - 91,704 - 133,397 - 148,164 - 175,220 (maybe over service here)
    EFI flush - 29,442 - 106,367 - 121,867 - 158,068 - 184,417
    Brake flush - 29,442 - 106,367 - 133,397 - 175,220
    Combo meter - 180,210
    Drive belt - 58,071 - 133,397
    Fred_H and Aaron Vitolins like this.
  3. nitteo
    nitteo Junior Member
    29
    Weston FL
    1) Did you replace the HV battery pack? - YES at 180k
    2) Did you replace the 12v lead-acid battery? - YES at 180k
    3) Did you replace the hybrid transaxle fluid? - non
    4) Did you replace the brake pads? non
    5) Your lifetime MPG (if available)? - fuely says 46.7
    6) How often do you change your oil? What brand / product did you use? 6k miles quick oil places
    cwerdna and SnT08Prius like this.
  4. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    2) Did you replace the 12v lead-acid battery? - Yep in 2011
    3) Did you replace the hybrid transaxle fluid? - twice
    4) Did you replace the brake pads? twice
    5) Your lifetime MPG (if available)? - 45
    6) How often do you change your oil? What brand / product did you use? every 5,000 miles Mobil 1 with OEM filter
    7) How about post a picture of 200,000 miles on ODO? Closing in on 300,000 will update in the spring if the car is still going...
    Engine water pump: last summer
    tires: keep two sets (winter and summer) winter tires last about 4 seasons (24 mos) same with all season summer tires.
    HV water pump: never
    Wheel Alignment - at least once a year
    HID bulbs: at least 3 sets over the years
    Headlight leveling sensor: repaired twice then bought a new one and installed it.
    Combo meter - January 2010
    drive belt - twice
    Hub / bearings: front - 3 times
    Power steering module: once at about 150,000 miles
    Plugs/PCV valve: At 150,000 miles
    Engine and Inverter coolant: twice
    Muffler: 4 times
    Aaron Vitolins likes this.
  5. priuslover408
    priuslover408 New Member
    San Jose, CA
    1) I have replaced battery pack currently vehicle mileage is 221,300 and counting
    2) I have replaced the 12V Lead acid Battery
    3) Not sure I havent changed it in my ownership (Transaxle Fluid)
    4) I have not replaced brake pads car still stops on the dime!
    5) my average MPG is anywhere between 43MPG and 48 MPG
    6) I change my oil every 3,000 with Mobile 1 full synthetic High mileage instead of using 5w-30 I am using 10w-30 since with age Toyotas tend to burn oil
  6. eman08
    eman08 Active Member
    360
    192
    US
    I'm getting there on my 09 model lol. Next year I should hit that 200k mark. These Toyota's runs like a clock. 1487969812665.jpg
  7. Skizza
    Skizza New Member
    Los Angeles, CA USA
    211k and runs great!
    1) Did you replace the HV battery pack? Yes 128k miles
    2) Did you replace the 12v lead-acid battery? No
    3) Did you replace the hybrid transaxle fluid? No
    4) Did you replace the brake pads? Yes
    5) Your lifetime MPG (if available)? 42
    6) How often do you change your oil? What brand / product did you use? 5k, regular
  8. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Nice. Probably about time to change that 12v battery though. Don't want to get stranded
  9. Skizza
    Skizza New Member
    Los Angeles, CA USA
    Upon reading back I realize I did replace the 12v battery at about 155k my bad.
    I'm burning oil now about a quart every 2500 miles. I've been using regular oil but I did Synthetic this time and put in Royal Purple. What's the consensus about the best way to stop the Prius from burning oil?
  10. butzodaddy
    butzodaddy Junior Member
    2004 hit 200k today. Have replaced the 12v battery once, headlights a couple times, oil on schedule.
    SnT08Prius likes this.
  11. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    You are most likely sucking oil through a gummed up PCV valve. Replacing it (a time consuming PITA) will stop the "burning" temporarily, but the root of the problem is poor oil drain back from the cylinder head. Flushes (Amsoil, Prestone & others) have bee of little help to me. IMHO, the old "Toyota sludge" of yore compounds the problem.
    iPhone ?
  12. dann kaihua
    dann kaihua New Member
    hb
    Just got my 2005 Prius with 229,000 on it and it has been running well for my first 1000 miles. We did the spark plugs a month ago and I'm fixing to do the oil next week. Mobile 1 synthetic mixed with regular has been the regime it has been used to for 150k, so I might keep that going. Previous owner did the battery pack a year ago and aux battery a month ago. I don't know about brake pads but I am going to check those too, along with the trans-axle fluid. I have been registering 45mpg. I have filled up 3 times so far but it seems that I can go only 400 miles on a tank. When I fill her up it only will take 8.__ gallons of fuel. I thought these held at least 10 and spec said 11. __? Is this normal? I do see the fuel economy pretty significantly drop when she is cold but definitely get better as she warms up. Any suggestions, anyone... for things to watch for or care I should be keeping up with?
    This is my first post on any forum,
    Thanks,
    Dann
  13. JEK
    JEK New Member
    Santa Clarita, CA
    My 2005 Prius turned over to 200,000 miles last weekend. We have only done maintenance
    ( oil, brakes, filters, wipers..) a new key fob and body work when it was rear ended. Now, it needs
    an inverter that will cost ~$5000. Should I do it or start looking for a new car?
  14. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    In my opinion, you'd have to really love a car to spend $5000 on a repair bill when the car is 12 years old and has over 200,000 miles. I'd look for a different car.
    JEK likes this.
  15. Patrick Wong
    18,213
    6,530
    Or install a used inverter which you can buy for a few hundred $s.
  16. eman08
    360
    192
    US
    Only part worth getting new is the traction battery pack. The rest, used parted out or rebuilt dirt cheap.
    SnT08Prius and JEK like this.
  17. Kuriti
    Kuriti Junior Member
    Raleigh, NC
    Hey all,
    I don't post much here, but thought I would contribute to the knowledge base since I use it. My 2006 Prius II just ran over 200K, so here is my data.
    1) Did you replace the HV battery pack? Yes. I had mine done by then Re-Involt, now Taylor Automotive in Sanford NC. They are a big one in the US and just happen to be about 40 mins from my house. That was at 100K, I checked the voltage of all the cells last week using TechStream and they are going strong.
    2) Did you replace the 12v lead-acid battery? Yes, several times. I think I am on my third. I don't like how this car eats these up. Converted to the Optima battery after the original died. On my second one of those.
    3) Did you replace the hybrid transaxle fluid? Yes, but only just now at 200K. No issues to date. It was very dark, but didn't find any metal pieces.
    4) Did you replace the brake pads? Yes, but they didn't need it. i bought them at 60K reflexively when doing my other car. Put them on a shelf until 120K, then just put them on even though they didn't need it. I did an inspection during my recent 200K 'spa day' of all the steering and drive train and didn't even think to look at them as I assume they will last the remainder of its life.
    5) Your lifetime MPG (if available)? 47mpg is what I have always gotten regardless of my driving habits both highway and city. I hyper-miled it a little when it was new, but have just driven it since.
    Maybe every 8-10,000. It is burning oil now so I need to be more vigilant on topping up. I don't do my own oil changes, so I just tell them to use the cheap stuff, not synthetic. I may end up doing the CarTalk thing and just topping up from now on, never changing it again since I assume the burning is blow-by as the rings age.
    7) How about post a picture of 200,000 miles on ODO?[/QUOTE]
    Looks like everyone else's.
    In celebration of her milestone, I gave her a spa day: new serpentine belt, transaxle fluid, coolant and inverter fluid, PCV valve, spark plugs, finally replaced the mileage meter that went dead in cold weather, got a second key and programmed it, un-yellowed the headlights with wet/dry paper. I did all the work myself, so pretty cheap and plan to do some compounding and waxing as well as a detailing of the interior once it warms up. I took the console lid off and re-glued the fabric that had slipped out.
    I am making little micro-goals now to get more miles from her. I have committed to try to get 50k more. We will see after that. I feel like Kramer running the car out of gas at this point. It's all gravy from here.
  18. eman08
    360
    192
    US
    "6) How often do you change your oil? What brand / product did you use?
    Maybe every 8-10,000. It is burning oil now so I need to be more vigilant on topping up. I don't do my own oil changes, so I just tell them to use the cheap stuff, not synthetic. I may end up doing the CarTalk thing and just topping up from now on, never changing it again since I assume the burning is blow-by as the rings age."
    Lol that's way too long between oil changes on regular oil. I'm surprised your engine didn't blow up. I use Synthetic on every 6k miles.
  19. Kuriti
    Raleigh, NC
    And yet it lives.
  20. maximusdec
    maximusdec Member
    108
    Is that an item that is suppose to commonly fail?
