200,000 Mile Club
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Jan 3, 2009.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Wow, 279k miles with the original transaxle fluid. If it has been reliable, I would say keep it and see how far it goes.
  2. Devil's Advocate
    922
    Las Vegas, Nevada
    Just turned over 200,000 miles!
    2005 Pkg #9 purchased February 2, 2005
    Date hit 200,000 miles - December 30, 2009
    • Orignal brakes
    • Transaxle and coolant change at 100,000
    • Oil change every 35,000 miles (Amsoil) 5 oil changes with a new filter every six months
    • Replaced driver side wheel bearing assembly at 100,000
    • fourth set of tires, now have Pirelli Cintarato 195/60
    • 42 MPG average over lifetime, including towing 2 and 3 motorcycles and many bicycles on the back
    • 30 cents per mile considering the total purchase price/maintenance/insurance cost
    • rear ended at about 150,000 miles (Their insurance fixed like new)
    Suzazoom and Dino33ca like this.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Devil, the next 100k miles will cost much less ;-)
    btw, how much did the bearing repair cost ?
  4. Devil's Advocate
    922
    Las Vegas, Nevada
    Did the work myself. Toyota made the work easy by requireing the whole assembly be replaced. Found the part for about $150 from Hoy Toyota in Texas. Usually the part is like $450. Haven't checked the price in the past two years though.
    Took about 2 hours because I was taking my time and wanted to be careful with the ABS/Traction control shield
  5. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    An update. Im at 238,000 miles. Replaced rear shocks last month. New spark plugs this week. Tie rod ends replaced in November. Rear wheel bearing in November or early December..cant remember.
  6. uvm1969
    uvm1969 New Member
    39
    Fantastic!
    How often do you change your oil? Do you use a synthetic?
    Thanks,
    Larry
  7. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    2nd set of Spark Plugs right? How did you know to change the rear wheel bearing? Does it get louder over time to the point you realized something must be wrong? Did MPG drop?
  8. gasmiser1
    gasmiser1 EV Wantabee
    107
    Cambria, CA
    We just bought a 2006 Certified Used Prius with 67k:) w/ nav,rear camera, 6 pack CD player,
    and traded in my 2001 Honda Insight with 284,000 miles to the same dealer.
    It didn't burn any oil! Oil changed: every 3-3,500 miles.
    New IMA controller and battery pack at 148k under warranty.
    New main computer at 210k under warranty.
    over the life of the car-
    5 sets of tires(kept inflated at 45-47 psi)
    front main engine seal.
    110k and 210 k services
    2 sets of brake pads
    It was a great car.
    Also own a 1999 Toyota Tacoma p/u with 238,000 miles, orig motor and automatic trans, doesn't burn any oil. Engine oil changed every 3-4k. Just routine services done.
  9. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Uhm what warranty?
  10. gasmiser1
    107
    Cambria, CA
    I was talking about the Insight warranty items replaced. Honda had a great warranty for items I had replaced.
    Hopefully, the newer Prius will keep going past 200k miles like my Tacoma truck has done so far :)
  11. nikfish
    nikfish New Member
    Georgetown Ontario
    2001 Prius
    Our 2001 has 371,000 km on it (about 260,000 miles). And it looks like we're finally putting her out to pasture. She's worth about $2000 on a trade in at best, and she needs about $2000 in repairs for wheel bearings, leaky struts and sway bar link connectors.
    I'm gonna miss her.
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Awesome. Mechanical things will break down. Are you still on the original HV battery?
  13. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Why don't you donate it to a High School Trade school? I'd bet they'd love to have a hybrid to tinker around with. Plus maybe you get a tax deduction?
  14. nikfish
    nikfish New Member
    Georgetown Ontario
    2001 Prius
    I'm still on the original HV battery.
    Our A/C died a few years ago, and on very hot days when traveling on the highway we had the hybrid warning light go on. We were told the first couple times it was a weak cell in the battery (different cell each time). The last time it went off in August '08 we figured we'd save the cost of having it checked out, and it's run fine ever since with the little yellow check engine light on.
    I've posted her story on Toronto Craigslist cars section. I'll give it a couple of weeks to see if I get any bites, and if not, I might take her to a Prius specialist to see if she can become a parts donor.
  15. green taxi
    green taxi New Member
    missoula,mt
    Yes !! 06' over 200k -Wheel bearing @87K, inverter coolant pump?@197K. Uses a half quart of oil every 4k.
  16. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    50,000 more miles for me.
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I am approaching 120k miles, 80k more to go. My car only accelerate when I intended it to.
  18. joe350gt
    joe350gt It's too windy here...
    40
    38
    Wichita, Ks.
    My Silver '05 is at 180K right now..should hit 200 by late summer. Full report at that time!! But it has been the best car I've ever owned as far as reliability goes!
  19. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    Only 191,000 miles to go!
  20. bwilson4web
    16,549
    Daryl's 2001 Prius, 250,000 miles:
    Swapping the traction battery.
