200,000 mile seafoam?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pieter, Apr 25, 2017.
  1. Pieter
    Pieter New Member
    Colorado
    I have a 2004 gen 2 prius that is soon to have its 200,000 mile birthday and I was wondering about the pros and cons about seafoam. The engine is a oil burner and definitely has some good carbon buildup and valve tick. I have read that putting seafoam in the gas will not do too much harm, but I was wondering more about adding it to the crankcase and doing a air intake seafoam soak as well.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    How are u going to do the air intake?
  3. ETC(SS)
    7,560
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    You should NOT put any solvents in with your crankcase oil.......especially on a high mileage engine.
    The sludge it loosens might do more harm than good.
    In the gas should be no problem. That is what it was originally designed for. Probably won't do any good either.
    In general, a little carbon buildup over 200K miles isn't the disaster that it's made out to be either.
    And pouring stuff down the intake might do more harm to the sensors than good too.
    The process is sometimes good for stuck rings but if there is a ring problem it is probably wear and not sticking.
    Pieter likes this.
  5. Kenrico
    Kenrico Member
    82
    52
    My 203k 2007 was burning a fair amount of oil , but when I switched to 0-20w Toyota syn oil from Mobile one syn it uses alot less between changes .
    Kenny
    Prius_Angie likes this.
  6. timmyjane
    timmyjane Junior Member
    87
    SC
    Some of the oil cleaners say that if you are going to add it to the oil on a high mileage engine the oil pan should be removed and cleaned first.
  7. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Interesting, had planned on moving up a grade from the Toyota 0-20w as summer is near.
    Now I need to research this again.
    Also thought most of my oil usage was from higher freeway speeds.
