2000Mile Winter Road Trip Recommendation
Discussion in 'Gen 2 Prius Main Forum' started by Tim Wang, Dec 7, 2014.
  1. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Are you kidding? Change transaxle fluid after a single trip through the mountains? How often then, would you suggest mountain dwellers change THEIR fluid?
  2. Tim Wang
    Tim Wang Junior Member
    33
    Central Illinois
    Thanks for the info.
    I actually did a test with my Garmin GPS and the car odometer for a leg of pure highway.
    The GPS counted 152.4 miles and the odometer showed 154.4.
    So doing the math: 2/152.4*100, I got 1.31% of error. I guess this is tolerable...
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Interesting maps...watched a Route 66 show the other night and the bottom map is really the original Route 66.
    When I was a kid 100 years ago I drove from Florida to LA in a station wagon with my beloved Siberian Husky Fred. Went over those same mountains. Holy shite!!!
    That and Texas never ever ends. By the time El Paso appears your just begging for it to end. 100's of miles of nothing. I saw this big cloud miles away....kept getting closer and closer...had no idea what it was...till I started hearing things hit the car. My first sand storm. It was a big one. Pulled over. Filled the car up with dust. Scared the crap out of me. Ruined the paint and made the car overheat within 20 miles. Had to change the oil.
    Good times.
    Tim Wang likes this.
  4. fuzzy1
    10,684
    That much difference in that direction is actually a bit too much, and would draw the attention of the sharksXXXXXXlawyers. Are your new tires the same size as the originals? Have you rechecked this measurement? Or tried a different reference such as highway mileposts (which has other potential problems)?
    #24 fuzzy1, Jan 27, 2015
  5. Tim Wang
    33
    Central Illinois
    The tires are the same size as the original, I checked the markings on the side wall. all the tires are overinflated (to 41/39), if that matters at all.
    I have not had any chance to recheck the measurement yet, but I will try different things.
  6. fuzzy1
    10,684
    With modern steel belted radials, that should not make a significant difference. And even on the older bias ply tires, it would bias the error in the opposite direction.
    Try some rechecks or other measurement types when convenient. For me, the really convenient conditions don't happen very often.
  7. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The gen2 Prius oil change interval varies by country. In the UK and Europe it is and always has been 10,000 miles. This is of course using synthetic oil.
    John (Britprius)
  8. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Glad you had a good trip with your Prius.
    The uphill lag you experienced in the mountains had less to do with the Prius and more to do with the amount of oxygen available to your car and all other cars at this altitude. The pinging and drag is your car choking because it doesn't have enough oxygen. If you're simply traveling through, it's not a big deal. If you LIVE in the mountains, there are things that people do or did - like buy different octane gasoline or changing their engine timing - to deal with this.
  9. fuzzy1
    10,684
    Huh?
    All my pinging in past cars happened at low altitude, not high. Up in the mountains, all those cars could get away with significantly lower octane than at sea level, which is why 85 octane is often available up there. Different octane isn't going to fix the dragging issue either.
    And owners needing to change timing in a modern emission-controlled engine? Not any more.
  10. Yakoma
    470
    125
    sss
    Which is why I said DIFFERENT octane and not HIGHER
    Which is why I said DO OR DID...are there not cars on the road without electronic ignition?
    Read much?
  11. fuzzy1
    10,684
    Octane-related pinging is fixed by using higher octane, not lower octane. If a given fuel won't ping at low elevation, it won't ping at higher elevation either, so there would be no performance benefit to changing it.
    The last U.S-market cars without electronic ignition were made long long before the first Prius was invented. The 'DO' portion of you comment is long obsolete, so suggesting a timing change to a Prius owner is absolutely useless.
    I'd ask that of you. But I'd be more interested in whether or not you drive much at high altitude.
  12. Yakoma
    470
    125
    sss
    Fuzzy...read and learn. I don't think anything I stated was incorrect. But if you inferred something incorrectly, I'm sure you'll let us all know.
    And I wasn't making a recommendation to any Prius driver. I was simply explaining the phenomenon that he was experiencing at high altitude and trying to explain that it was fuel/air mixture related, and not HV battery related.
    No, I don't drive much at high altitude but I have driven some.
  13. fuzzy1
    10,684
    Never heard of that site before, so they don't have a track record. It is also too generic and oversimplified, partially wrong, advice from a prior era:
    While carburetors continue on those smaller engines, they pretty much vanished from the automotive market in the late 1980s. The last stragglers vanished from the passenger car market in 1990, and from the light truck market in 1994.
    Step up a couple levels and search PriusChat or CarTalk for 'octane vs altitude' or similar keywords, and you could learn far more.
    Octane and Altitude Revisited
    fuel grade
    Fuel 85 87
    Gas question: 85 or 89?
    prius climbing to 9,000 feet questions
    Mountain Climbing slowed to a grinding hault.
    Fuel octane at high altitude
    Gas Octane & High Altitude Areas
    octane rating
    What is the effect of altitude (>10,000 feet) on a car's performance
    That is not how I take the instant replay:
  14. Yakoma
    470
    125
    sss
    There it is. Thanks for enlightening us.
    Full context of my remark:
    I know the OP doesn't live in the mountains - he was passing through, so I'm not speaking to him directly. I'm using YOU in a general sense. I can see how you misunderstood that - though I doubt many others did.
    OK. Now that you've demonstrated that I'm not nearly as clever as you, I guess you win. Congratulations.
    If anyone else would like to ignore Fuzzy1, simply click on your name above, and then People You Ignore - type in Fuzzy1, then click Save. It's a great feature...Fuzzy1's posts no longer appear on your screen.
    By the way, Fuzzy, that guy you're yelling GET OFF MY LAWN!!! at, he's just the lawncare guy. Leave him alone and eat your yogurt. It'll be naptime soon.
  15. fuzzy1
    10,684
    No, that is less than half the full context to which I replied.
  16. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    if you think Texas is bad never (and I mean never!) drive through Kansas on I-70. 500mi of nothing but flat open space, cows, occasional wind mill farms and constant Wizard of OZ museum billboards. There've gotta be at least a couple dozens of them alone the route.
    At some point you start wonder, why this road has turns every few miles? there is nothing there to obscure it.
    edthefox5 likes this.
  17. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I'm curious why you didn't just fly. Accounting for gas, an oil change and incidentals, you're looking at roughly $400 and 8 days for travel if you slept in your car. If you include motels, that's likely more expensive than airfare.
  18. edthefox5
    10,096
    4,837
    Clearwater, Florida
    .[/QUOTE]
    At some point you start wonder, why this road has turns every few miles? there is nothing there to obscure it.[/QUOTE]
    Wow.
    Texas was like a bad joke. You would see something...anything...coming up..and when you got there it was just an intersection with nothing else there. The other roads of the intersection just went on for miles with nothing.
  19. cyclopathic
    3,292
    547
    2014 Prius c
    He is probably looking for experience.
    This is obviously in the past, so the comment is too late. Hopefully you had a good trip, and if you bailed out well it was probably a good thing.
    I had driven/rode bike coast to coast across country several times. Out of major East-West routes had been on I-90, I-80, I-40. Had been on I-10 but not all way through, so can't comment on I-10. And all trips were in during warm period of time (though the was a trip to Seattle in Dec)
    I-70: really great in summer. Very scenic west of Denver; Cottonwood canyon is a marvel, and there is alot to see alone the route. Not sure I'd like to be there in the winter, there are might be issues with snow. If I were not in the hurry, I'd make alot of side trips Rocky Mount NP, Mt Evans. Several 11,000'+ high passes on US 6 which runs in parallel. If time permits instead going straight to Salt Lake City and dropping down on I-15, I'd take UT-24/UT-12 and cut the corner from Green River to St. George. Best red rock country you'd see in lifetime, right in front of your eyes!
    Now the bad thing about I-70: Kansas. 500mi of nothingness (look my comment above). After crossing Kansas on I-70 twice I swore not to do it ever again. Luckily there is alternative: you can take I-80 - I-76 to Boulder, and then US-34 through Rocky Mount NP to I-70. But it will be closed in winter.
    I-44 from St Luis to OKC is not bad, and if you planning a stop in Amarillo, there is Palo Duro, the 2nd biggest canyon in CONUS just a few miles south. You will get to camp in the canyon. Usually busy during summer, so it is recommended to get your camp site in advance if you come late. There are a couple hundred miles of prairie land to cross in TX/east NM, but nothing as bad as Kansas. There are things to see alone the route like Grand Canyon, Petrified Forest, Sedona, Blue Hole in NM, etc The most pristine section of Route 66 btw Seligman and Kingman; the one pictured in Disney's Cars.
    One of the good things that I-40 does not go as high as I-70. Flagstaff is at 7,000' where Vail pass is ~10,000', so sn
  20. Tim Wang
    33
    Central Illinois
    I choose to drive instead of flying for a few reasons. First, as cyclopathic noted, I want to experience some long road trip like this, I have never done anything like it before, and it turns out nice. Second, flying is more complicated for me because I live away from a major city (Chicago) so I have to make transfers. Also I need wheels in LA.
    I end up spending a total of 7 days instead of 8, and I could make it easily in 6 days if I did;t have to stop at Palm Springs.
    Lastly, no, it is not cheaper to fly than drive. Im not sure in terms of environmental impact but in terms of cash money, at the time I traveled, the ticket from ORD->LAX was 400 bucks one way (Christmas you know), and I spent 293 dollars total in gas, round trip (could save much more, note to self, use gas buddy trip planner next time) and a 40 dollar oil change. I don't consider the wear of the car part of the cost. A car is meant to be driven. Plus, the experience is priceless! Screen Shot 2015-01-30 at 9.38.39 AM.png
    #40 Tim Wang, Jan 30, 2015
    mmmodem likes this.
