2000w Inverter Install
Discussion in 'Prime Accessories and Modifications' started by Insighter, Mar 29, 2018.
  1. Insighter
    Insighter Active Member
    409
    287
    SoCal
    I'll have to ask my installer, but I'm guessing they sized the fuse to the inverter. I bought the inverter on my own and brought it to them, and asked them to install wiring to it. So I'm guessing the 300 amp fuse matches the inverter. Depending on what my installer says, and what the inverter company says when I call them, I'm likely to have it swapped for a 90 amp fuse (based on what folks have said in this thread).
    Andyprius1 likes this.
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Nice job, excellent posts, TY Please don’t take this as a criticism but I wouldn’t want anything close to even 50- 100 Amperes running thru the 12 Volt battery, the inverter or my house. To insure this, when I tested my 1000 KW inverter for a possible electric grid failure I always had in mind to put only minimum loads on the car, inverter, 12V battery and probably shutting off at night. Basically this would give min usage of TV, refrigerator. lighting, and computer charge. You may have the same thing in mind. Incidently,, the Prius only requires milliamps from the 12V to go into Ready, so why even 100 Amp fuse. Perhaps in case of voltage surges.....
    anyway I presume the Toyota EEs know better than I.
    Primefan and Merkey like this.
  3. Andyprius1
    2,327
    859
    Cool CA
    The possibility of too much current conducting can exist and cause a fire by continuous short circuit, the thicker cables insure longer and better short circuitry as well as the higher than battery designed 12 Volt fuse. (100Amp ) Higher fuses don’t give better protection, lower fuses do. The rule was when I was in the field, if you don’t have the right size fuse, go to a lower one.
    Anyway again TY for your post.
    Insighter likes this.
  4. Andyprius1
    2,327
    859
    Cool CA
    Since both the inverter and 12 V are fused at the design levels you may not need that 300 Amp at all.
  5. Andyprius1
    2,327
    859
    Cool CA
    Which is why it’s critical to keep the load LOW
  6. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    I don’t get what this is used for.. I read it all but I’m confused.. can you simple it down in one sentence for me what it does :oops:
  7. Andyprius1
    2,327
    859
    Cool CA
    How were you planning to use this?
  8. Insighter
    409
    287
    SoCal
    Thanks for the input. I appreciate it and you can rest assured am going to look into it fully. I originally only wanted a 1000w pure sine wave inverter, but I couldn't find one online that had an ETL or UL listing, and that's very important to me. I hadn't thought much about what load I'd put on the inverter. It would probably only be a refrigerator, computer and TV.
  9. Insighter
    409
    287
    SoCal
    The installer did say that fuse would probably never come into play. I was surprised when I saw it was 300 amps. I'm going to look into all of this thoroughly. One good thing is that I am the only person who will ever use this, and I'll never put much of a load on it. Still, I want to understand all of the ins and outs, and I want a reasonably-rated fuse there that would come into play at a reasonable point should that need ever arise.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Agreed, lower Watt draw = lower Amp draw.
    Rob43
  11. Insighter
    409
    287
    SoCal
    I'll use it very occasionally when the power goes out. I don't think I'd ever have more than a refrigerator, TV and computer plugged into it (maybe an LED lamp, too). I suppose I might use it camping, but, then again, I haven't gone camping since I was a kid (like 1984, so that isn't likely).
  12. Andyprius1
    2,327
    859
    Cool CA
    You made a good decision with the pure sine wave, and nothing wrong with a 2000 KW inverter either. If not sure of load, buy a KWHr meter to measure AND before connecting to your house, Pull the main cicuit breaker, you don’t want utility power interfering with Prius Power.
  13. bisco
    52,861
    a number of people use their prius as a generator in a power outage, or for camping and the like.
    Merkey and Insighter like this.
  14. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    Ooooooooooh! That’s cool I never knew that was a thing :eek::eek::eek:
    Estew808, bisco and Insighter like this.
  15. Insighter
    409
    287
    SoCal
    Oh, I'd never connect it to my house. I have some 10 and 12 awg extension cords. I do have a Kill-A-Watt meter.
    Merkey and Andyprius1 like this.
  16. bisco
    52,861
    a lot of people do, and if you want to go all in, you can get inverters that run off of the hybrid battery, but it gets way more complicated.
  17. Andyprius1
    2,327
    859
    Cool CA
    OK have you tested this setup?
  18. Insighter
    409
    287
    SoCal
    The way I understand it, you could use an inverter with any car. The problem is that to prevent the 12v battery from depleting, you'd have to leave your car running constantly. That would waste a lot of gas as the inverter would be using only a small fraction of the power generated by the burning of the gas.
    If I understand correctly, the Prius is particularly well-suited to running an inverter because, IF you leave your Prius in the "READY" mode, the hybrid battery will maintain the 12v battery, and, whenever the hybrid battery gets low, the Prius will automatically run the gas engine long enough to recharge the hybrid battery. What's great about that is that the gas engine doesn't have to run all the time, and, when it does run, it is a small, efficient engine and the electricity it generates is stored in the hybrid battery, meaning less waste. Maybe others can comment on this, but this is my understanding.
  19. Insighter
    409
    287
    SoCal
    Yes, they tested it at the shop, and I tested it here. I mean, I haven't run it for any amount of time, if that is what you're asking.
  20. Andyprius1
    2,327
    859
    Cool CA
    You understand perfectly. Try connecting from the garage to the house, any outlet, 110 V of course.
    Main CB disconnected. When “they” tested your setup did they disconnect the main CB.
