2001 engine just threw a conrod
Discussion in 'Generation 1 Prius Discussion' started by Itsmeonprius, Jul 6, 2018.
  1. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Well that's it! Cylinder no4 just snapped it's conrod and put a couple of holes in the housing. Time for an engine change.
    So the question is, can I just get another engine only or do I need to make sure I get the ecu to go with it?
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I guess I'd use all the sensors off the old one, just to be sure. But a good used engine should just shoehorn right in. No different ECU required.
    That's gotta be the rarest failure I've heard of. It would be interesting to figure out what happened.
  3. ETC(SS)
    7,550
    17 years, huh?
    Man.
    They just don't make them like they used to.........;)
    Good Luck with the hunt!!!
    Let us know how it turns out, and if you're going to swap out the motor yourself or pay it done.
  4. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    You don't need a any ECU for the swap.
  5. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Good good. Yes nice suggestion about the sensors. From one of my other posts, this engine has had a misfire on no4 for sometime before I got it. I figured out it was the injector so I'm not sure if this has helped to kill it. And yes I will be doing the work to change it. I've done conventional engines so I just need to factor in isolating the HV battery.
  6. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Update: I've found a second hand 2002 engine with only 58k miles! Warrantied and on its way to me. Fingers crossed the courier doesn't drop it......
    Brian in Tucson and Raytheeagle like this.
  7. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
  8. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
  9. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
  10. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
  11. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Now the long slog of remembering where everything goes ha ha 20180820_165732.jpeg
    Mendel Leisk, Raytheeagle and Naurill like this.
  12. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Raytheeagle, m.wynn and Mendel Leisk like this.
  13. Mendel Leisk
    42,343
    Congratulations (y)
    Me fix:
    Brian in Tucson and Itsmeonprius like this.
  14. Mendel Leisk
    42,343
    If you want to copy and paste the above into your post, afterwards I'll request to the mods to delete mine.
  15. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    App doesn't want to let me do it. Just leave it as it will keep people amused when they have to turn their phone or monitor to see it. Thanks anyway.
  16. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I wish I could work that fast. Congrats on getting it running.
    Itsmeonprius likes this.
  17. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I bought a used engine for my Dodge pickup yesterday. Pretty excited, mine's a 96 with 256,000 miles on it, the newer one is an 01, with only 104,000. Guess what I'll be doing this fall? For now I'm just going to overhaul the seals and gaskets, make it tight.
  18. Pri-Eye
    Pri-Eye Junior Member
    34
    Metro Detroit
    2001 Prius
    Awesome job!
  19. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Yee Haa. That's my gen 1 back on the road. Just test drove it and it feels great. Actually feels better than before.
    Brian in Tucson likes this.
  20. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
