2001 Main Battery Problem
Discussion in 'Generation 1 Prius Discussion' started by DOLLABILL, Oct 26, 2012.
  1. DOLLABILL
    DOLLABILL New Member
    2001 Prius
    Ok just bought this 2001 Prius One Owner new car trade in it sat for a month without moving It needed a boost to start it then the three lights on the display lighted up PS+Main Batt + a pic of the car with a ! in it ! is it just from sitting so long and the Battery is low ? If I use an OBD and reset it will this and a charge take care of the problem ?? Thanks in advance
  2. bwilson4web
    16,551
    Did the engine turn over and run?
    If not, you are going to need a Prius aware, OBD scanner to read out what is going on.
    The easiest way to reset all Prius codes is to disconnect the ground wire for a minute or so. In theory, the run-down 12V battery might have put the control computers in an indeterminate state showing false errors . . . but very few people are that lucky. Still, disconnecting the ground eliminates that hypothesis.
  3. DOLLABILL
    2001 Prius
    the engine starts and runs but after say 5 miles the brake light comes on and if i pull over shut it down in a few minutes all was fine enough to get home My OBD gave these codes 3006,3011.3012
  4. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Looks like it's time for a new traction battery.
    bwilson4web likes this.
