2001 prius(blown head gasket)
Discussion in 'Generation 1 Prius Discussion' started by ChrisPDXPrius2001, Mar 11, 2023.
  1. ChrisPDXPrius2001
    ChrisPDXPrius2001 Junior Member
    16
    portland
    2001 Prius
    Here is the deal. My 2001 Prius has a blown head gasket. The mechanic found hyrdocarbon in the coolant. I have experienced misfires in cylinder 1 and 4. I had the ignition coil 1 and 4 replaced along with all spark plugs at the end of November 2022. I am slowly burning coolant, but at least my car is not overheating. He did not recommended that I replaced the head gasket due to age and mileage of my car(currently sitting at 258k). Car is starting to slightly misfire again and check engine light came on last night. It's still drives, but albeit a little rough at the moment.
    My question to y'all is, for a last ditch effort, do you recommend a good head gasket sealer that I could try to extend the life of my car before I just give up on it and send it to the junkyard. It's obviously not worth the money to replace the head gasket or replace the engine. As far as I am aware the oil is not mixing with the coolant. My tags are good until Jan 2024. So, I don't need to worry about passing inspection for awhile.
    What you guys think? Blue Devil, Bar's Leak? Or just keep driving it as is, replacing coolant as needed, until it finally dies.
    Thanks in advance!
  2. Tombukt2
    Tombukt2 Senior Member
    13,851
    2,515
    Durham NC
    1NZ is still used in today's Prius C. The make a hi HP rally edition of this engine . They are also relatively inexpensive engines so and plentiful so price gouging shouldn't be a thing. You can try anything you want as far as sealers goes it sounds like your head gasket is very minimal so they're all kinds of sealers you could try and if you do it in moderation and don't try to flood the thing with sealer that is you could probably get it to hold off for a while whatever I'm guessing the car doesn't warrant an engine replacement as it has other problems interior age all of that maybe you can't bring yourself to put money in something so old I get it no problem You could just get an old Corolla and run to 500,000 and get about 13 miles to the gallon less but none of the headaches per se.
  3. Stock808
    Stock808 Junior Member
    Hawaii
    2001 Prius
    Try K-Seal, little blue/orange bottle. Around $15.
    I used it on a Toyota Yaris years ago, It managed to keep it going for another 4 years, probably longer if I hadn't traded it in at a dealership. Who knows it might be still good till this day.
  4. Tombukt2
    13,851
    2,515
    Durham NC
    Yes that's the brand I'm talking about .my BG guy gave me 2 bottles. Just found it this AM cleaning up . It's about 4 yrs old never used 2 bottles
  5. ChrisPDXPrius2001
    16
    portland
    2001 Prius
    Right on. Thanks for the replies.
    I drove up to AutoZone and bought the K-Seal. My question before I use it is do I remove the radiator cap and pour it in there or do I pour it into the coolant reservoir? The instructions on the bottle only says "pour into where you normally add coolant". I've seen conflicting info doing research online so just wanted to ask. Since my leak is very small do you think using 1/4 of the bottle is a good idea?
  6. Tombukt2
    13,851
    2,515
    Durham NC
    Look the stuff up online see if they have a website with any videos or anything you can look at My worry here is that it's going to be tough to get the Prius nice and hot which I think most of these sealers like that to be a thing initially I could be wrong but generally I would think they would want you to be able to get up to some kind of decent temperature and in the recent weather we're having here in the southeast that takes a little bit of doing at least in my Gen 2 I'm not sure about a Gen 3 but it takes a minute to get them warm and then you want to get it into the system as quickly as possible so adding it to a radiator jug or a degas bottle or whatever you're going to call it. Seems not the thing to do but it looks like it might be your only option in some cars. If I had to do something like that I would take it out for a heck of a drive right after I put that stuff in to get it circulating and heading to the leak probably give it an hour's worth of driving something like that
  7. ChrisPDXPrius2001
    16
    portland
    2001 Prius
    I am doing the K-Seal treatment right now following this guide I found online. I will post updates.
    I put my car in "inspection" mode to keep the engine running continuously and I am only using about 1/4 of the bottle.
    #7 ChrisPDXPrius2001, Mar 14, 2023
  8. Stock808
    Hawaii
    2001 Prius
    Pouring into the radiator cap would have been best, also I would just have done the whole bottle. This stuff works fast.
  9. ChrisPDXPrius2001
    16
    portland
    2001 Prius
    I am going to do another cold/heat cycle. Waiting for my car to cool down. I will add a little bit into the radiator cap on the next cycle.
    UPDATE
    I used slightly more than half the bottle. Per the instructions on the K-Seal bottle is states to use half the bottle if your cooling system is 5 US quarts or under. The 2001 Prius coolant capacity is 5.18 US quarts.
    I am continuing to run cold/heat cycles at the moment.
    #9 ChrisPDXPrius2001, Mar 14, 2023
  10. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    OK, that's a new one on me: "inspection mode." The only way I know of to keep the ICE running is to have "MAX A/C" engaged. Is there another way?
    Bruce Berquist likes this.
  11. Jakob
    Jakob Junior Member
    69
    Wisconsin
    2003 Prius
    Yep, Inspection Mode is described in repair manual volume 1 in the Introduction section. It's one of those things you can activate with a bizarre sequence of operations from the driver's seat.
  12. ChrisPDXPrius2001
    16
    portland
    2001 Prius
  13. Trombone
    389
    130
    2002 Prius
    Many thanks! In case I ever need to do this, now I know.
  14. velosolex50
    velosolex50 Junior Member
    Isle of Man
    2001 Prius
    I used k-seal to fix some weeping core plugs in a rebuild, and it worked within seconds.
    I tried it on a daihatsu 3 cylinder with a blown head gasket, and it didnt seem to work, but after I sold it, the new owner later told me he had had no problems! Remarkable.
  15. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    Hope this works, but if not, don't give to the dismantler without salvaging the catalytic converters assembly and hybrid battery. The rest is just scrap metal value.
  16. ChrisPDXPrius2001
    16
    portland
    2001 Prius
    *UPDATE*
    It's been a little over a year since I did the k-seal treatment to fix my head gasket leak and my car is now at almost 267k(at the time of repair was 258k). So, the k-seal did in fact work. Almost 9k miles later. Hope this post helps others that are in a similar situation.
  17. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    For my Gen1, I have found no real need for inspection mode. Just engage max a/c and put the tranny in B at lower to no speeds. The engine will rarely shut off when engaged in the B position. If inspection mode is required for maintenence then Toyota should not have required a "chicken dance" to engage it.
  18. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    Inspection mode disables traction control as well.
