2001 prius has ac but no heat
Discussion in 'Generation 1 Prius Discussion' started by Lakisback35, Sep 25, 2024.
  1. Lakisback35
    Lakisback35 New Member
    Massachusetts
    2001 Prius
    Hi everyone, I have a 2001 prius with ac but no heat, it hasn't had heat since I bought it nearly 4000 miles ago. I checked the two metal hoses for the heater core by removing the glovebox (pictured) and they read about 89-95°f but beyond that I have no idea what to look for. If there's diagrams I could look at or ideas anyone has they would be greatly appreciated!
  2. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    check your coolant level. No coolant, no heat.
  3. Lakisback35
    Massachusetts
    2001 Prius
    Coolant level is normal on the engine side.
  4. ChapmanF
    18,982
    Any trouble codes from the HVAC system? In a gen 1, you won't see those on an OBD code scanner, but only by counting the blinks as described here (scroll down to the heat/air conditioning system part).
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Also, you can look on the other side (driver's side) of the HVAC box, just by sticking your head down where your feet go, to check whether you see the white linkage of the temperature blend door move from one end to the other as you twist the temperature dial from above the current cabin temperature to below.
