2001 Prius Help - code p3000
Discussion in 'Generation 1 Prius Discussion' started by dlfoster, Dec 15, 2017.
Tags:
  1. dlfoster
    dlfoster Junior Member
    16
    Georgia
    2001 Prius
    Hi everyone, It's good to be here with my first post and hopefully someone can help with the problems I'm having with my 2001 prius.The other day I replaced the hv battery ecu that's located within the battery and it seems to have cleared the problem that I was having with code p3009. however when I go to start the car it starts for a brief time (15 seconds) and then the red triangle comes on with the brake light on and the engine revving really fast and the main battery symbol (between the car and the ps symbol) comes on saying problem. Once that happens I turn the car off to not damage it and then it won't start again. I have the mini vci and techstream to check what codes it is giving and it seems that the codes now are p3000 and c1259. I'm kind of at a loss for what to do because with the old hv battery ecu installed the car was running and charging/recharging the hv battery as I drove it around to keep it lively but now I can't really do anything with it. Thanks for your time and efforts.
  2. Prodigyplace
    12,712
    11,848
    Central Virginia
    Andyprius1 likes this.
  3. ChapmanF
    19,016
    A lot of links you find online about the C1259 are nothing but distractions. C1259 isn't a primary code. It's a code the brake ECU sets when it gets a note from the HV ECU that there's a problem over there. You don't really "fix" a C1259, so much as you mostly ignore it, follow up on whatever code is really from the HV ECU telling you what the real problem is, and when you fix that, the C1259 takes care of itself.
    In this case, there's another step like that: P3000 is a code the HV ECU sets, when it got a note about a problem from the Battery ECU!
    But you mention having Techstream, so it might be useful to touch the "snow" icon next to that P3000 to get the freeze-frame data ("freeze" frame, get it?), and see what 3 digit INF codes go with it. Seems like about four different possibilities. You could also look at the live data list from the battery.
    -Chap
    Dxta, Andyprius1 and Prodigyplace like this.
  4. dlfoster
    16
    Georgia
    2001 Prius
    Thank you both for the help so far. For the p3000 code I initially had the code of p3000-389 and then out of nowhere, and i'm guessing because it warmed up a little bit outside because it was really really cold out before, the car actually started to run and stayed running. However the problem came back once again but this time it was the code p3000-123 with a p3006 as well. I know that means the voltage of the cells is a little off but looking at them on the live data it didn't really seem low anywhere at all. Any suggestions as to what I can try now?
  5. Prodigyplace
    12,712
    11,848
    Central Virginia
    A Prolong reconditioning kit or, at least, a Prolong battery charger& harness from Hybrid Automotive may be able to balance the cells. @Raytheeagle or the owner @jeff652 could comment further.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    The first thing you need to do is look at the freeze frame data for the 3006 to see what information locked in when the battery coded.
    For the P3000-123 read here:
    https://static.nhtsa.gov/odi/tsbs/2014/MC-10061270-2273.pdf
    Basically says don't worry about it, as it's triggered by the Battery ECU fault. Focus on correcting the battery fault.
    For the battery fault P3006:
    Gen 1 Prius Battery Failure, P3006 - Luscious Garage | Hybrid Specialists
    These guys are pretty much the go-to garage for Prii. I doubt there's anyone available who knows more than they do.
    Additional info:
    P3000 – Toyota Prius Hybrid Fault Code Diagnosis
    P3000 – Battery Control System
    The P3000 fault code relates to the battery control system in the Toyota Prius. If this code is displaying on your vehicle, it means that there is a problem with the HV battery ECU. The problem can be caused by several different sources, making P3000 a very generic and common fault code.
    The P3000 fault code will often be accompanied with a suffix (for example, P3000-388) to help with diagnosing the source of this problem. The definition of these suffixes (or INF codes) can be found below:
    P3000-123
    Abnormal signal response from the battery ECU, often associated with a high-voltage battery system malfunction.
    Possible causes include: HV battery system, Battery ECU
    P3000-124
    Abnormal signal response from the battery ECU, commonly associated with a blown fuse.
    P3000-388
    Discharge Inhibition Control Malfunction. This code is triggered when the battery’s state of charge decreases due to the vehicle being left in N position, running low on fuel or a malfunction occurring in the HV control system.
    Possible causes include: HV control system, HV battery assembly or a fuel shortage
    P3000-389
    Drop of battery voltage detected by the battery ECU. This code is output if the HV battery is depleted or the battery control system malfunctions.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Can you post the freeze frame data you have collected. While the spread you report seems small, it can make all the difference.
    Prodigyplace likes this.
  8. Prodigyplace
    12,712
    11,848
    Central Virginia
    Thanks, guys
    Raytheeagle likes this.
  9. dlfoster
    16
    Georgia
    2001 Prius
    sorry it took a little while to get back to here but this is the freeze frame data for p3000-123 that techstream gave me.
  10. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    Per post #6, the P3000 is not where we want to focus. The first thing we need to do is investigate the P3006.
    Do you have the freeze frame data for the P3006? I think that will provide us with much better clues, as it will have all the HV battery block info.
  11. dlfoster
    16
    Georgia
    2001 Prius
    now the p3006 has gone away but if it happens to come back i'll post the freeze frame data for it.
  12. dlfoster
    16
    Georgia
    2001 Prius
    oh happy day, the p3006 has returned so here's the freeze frame data for it. now the p3009 has come into light again and I have the freeze frame data for it as well. for the p3009 I know it'll say 8.88 on the voltage of block 7 but when I check it again the voltage goes back up to 12.29 so it seems inconsistent and i do know that is still too low. I also have replaced one of the cells in that block before so now I wonder if it's the other cell that has gone bad in the same block or if that cell I replaced has messed up or if it's something else altogether. I do know that p3009 is a leak detected so maybe a cell blew up. once again, any insight is greatly appreciated. Thanks guys.
  13. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Your pack looks out of balance:(.
    Do you have a way to balance it or the individual cells?
    Did you balance the cells you swapped in? What were their date codes?
    Keep us posted (y).
  14. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    You have significant issues with blocks 6 and 7, or the measuring of block 6 & 7. Focus your energy there. Check the sensor wires and the plug connector. What voltages do you get when you use a multimeter to check them?
  15. dlfoster
    16
    Georgia
    2001 Prius
    I'm not even sure how to balance the cells in the pack and no i didn't balance the cell (I only put in one) before I put it in. How would I find the date code? also, how would you recommend I go about balancing them? I have an imax b6 charger like here
    IMAX B6 50W 5A Charger/Discharger 1-6 Cells (GENUINE)
    but i'm not sure how to use it properly
  16. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Just to be clear, this means there has been a HV leak to ground detected, not a physical module is leaking, although one can lead to the other. So check for traces of electrolyte in the case. If these are original Gen 1 modules, they were known for leaks. The presence of leaking electrolyte enables a path for the HV to leak to the chassis ground, something that, I think you'll agree, is highly undesirable.
  17. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    dlfoster,
    Look at the photos you provided. Certain things jump out as being obviously jacked up. Like Blocks 6 and 7. Your problem most likely stems from the items discussed in post 14. Although not ideally balanced between all the other blocks, something with 6 and 7 or the sensing circuit for 6 and 7 is your culprit. I can't help you anymore than that.
  18. dlfoster
    16
    Georgia
    2001 Prius
    alright, what's the best way to go about doing that?
  19. dlfoster
    16
    Georgia
    2001 Prius
    i'll check it out. thanks for the help
  20. dolj
    dolj Senior Member
    8,646
    4,397
    Find any and all modules that are leaking, remove and replace. While the pack is disassembled, i. e. all modules removed, throughly clean and dry the inside of the case. Thoroughly clean and dry all modules you intend to reuse, as they can easily have been contaminated by the leaking modules. Check all wiring for damage while you're at it, too.
