2001 prius hv battery help
Discussion in 'Generation 1 Prius Discussion' started by Cook71, Jan 12, 2015.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    If you don't have an RC charger, a variable power-supply would be the best.
  2. Cook71
    Cook71 New Member
    24
    2001 Prius
    Just ordered a tp820cd with 2x tp1527ps and a futaba br3000.
  3. Cook71
    Cook71 New Member
    24
    2001 Prius
    Ok I have all the tools and modules i need to rebuild this battery. now i need some help how to connect and measure the modules with this equipment. I have a TP1430C RC charger/discharger/cycler, 2x TP1527PS power supplies and a BR3000 battery checker.
  4. bwilson4web
    16,552
    Understand this is a collaborative effort and it is common for folks to add details.
    1. Number modules 1-38 with 1 by the controller. Measure voltages and post here.
    2. With one hand, remove one side buss bar. ONE HAND.
    3. Remove other buss bars.
    4. Inspect buss bars and terminals for corrosion. Post photos of worse.
    5. Inspect connectors looking for damage or corrosion.
    6. Remove modules and inspect terminal seals looking black smear, melted "O" rings.
    7. Take the lowest voltage modules and put a 5-10 minute, 8V charge and monitor voltage when charge is taken off. Those that drop below 5.5 V are put in the junk box.
    8. Rig up two compression plates and clamps.
    9. Configure cycle discharge / charge for NiMH. Limit charge voltage to 8V. One cycle and put aside to rest.
    10. Second pass, for the numbers after rest. One discharge / charge: RECORD DISCHARGE AMP-HOURS and module numbers.
    11. Those above 2.5 Ahr are marginally serviceable. But post the numbers to decide how many to replace.
    Be sure and clamp the modules because charging heats the modules and generates a small amount of gas. These combine to increase the internal pressure and you don't want to damage the modules by not having them clamped. Actually a pair of clamps works best so the modules taken off the charger can rest in the clamps.
    #24 bwilson4web, Jan 27, 2015
  5. Cook71
    Cook71 New Member
    24
    2001 Prius
    Thank you sir. I'm running around radio shack and internet to build a jumper cable for the br3000 meter, and making cables etc etc. Il get back with details in a few.
  6. Cook71
    Cook71 New Member
    24
    2001 Prius
    First I checked all the connections, toke off the connectors and cleaned them. I want to upload pictures but i get this error message
    "The following error occurred
    There was a problem uploading your file.
    image x.jpg"
  7. Cook71
    Cook71 New Member
    24
    2001 Prius
    I cant upload any pictures!! I lower the size and still nothing. Anyone knows whats going on?
  8. bwilson4web
    16,552
    See if you can post the pictures in a picture web site so you can insert the URL. That is the technique I use.
  9. ChapmanF
    19,060
    I've generally not had such problems ... the last line looks like maybe your file name contained a space? Have you tried renaming so it doesn't? It sounds goofy, I know, but trust me, I've seen goofier.
    -Chap
  10. Cook71
    Cook71 New Member
    24
    2001 Prius
    Its the same error. Don't no what's going on.
  11. Cook71
    Cook71 New Member
    24
    2001 Prius
    #31 Cook71, Jan 28, 2015
  12. Cook71
    Cook71 New Member
    24
    2001 Prius
    I used vinegar and salt bath to clean the copper from corrosion and rinse them after that with water and backing soda.
    [​IMG] [​IMG] [​IMG] [​IMG]
    Here are the pictures after cleaning
    [​IMG] [​IMG]
    #32 Cook71, Jan 28, 2015
  13. Cook71
    Cook71 New Member
    24
    2001 Prius
    Bob the controller is the ECU?
    Can I use 2 pieces of wood and use 2 clamps to hold the modules?
  14. Cook71
    Cook71 New Member
    24
    2001 Prius
    Thanks I got this site it is special for forums. Easy to work with them. I get all the codes for whatever I want.
  15. bwilson4web
    16,552
    Good deal! The controller is on the right side of the photo.
    You'll want to take photos during the disassembly as these will provide a road-map when you reassemble the pack. Start with a close-up of the controller side module so you won't forget the polarity (grins). Also, the temperature sensors.
    I recommend doing a close inspection of the buss bar, terminals before disassembly looking for evidence of corrosion. Speed is less important than accuracy and photos are better than human memory.
    As for the compression boards, you'll find these 6-cell modules have three mechanical 'dimples' on each side. I recommend recess-drilling, shallow holes to avoid stress concentrating the dimples. As for the number of clamps, two is a good number. You'll see when the first ones start to swell.
  16. Cook71
    Cook71 New Member
    24
    2001 Prius
    How many modules should i charge at once?
  17. bwilson4web
    16,552
    There is a learning curve. Start small and the most likely bad modules first. Then go up as it becomes more familiar.
  18. Cook71
    Cook71 New Member
    24
    2001 Prius
    This are the measurements:
    1 7.74
    2 7.74
    3 7.74
    4 7.74
    5 7.74
    6 7.74
    7 7.74
    8 7.74
    9 7.74
    10 7.74
    11 7.74
    12 7.74
    13 7.74
    14 7.74
    15 7.73
    16 7.73
    17 7.73
    18 7.73
    19 7.73
    20 7.73
    21 7.73
    22 7.73
    23 7.73
    24 7.73
    25 7.73
    26 7.73
    27 7.69
    28 7.69
    29 7.69
    30 7.69
    31 2.16
    32 4.64
    33 2.42
    34 3.1
    35 2.5
    36 0.18
    37 1.38
    38 0.88
  19. Cook71
    Cook71 New Member
    24
    2001 Prius
    Anyone guys are familiar with Thunder Power TP1430C charger? How can i rig this to read the prius module?
    I know the to program the charger but i cant figure it out how to read the Ahr of the module.
    This is what i have :
    1 x TP1430C - charger
    2 x TP1527PS - power supply
    1 x Futaba BR3000 - Voltage, capacity and balance meter
    Any ideas?
  20. ChapmanF
    19,060
    I don't know that particular charger, but the usual drill is to fully charge the module (setting the charger to turn off based on the right criteria for "fully charged"), and then set it to do a controlled discharge down to either 1.0 or 0.9 volts/cell (so, 6 or 5.4 volts for the module). If the charger is good it should have an amp-hour counter that measures the energy taken out of the module, and when it reaches the discharge cutoff, you look at that counter and that's the module's capacity.
    -Chap
    bwilson4web likes this.
