2001 prius key stuck
Discussion in 'Generation 1 Prius Discussion' started by Sharnold, Oct 25, 2019.
  1. Sharnold
    Sharnold Active Member
    365
    116
    Alabama
    I have a 2001 prius that I'm working on for a customer the only way you can remove the key is with the 12 V battery disconnected yes I've tried pressing the plastic pedal under the steering wheel it will not work I have took the steering column down and looked all the pieces are functioning as they should be I even adjusted the shifter linkage neither the key nor valet key will come out unless the battery is disconnected. Any ideas or hacks without replacing the column?
  2. Q*bertZ
    Q*bertZ Member
    155
    38
    greenville south Carolina
    2002 Prius
    Is the car in park?
  3. Sharnold
    365
    116
    Alabama
    Car is in park the nsbu or gear selector module recognizes it's in park but it will not release the key even while pressing the manual release under the steering wheel. Only way to remove it is to disconnect the 12volt battery
  4. Q*bertZ
    Q*bertZ Member
    155
    38
    2002 Prius
    So, by removing the 12volt battery, you some how disable the voltage to a switch or solenoid that allows the key to be removed. Interesting...find a wire diagram. Something in the park switch is not disabling the power correctly, even though it shows it is in park. Could the car have a short that is supplying 12volts to that key removal solenoid constantly until you disconnect the 12 volt battery?
    Sharnold likes this.
  5. Sharnold
    365
    116
    Alabama
    Yes I've already traced it down to a constant 12volt supply to the lock solenoid and it's in the gear selector switch But if i unplug the solenoid the key will come out
    #5 Sharnold, Oct 26, 2019
  6. Q*bertZ
    Q*bertZ Member
    155
    38
    2002 Prius
    Mount a switch outside the steering column that will disable that wire, so the key can be removed with out having to disconnect the battery. If that wire to the solenoid has a constant 12 volts, it shouldn't. Obviously something is causing it. A short to +12volts. Can you trace that wire back to its origin. What is giving it the +12 volts? The gear selector?
  7. Sharnold
    365
    116
    Alabama
    The gear selector is what supplies the voltage because it's not sensing the car is in park. I figured all of this stuff out last night.
  8. Claudio M Cacace
    Claudio M Cacace New Member
    Frisco, TX
    2002 Prius
    I
    I have thee same problem with my '02. So what is the solution? Replace the gear selector? I bought the car at Copart and I suspect it was damaged by forcing the gear selector out of P without turning car on.
