2001 Prius replaced main battery 2016 but now needs a generator
Discussion in 'Newbie Forum' started by 2001 Prius not running, Oct 12, 2018.
  1. 2001 Prius not running
    Oregon
    2001 Prius
    I bought a used 2001 Prius in 2015. It needed the main battery replaced in 2016. Now it is not running. Needs a generator. $4000. Plus I cannot afford! What is it worth? In cash? In trade ??
  2. 2001 Prius not running
    Oregon
    2001 Prius
    Will someone want to buy this or is this total junk??
  3. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    You can sell it if priced low enough and if you're patient. For example, an experienced mechanic that knows how to find a used generator for cheap, can use his own labor to replace the part. Maybe he'll flip it.
    It depends on how cheap you list it, what kind of battery you installed in '16, miles, and the condition of the rest of the car.
    52,742
    maybe for parts, try craigs list
  5. bisco
    52,742
    if your budget is low, look for a corolla or some such
  6. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Have to assume by generator you mean traction battery, Prius is a generator "because of" the traction battery and if yours is original, it's toast, well, it's a Toyota, so, if the body is good and passed inspection, a new traction battery, installed by a competent technician will bring life to a relic.
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    No, he said he bought a new traction battery in 2016. He means MG1 or MG2. At least that’s what I think he means by “main battery replaced”. I could be wrong though.
  8. bisco
    52,742
