2001 Prius turn signal relay location help
Discussion in 'Generation 1 Prius Discussion' started by statultra, Oct 20, 2024.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    I am searching for the turn signal relay, the repair manual specifically page BE-25 says the relay is in front of the drivers side door fuse box. Does anyone know where it would be located?
  2. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Do you doubt the repair manual is correct or are you asking for the location of the driver's side door fuse box?
    ronlewis likes this.
  3. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    If you'll turn over the cover for that fuse box, it has a diagram saying which fuse/relay does what.
  4. Trombone
    Trombone Active Member
    389
    130
    Allentown, Pennsylvania
    2002 Prius
    Unfortunately, that diagram does not specifically identify the flasher relay---I'm looking at the cover from my '02 right now. All of the IDs are fuses, not relays.
  5. ronlewis
    1,061
    206
    texas
    2001 Prius
    I have the PDF wiring manual if anyone wants it. Just pm.
