2001 Prius with dead MFD
Discussion in 'Generation 1 Prius Discussion' started by anniede77, Jan 11, 2018.
  1. anniede77
    anniede77 New Member
    Southern California, USA
    2001 Prius
    I
    I scored a 2001 with 175,000 miles and one owner who always took it to the dealer for ALL of its maintenance for under $3000, including tax, title, and reg today. The body is in excellent shape too - someone really really loved this car.
    I'm not a first-timer - I bought a 2005 Prius right off the lot when life was a bit better for me financially years ago. Life hasn't been so rosy for me lately, and I've spent the last 3 years driving a POS '97 Toyota Tercel, so this is a MAJOR upgrade for me.
    The only major thing I can see wrong with the car is that the MFD is dead. Well, not dead - the onscreen buttons are still functional (they beep when I touch where the manual says the brightness and contrast buttons should be) but the screen does not light up. I'm assuming that the extremely fragile bulb that backlights the screen is dead.
    Question 1 - how important is it to have the MFD working? Can I go without it, at least for a while until my student financial aid comes in?
    Question 2 - if I can find a working used MFD on ebay or at a local junk yard, how hard is it to replace? I'm pretty handy with tools and figured out quite a few things on my Tercel with the help of Mr Google and YouTube. I'm not afraid of getting my hands dirty or tearing apart the dashboard (probably with a lot of curse words involved)...as long as I can get it apart and back together without killing myself or the car.
    Question 3 - should I try to get in there and unplug and plug back in the unit first, just to see if it's a loose connection? (I'm going to school for IT, so I know the importance of unplugging stuff and plugging it back in.)
    Thanks!
    Anne
    rbdigital likes this.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I'm sure its possible to replace the MFD with a used one. The only problem is the plastic dash in the first gen Prius is very fragile. So you run the risk of possibly cracking your dash.
    If it was I who onwned a classic prius, I'd definitely want the touch screen!
    Glad you're back in the Prius gang!
    anniede77 likes this.
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    There should be wrecking yard Gen 1 Pri's in the wrecking yards around LA . I'd find one in a you pick it yard to see what's involved. It's not difficult, but as Aaron mentioned the old dash boards get to be fragile as dried spaghetti. There are tricks, and you should google removing the dash and also search this forum. Someone did a nice writeup last spring and I got one unmolested off a parts car last spring. Important to be sure to get all the fasteners out and then proceed very gently. Even then you'll probably crack it at best or have it shatter at worst.
  4. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Search the Gen 1 forums for a post by ChapmanF, he did a video to show you how to get the dash apart with the best chances of not breaking any of it.
  5. ChapmanF
    18,958
  6. anniede77
    2001 Prius
    I
    Awesome! Thank you for all your answers...and for ChapmanF's extremely informative video. It looks like something I can do, with a lot of care and curse words. I'll look into getting a replacement screen when my grant money comes in. I bought this car straight out with cash, so I'm a bit tapped right now.
    Anne
    dolj and Aaron Vitolins like this.
  7. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Using Chap's method, I've pulled a couple finish panels off wrecking yard or parts cars without damaging them. Always like to watch this video, because if you do as Chap does, your chances of getting the thing out undamaged are pretty good. The only thing I'd add is that to remove it all the way, you need to disconnect a bunch of wires and putting the shifter all the way to "B" helps. Disconnecting the 12v battery is a good idea, and will keep you from going crazy with the ding, ding, ding.
  8. ChapmanF
    18,958
    Thanks for the testimonial! I knew it worked ok for me, but I was curious how it would turn out to work for other people in other climates.
    -Chap
  9. Alexwasalreadytaken
    Alexwasalreadytaken Junior Member
    Northern California
    2001 Prius
    Hey Annie, it sounds like I am having the same problem with the screen in my 2001 Prius as you were. I've already checked to make sure there wasn't a blown fuse, and while the screen does not illuminate, I can hear beeping when I touch it in certain places. Were you able to fix your problem? If so, how did you fix it and how much did it cost you to repair?
  10. Misha
    Misha Junior Member
    Georgia
    2001 Prius
  11. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Sorry to bump such an old thread but my daughter’s 2002 is having this same MFD issue. Nothing shows on the screen but it beeps when touched where the buttons should be. Is this for sure a blown bulb? Fuses have been checked.
  12. ChapmanF
    18,958
    LCD panels need a backlight to be visible ... back in the Gen 1 era it was probably a tiny fluorescent-like tube built in behind the panel. I guess it is "replaceable" to people who regularly repair such things, but nothing like replacing a bulb. I don't know how hard it is to find a salvage Gen 1 MFD, but if you can find one, that might be simpler.
    WHCSC likes this.
  13. ChrisPDXPrius2001
    ChrisPDXPrius2001 Junior Member
    16
    portland
    2001 Prius
    My Gen 1 MFD has been "sorta" dead for awhile. Still beeps when I touch it and for whatever reason will come on for a few seconds when I start the car only if it's really hot or cold outside. Maybe there is a loose wire I need to jiggle? Before I would smack my dash and it would come on, but smacking no longer seems to work.
