2001 started shuddering and died now is a no-start
Discussion in 'Generation 1 Prius Discussion' started by vaughnstark777, Jun 28, 2018.
  1. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    I started a “conversation” about this “dilemma” and, now that I figured out how, I thought I’d start a public thread and maybe get some more ideas.
    There were several codes that showed after it died but no check engine light until after it died:
    C1259, P0300, 0301, 0302, 0303, 0304, P3190, P0171, P3190, P3000, P3101, B2799, P3009, C1521, C1522, C1571, C1572
    This came from my OTC scanner.
    After I cleared the codes I initially got:
    P3191, P3000, P3004, P3101, P3140, P3030, C1259, C1521, C1522
    Again with my OTC
    Because I was stumped and had the time I swapped HV batteries with another gen1 I have that had no known issues and also finally used my Mini VCI with the Toyota tech stream software and checked with it. I also cleaned the inside the TB and manifold because of the p3191. After the battery swap tech-stream gave me a c1259, p3191 and p3030 and still no-start, hence the p3191.
    What ever is causing the no-start is cutting power to the fuel pump (I used a jumper wire to force power to the fuel pump and it pumped fuel when I removed the pressure line with key on on position). With the jumper wire in place it still wouldn’t start so the problem is also cutting power to the coils and/or the injectors.
    I swapped the battery back to the original one that was in it when the car died and now it still won’t start but the p3030 is gone anyway. What I have left is p3191 (obviously) and c1259 and I’m out of ideas.
    I want to thank Patrick Wong, 3prongpaul and bwilson4web for checking in on the “conversation” I originally started with and their help getting me through some tests to get me to this point. Although I’m still stumped I have learned a lot so far.
    Anything anyone could add will be appreciated.
    Thanks for looking in,
    Vaughn
    iPhone ?
