For Sale 2001 Toyota Prius
Discussion in 'Private Sales' started by Oats, Nov 27, 2012.
  1. Oats
    Oats Junior Member
    28
    2001 Prius
    CAR HAS SOLD
    2001 Toyota Prius
    -cruise control
    -cd player
    -156k miles
    -optima yellow top (less than 6 mo old)
    $3800
    The car is located in Geneva, Ohio.
    Got it from the original owner in the fall of 2003 when they ordered a 2004. It's been a good car but got a good deal on a new 2012 Civic.
    Runs good, the tires are worn unevenly because of a stupid tire shop. Got a flat so the tire was replaced. There was a wobble at low speed, tire shop said the rim was slightly bent but the tire would wear and it would go away. After 4-5 months it hadn't gone away so I went to get a new rim and they said it wasn't bent, just corrosion on the mounting surface. Cleaned it up and the wobble is gone, but the tires are worn weird now.
    Cosmetically it is an 11 year old car. There are chips and door dings, there is a large touched up area on the passenger door from a shopping cart accident. The front bumper doesn't align perfectly on the right side from a minor accident.
    I forgot to take pics of the interior, but it is in good shape. The drivers rear floor mat has a bald spot on it. The front mats look new since they have another set of mats over them.
    Last year it got new spark plugs, new coolant, new inverter coolant, new transmission fluid. All fluids were replaced with the proper Toyota fluids. The transmission pan was removed and cleaned along with the little magnet in there.
    IMG_4790.JPG IMG_4791.JPG IMG_4792.JPG IMG_4793.JPG IMG_4794.JPG IMG_4795.JPG IMG_4796.JPG IMG_4797.JPG IMG_4798.JPG IMG_4799.JPG IMG_4800.JPG
