2002 cig, side mirrors radio MFD not working
Discussion in 'Generation 1 Prius Discussion' started by Lost and confused, Jan 20, 2019.
  1. Lost and confused
    Lost and confused New Member
    Wisconsin
    2002 Prius
    i just bought a 2002 Prius. It is in perfect shape but the side mirrors,MFD, radio and cig lighter do not work. I checked all the fuses and all were good. Any thoughts on this?
    52,880
    visual check? i suppose if its more than one fuse, it is more likely a wiring problem. any sign of rodent activity?
  3. Lost and confused
    Wisconsin
    2002 Prius
    I have checked all fuses and everyone tested out fine. There is no signs of rodent anywhere.
  4. ilmawi
    ilmawi Junior Member
    Finland
    How's your 12v battery? If there is not enough juice the relay wont flip. I had this in my 2007. I had to swap the battery to get this fixed.
  5. ChapmanF
    19,046
    Someday I want to see what you call "not in perfect shape".
    Wiring diagram (more info) and a multimeter will be your friends for this one.
